Valve Adjustment 1.4 Rockers
dentfreeimage
dentfreeimage is offline
PostPosted: Sat Aug 01, 2015 9:08 pm    Post subject: Valve Adjustment 1.4 Rockers Reply with quote
Hello everyone, I just upgraded to 1.4 rockers with lash caps and will like to know what is the recommended valve adjustment. Also I am using chromoly push rods, I use to run .002 with the 1.1 rockers.
I greatly appreciate the advice!
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Sun Aug 02, 2015 1:32 am    Post subject: Reply with quote
The rockers have not crap to do with valve adjustments. .006 with aluminum pushrods. Loose zero with chromoly.
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
mark tucker
mark tucker is offline
PostPosted: Sun Aug 02, 2015 2:34 am    Post subject: Reply with quote
yes lug they do....... but zero works for most just fine on vw stuff
dentfreeimage
PostPosted: Sun Aug 02, 2015 6:30 am    Post subject: Reply with quote
Great, thanks for the help. Just making sure they are no changes by upgrading the rockers.
dentfreeimage
mark tucker
PostPosted: Sun Aug 02, 2015 9:25 am    Post subject: Reply with quote
just be sure the geo is close.
Ebel
Ebel is offline
PostPosted: Sun Aug 02, 2015 2:12 pm    Post subject: Reply with quote
Did you change the pushrods at the same time? I'm guessing its a stock cam if your going from 1.1 to 1.4. But I think no matter what you would need shorter pushrods.
