Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Fri Jul 31, 2015 6:41 am Post subject: Removing the interior light |
How do I remove the 2 interior lights from my BT6 without destroying the headliner? I tried to pull... but did not risk to pull to hard so it would break?
any special method?
Thanks!
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Fri Jul 31, 2015 11:34 am Post subject: |
Porsche dome lights work exactly like VW dome lights
At either end of the dome light, there are spring-loaded brass "bullet" catches that press outward against the mounting hole in the headliner. Use something flat on either end and insert it between the light and the headliner material. But pry it out carefully, as the 50+ year old clear plastic surround can be fragile. It just snaps out, and snaps back in.
Jerry Henning
St Pete FL _________________ Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket |
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Sat Aug 01, 2015 8:58 pm Post subject: |
Use some small plastic wedges on either end and be careful. Take your time. These parts are fragile! |
roy mawbey Samba Member
Joined: May 21, 2012 Posts: 397 Location: Sussex England
Posted: Wed Aug 05, 2015 3:41 am Post subject: |
That was a good question and a good clear answer! I got one out 20 years ago by luck I reckon. The other needing a new bulb ( probably 56 years old ) I could not move without damaging it I think. Now, I will try again.
thanks
Roy _________________ Roy
RHD356A super75 106954 |
