egibau Samba Member
Posted: Thu Aug 06, 2015 3:05 pm Post subject: Anyone else with november 1961 type 2? |
I pulled a november 1961 15 Windows bus out of the Norwegian Woods a few years ago. The bus had been sitting there since the mid-seventies, so bits and pieces has been removed, but it is restorable. The biggest issue is that both m-plate and vin plate is removed, and the section With the vin nr is rusted out. The number on the front beam (817588) tells it is an early november 1961, but I know nothing more than that.
Is there anyone here With a november 61 bus With both beam nr, vin nr and date of Production, so that I can try to figure out approximately what my vin nr is? If i can narrow it to a small series of numbers, then i can get the dmv to search after it, right now they are a bit tired of me sending them random numbers starting With 85xxxx....
All help appreciated!!!
GTV Samba Member
Posted: Thu Aug 06, 2015 3:40 pm Post subject: |
Nice rescue
The number stamped on the transmission may help you narrow it down more as well. _________________ EMPI Power Rules! |
Clara Samba Member
Posted: Thu Aug 06, 2015 8:41 pm Post subject: |
epic first post! _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Aug 07, 2015 8:39 am Post subject: |
Man that is a real extraction, more pics please! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
egibau Samba Member
Posted: Sat Aug 08, 2015 2:24 pm Post subject: |
Well, I dont have many exciting pics from the rescue. The big bad yellow machine made it quite easy to remove it from the place where it had been sitting for all those years. Lots of thanks to the gentleman in the drivers cabin for lending us his machine and helping us there.
Got a Picture of it as found.
Another one when we started to lift it.
The last one as it sits now, after washing it With a high pressure steamer.
The idea is to keep the body mostly as it is, and replace the rusted out frame. Received the front floor and some other metal parts today, and I think they were the last pieces of the Puzzle. So, I Guess it is time to start the fun pretty soon.... |
egibau Samba Member
Posted: Tue Aug 18, 2015 9:45 am Post subject: |
Ok, numbers from one car so far. It is a doublecab made 15 November, vin.nr 865xxx, beam nr. 824324.
First vin.nr in november is 850334, last one 871303.
First beam nr is 816228, last one 829135.
There was roughly 21000 cars made, and 13000 beams numbered....
Does anyone have an idea why 8000 cars had unnumbered beams?
Something to do With Foreign Production vehicles?
Maybe only the German made had a number on the beam?
All help appreciated and needed..... |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Aug 18, 2015 10:02 am Post subject: |
I have an October 1961 single cab. I've never tried to find the beam #, where would I look? _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
egibau Samba Member
Posted: Tue Aug 18, 2015 11:26 am Post subject: |
On the front of the bump stop, right hand side. |
egibau Samba Member
Posted: Tue Aug 18, 2015 11:44 am Post subject: |
Here is what mine looks like
And this is where the m-plate ones was.
With some imagination you can read 0x 11 1 |
egibau Samba Member
Posted: Thu Sep 03, 2015 11:50 am Post subject: |
Where can I find the gearbox number? |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2356 Location: In the woods, Ontario
Posted: Thu Sep 03, 2015 6:13 pm Post subject: |
egibau wrote: |
01 11 1 |
Clara Samba Member
Posted: Thu Sep 03, 2015 10:13 pm Post subject: Re: Anyone else with november 1961 type 2? |
egibau wrote: |
I pulled a november 1961 15 Windows bus out of the Norwegian Woods a few years ago. ....The number on the front beam (817588) tells it is an early november 1961, but I know nothing more than that.
Is there anyone here With a november 61 bus With both beam nr, vin nr and date of Production, so that I can try to figure out approximately what my vin nr is? ... |
I thought of checking Progressive Refinements at http://www.oacdp.org/
There is only one bus data point for Nov 1961
3 Nov 1961 - bus VIN 851 390 had beam 818 037.
The last bus buildt in October 1961 was VIN 850 333 with beam 816 227
There are 1057 VINs between the two VINs, and 1810 beams between the two beam # that went with them. So either they put some beams aside for spares, and/or these were not always sequential.
Hope this helps.
egibau Samba Member
Posted: Tue Sep 08, 2015 12:59 pm Post subject: |
Thank you so much That very useful information could have solved this, if I am lucky. My beam is 449 earlier than the 818037. So, vin nr.851390-449=850940. I sent a request to the DMV and asked if they could search the old archives on anything in the vin series 850930-851030.
Today I received a mail with a copy of a registration card on a 1962 VW with vin nr 851018, and registration nr U4382.
Now I am sending mails to a few of the local DMVs to see if they can find anything on that reg.nr. And if they find anything that can tie it to the late owner or his District, well, then my search is over and I am very happy. |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Tue Sep 08, 2015 2:11 pm Post subject: |
Great detective work!! I wish you luck with the final pieces of the jigsaw.
Cheers
Dave |
Posted: Tue Sep 08, 2015 2:39 pm Post subject: |
That is some cool news, what a great find. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
egibau Samba Member
Posted: Thu Sep 10, 2015 12:58 am Post subject: |
It gets even better. Received a mail from the DMV of Trondheim which confirms it as a Type 2, 241 Zamba (typed with a Z). It spent its first years as a taxi, allowed to carry 13 children up to 15 years of age, or 8 adults! Imported to Norway 14 November 1961. Got the name of the first owner, and the dealership where he traded it in for a new one in december 1965. |
Clara Samba Member
Posted: Thu Sep 10, 2015 6:40 am Post subject: |
Sweet! Does this mean you can get the paperwork ironed out? Will you be driving it soon? Isn't a corner window bus a beautiful thing? Maybe I will start calling them "Zamba"s. Any old pictures of it with logos in the local newspaper archives? Or that the original owner has?
Wasn't there a famous smith from Trondheim? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Sep 10, 2015 9:40 am Post subject: |
A Zamba, wow, that is rad-e-cal-mon! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
