Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Sun Aug 02, 2015 9:37 pm Post subject: So what is the platform above the driver side tail light? |
So what is the platform above the driver side tail light on the green and white Things? I cant figure it out... I know they are French so maybe something they require?
_________________ Change is Opportunity!
Instagram=metaltwister |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Sun Aug 02, 2015 10:05 pm Post subject: |
Antenna mount for military radio. |
Semper_Dad Samba Member
Doc*181 Samba Member
Joined: December 09, 2003 Posts: 479 Location: Belgium
Posted: Mon Aug 03, 2015 9:19 am Post subject: |
I did give that a thought but talked myself out of that because it was so stout looking. Seemed over built for an atenna? Thaanks so much for all the info and posts. It is appreciated! _________________ Change is Opportunity!
Posted: Mon Aug 03, 2015 12:21 pm Post subject: |
Metal Twister wrote: |
I did give that a thought but talked myself out of that because it was so stout looking. Seemed over built for an atenna? Thaanks so much for all the info and posts. It is appreciated! |
No problem at all!
Just a small and maybe interesting fact: a genuin french 181 had an extra support for mounting a 3-point seatbelt. Handy to know if you spot a 181 with a french license plate. _________________ Thing stuff:
http://vw181.skynetblogs.be/ |
Posted: Mon Aug 03, 2015 12:34 pm Post subject: |
I get to pick up my thing sometime this week for the first time. Being it is off roaded and not original Im thinking seriously about blanking tthe original tail lights off and cutting in some bus tail lights like the French models. That might be a good mounting point for an Off road / CB antenna though I dont think Im going to be adding thinmg that substantial. Thanks for the help. _________________ Change is Opportunity!
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Mon Aug 03, 2015 1:37 pm Post subject: |
I was going to have one fabricated but it turned out to be more cost effective to buy one from Maik Potter, even with shipping from Germany:
http://www.u-m-p.de/seite4.html
I found the Telefunken antenna on eBay, from a seller in Poland. _________________ Mike B. |
Posted: Mon Aug 03, 2015 2:20 pm Post subject: |
As a metal fabricator by trade that is one stout antenna mount. Id expect to see that mounted to a building with a giant antenna attached. Great find by the way... _________________ Change is Opportunity!
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Thu Aug 06, 2015 9:53 am Post subject: |
As a metal fabricator by trade that is one stout antenna mount. Id expect to see that mounted to a building with a giant antenna attached. Great find by the way... |
That is not uncommon for military antenna mounts which may be made for more than one vehicle and more than one antenna-type, to simplify number of parts and cut costs through volume production. _________________ L'audace! L'audace! Toujours l'audace! |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Tue Mar 10, 2020 9:17 am Post subject: Re: So what is the platform above the driver side tail light? |
Checkmate King 2... This is White Rook |
Mark Lewalski Samba Member
Joined: June 19, 2010 Posts: 406 Location: Safety Harbor, FL (Tampa Bay)
Posted: Mon Mar 23, 2020 1:51 pm Post subject: Re: So what is the platform above the driver side tail light? |
I've seen those antennas get the heck knocked out of them when in the field at Hohenfels Training Area. That mount needs to be strong enough and spread the load enough with a 3-4 meter antenna moving around up top.
The Humvee antennas I worked on had similar mounts but were a lighter metal. They got banged up all the time.
Mark _________________ '89 Vanagon GL Wolfsburg "Bluestar" (given to and owned by my son now)
'87 Vanagon Weekender
'74 Thing |
