Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Aug 01, 2015 8:43 pm Post subject: |
Did you possibly pull on the spark plug wires to remove them off the plugs? That can stretch the cables to the point the wires inside pull away from the end socket and then cause spark plug problem. _________________ In Stereo, Where Available! |
richierich Samba Member
Posted: Sun Aug 02, 2015 4:13 am Post subject: |
Eric&Barb - good point but I am always very careful to not pull on the leads like that. _________________ Blah..... |
Posted: Tue Aug 04, 2015 3:08 pm Post subject: |
Ok an update on this....The bus is now running nice, I rechecked the timing and went back to the beginning and reset the throttle control on the carb and then got it running nice with the volume control and idle speed screws. I had fitted a new coil - a Silver one which is labeled Bosch but says made in Brazil on it...not trusting it i refitted my original Bosch Blue one and it seems to have made a difference. Are the Silver Bosch Brazil made ones known to be junk?? _________________ Blah..... |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Tue Aug 04, 2015 4:12 pm Post subject: |
richierich wrote: |
Ok an update on this....The bus is now running nice, I rechecked the timing and went back to the beginning and reset the throttle control on the carb and then got it running nice with the volume control and idle speed screws. I had fitted a new coil - a Silver one which is labeled Bosch but says made in Brazil on it...not trusting it i refitted my original Bosch Blue one and it seems to have made a difference. Are the Silver Bosch Brazil made ones known to be junk?? |
Yes _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
srfndoc Samba Member
Posted: Tue Aug 04, 2015 6:20 pm Post subject: |
richierich wrote: |
Atwell covered this pretty well:
http://www.ratwell.com/technical/BlueCoil.html
I recently purchased this one which seemed to check all his required boxes for a good one:
http://www.amazon.com/gp/product/B001CO4WA2?psc=1&...ge_o02_s00 _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
