miguedangel Samba Member
Posted: Mon Aug 03, 2015 1:43 pm Post subject: My 1679cc |
Hello everyone!
I have a Fastback 1967 stock, but I'm about to repair the engine with the following settings!
AA Performance Pistons 88x69
Cylinder heads Stock with Stainless steel valves 35.5x32mm Polished dual-port heads
Scat Hi-rev lightweight racing lifters
Scat 0.3125" Fixed Steel pushrods
Scat Hi-rev Single Springs with Chromoly Retainers
Engle W100 & straight-cut steel crank & cam gear
Schadek 26mm Oil Pump
Dual Weber IDF 40/40
Tri-Mil Exhaust System 1 3/8 "" Tuck-a-way "
Bosch 009 Electronic ignition
I hope to get good results with these toys ... and then they let you know that get results on the dynamometer |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Mon Aug 03, 2015 8:24 pm Post subject: Re: My 1679cc |
miguedangel wrote: |
Hello everyone!
Sounds like a nice combo. Use the 88 cylinders that machine in to the head side and slip in the case. They are thicker than stock on the head side. I have heard that straight cut gears are hard on the ears and only necessary for huge cams. Have fun. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Aug 04, 2015 1:08 am Post subject: |
This is a circa 5500rpm street motor, yes? Unless you have already spent the money, you do not need the CrMo retainers, steel pushrods and 'racing' lifters
But yes it's always fun building a 'no machine' engine as for many/most people there is less to prepare, less to think about... and less go wrong |
