richierich Samba Member
Posted: Fri Jul 31, 2015 11:52 am Post subject: New distributor - I'm puzzled! |
Hi all - have a stock 1600dp in my bus. It had a Bocar carb fitted along with a 009 distributor and ran like ****. So, I've had my original German Solex 34 pict 3 rebuilt and am going to fit a new vacuum advance distributor that I have bought as I know the stock carbs don't work well with the 009.
The problem is, when I've put in the new distributor, with the crank at TDC the notch in the rim is at kind of the 1 o'clock position rather than 5 o'clock ish where I think it ought to be......
Am I missing somehing here? _________________ Blah..... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 31, 2015 12:26 pm Post subject: |
Sounds like the distributor drive was installed at the wrong angle. Get a drive puller and re-align. _________________ In Stereo, Where Available! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 31, 2015 12:29 pm Post subject: |
SVDA's are 90 degrees off from the 009, move the wires one hole over. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jul 31, 2015 12:33 pm Post subject: |
Busdaddy - is that an absolute def? It is an SVDA distributor...
Actually Busdaddy - no need to answer that - you wouldn't have said it if you weren't certain - sorry! So the plug leads just move one position round anti-clockwise then right? _________________ Blah..... |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Jul 31, 2015 12:54 pm Post subject: |
busdaddy wrote: |
SVDA's are 90 degrees off from the 009, move the wires one hole over. |
You need to be careful when doing this, I have heard some distributors have a special lobe to make the number 3 cylinder run cooler. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Fri Jul 31, 2015 1:22 pm Post subject: |
campingbox wrote: |
busdaddy wrote: |
Some pre 71 distributors had #3 lobe retarded - IIRC about 5-7* retarded. This was because the oil cooler was in the path of #3 which hampered air flow. Actually air to #4 was also impeded but not as severely as #3. With the doghouse cooler being set out and away from the direct air no retard was needed. I think it was the 66-70 motors that did that. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
Agreed as well, AFAIK the retarded #3 is only found on SVSA's and DVDA's are all evenly timed.
You also may have issues with the vacuum can hitting something before you can time it correctly, in that case the drive must be moved (don't lose those washers). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Fri Jul 31, 2015 9:09 pm Post subject: Re: New distributor - I'm puzzled! |
richierich wrote: |
Am I missing somehing here? |
Where'd you get the dist? I bought a new 034 SVDA from Aircooled.Net, and the notch is definitrly different than my .009. I think you just need to be confident where #1 is (Remove #1 and see where TDH is), and then time from there. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
Posted: Sat Aug 01, 2015 12:29 pm Post subject: |
Ok - this morning I got the number one plug out and found top dead center which concurred with the marking on the pulley. The notch on the distributor rim is indeed at about 2 o'clock. Moved the plug leads to suit, timed it up and its running like ****! _________________ Blah..... |
quartermilecamel Samba Member
Posted: Sat Aug 01, 2015 12:41 pm Post subject: |
firing order off? Point gap off? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Sat Aug 01, 2015 2:10 pm Post subject: |
richierich wrote: |
timed it up and its running like ****! |
Could you be more descriptive with that?, idles nice but dies when you give it gas?, craps out at high speed?, barely idles?
Just like it ran before the carb/dist. swap?, or a different sort of ****! ? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Aug 01, 2015 2:11 pm Post subject: |
Recheck EACH plug cable to make sure you did not mix up two or more of them. _________________ In Stereo, Where Available! |
Posted: Sat Aug 01, 2015 3:56 pm Post subject: |
Firing order is correct - I've checked and double/triple checked that all plug leads are correct. When I took it on a short drive it runs ok and seems to have more power than before with the 009 etc BUT once the engine comes off choke it just does not want to idle at all, is lumpy and after about 15 seconds, dies. Bizzarely, if I partially cup my hand over the top of the carb (with air filter off) it idles better..! Maybe a clue here for those of you more experienced than me??
Considering it now has all new ignition components, new plugs and points (correctly gapped) valves clearances done and freshly rebuilt carb - I'm thinking either fuel pump pushrod or a vacuum leak somewhere along the inlet pipework. What do you guys think? _________________ Blah..... |
Posted: Sat Aug 01, 2015 4:16 pm Post subject: |
Too lean, but since it doesn't die under power the pump is out of the picture. Do a vacuum leak check by spraying something flammable on all the manifold joints and see if it picks up for a second. If that fails start unscrewing the smaller of the 2 brass screws on the left side of the carb until the idle improves (this assumes the throttle stop screw is adjusted properly and the butterfly is completely closed). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Aug 01, 2015 4:48 pm Post subject: |
Good point about the fuel supply. I'm gona be vexed if there's a vacuum leak to chase. _________________ Blah..... |
Posted: Sat Aug 01, 2015 5:06 pm Post subject: |
richierich wrote: |
Good point about the fuel supply. I'm gona be vexed if there's a vacuum leak to chase. |
I got for carb tuning. Cupping the carb wouldn't make it better if the leak was after the carb, right?
You switched a bunch of things whike trying to figure out why it ran poorly, including switching carbs.
Read your plugs.
Focus on the carb now, and set it up with a baseline setting. I haven't run stock carburetion in a long time, but either the Muir guide or someone here can help with that. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Posted: Sat Aug 01, 2015 5:12 pm Post subject: |
KevinAlbrecht wrote: |
richierich wrote: |
Read your plugs.
Focus on the carb now, and set it up with a baseline setting. I haven't run stock carburetion in a long time, but either the Muir guide or someone here can help with that. |
It stopped running full stop with the previous Bocar carb hence me digging out an original Solex to have rebuilt. At least now it is running - if a little poorly. _________________ Blah..... |
Posted: Sat Aug 01, 2015 5:16 pm Post subject: |
Blah, blah,
Read your plugs... 😎 _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Posted: Sat Aug 01, 2015 6:32 pm Post subject: |
I'm not sure how much the color of the plugs can tell you about an idle issue, but pulling wires out of the cap one at a time and noticing which one(s) don't make the idle get even worse can narrow the issue down to a certain cylinder. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
