SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Tcash Samba Member
Posted: Mon Oct 03, 2016 8:04 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
So would the adjustments to my carburetors lead to the need of adjusting my timing and ignition?
As of right now, after of course learning I was out of gas, even with fuel being deliveried to both carbs, I cannot for the life of me to get the bus to run, let alone idle. This is bizarre.
I apparently (dangerously) read Colin's works on fine tuning Dual Solex carbs and jacked my ride up. She was getting good gas mileage and solid pickup. Dammit!!! |
Not dwell. But you always need to set idle and check timing.
Check the filters. Maybe you sucked up some stuff when it ran out of gas.
Good luck
Tcash |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Mon Oct 03, 2016 10:26 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Running clear out of gas is notorious for sucking all of the crap from your tank into the fuel system.
Oftentimes, the crap can go past the filters magically somehow.
You will likely see the results of this in the idle circuit, where the passages are smallest.
Symptoms might be the mixture screws not responding..
Might as well open the carbs up and do the blow-out routine with carb cleaner and compressed air..
Pull idle jets and mixture screws (after counting how many turns out from bottomed) and give them the old blow-out.
Carbs changing wouldn't change ignition per se, but you can be visited by the Invisible Shit Fairy that comes and breaks things in the night.
Have seen her work before... She magically breaks two things at once.
Might give it a check with your timing light to verify she hasn't been by.. _________________ Bus Motor Build
Whats That Noise?!? |
wcfvw69 Samba Purist
Posted: Tue Oct 04, 2016 7:27 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
You saying the patina looks bad?!
Are the suppose to be a true white or an off-white creamy color? |
Yes, patina bumpers look not so good in my opinion. The paint code for the correct color white is in the technical tabs. You can take the code to a auto body paint supplier and they can mix up some paint to spray or they can mix it up and put it in spray cans for you.
It's make a HUGE difference in the appearance of your bus. _________________ Contact me at [email protected]
The Samba member since 2004.
notchboy wrote: |
Go sand and paint your bumpers white then while you wait |
The lady has been harping me for a while about them. You saying the patina looks bad?!
No patina is good
Its just that the bus looks so nice
They are supposed to be pastel white I believe or Lotus white Either way they are both a creamy, yellowish white. I just did mine in Rustoleum white - especially on my 74. I like the contrast way better on a bus thats all white. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Thu Oct 06, 2016 4:15 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Just for Notch, here it is:
This is Rustoleum's Heirloom White. Took the advice from a fellow member in matching attempts to L90D (Pastel White). I think it looks pretty good, I'd like to wax it to seal it but that'll be another day.
Also took apart my shifter, cleaned and regreased it. It was crusty and dried up goop. Also caught a small shot of the two front bushings I am missing. Does the one that goes into the shaft really do much, I can understand the O-ring one serving a purpose of being a guide, but the front pop-in one just doesn't seem to important to me. Educate me.
_________________ The Bus Barn Ltd. Co.
Oct. 67 Double Cab (68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Oct 06, 2016 4:58 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
There isn't anything that goes in the end of the rod, on earlier (pre 73) models there's a bushing that goes into the end, but it's a radically different mechanism. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Oct 06, 2016 5:27 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Wow, whos bus it that? Looks sharp!
Up above I wrote :
No patina is good. I meant to write - No, patina is good.
Lookin good brotha, lookin good.
t3kg wrote: |
1964 1500 S
Tcash Samba Member
Posted: Thu Oct 06, 2016 6:37 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Shifter Parts ID |
Tcash Samba Member
Posted: Thu Oct 06, 2016 8:11 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
No pain. Just refreshing. You threw me off with your question. "Does the one that goes into the shaft really do much," This pic has the bushings and their locations.
I do not know of a Tech tip for replacing the bushings. Seems it comes in bits and pieces. There was one Guest that did the whole job front to back. But I think it is buried in a build thread.
It is pretty straight forward.
Good luck
Tcash |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Thu Oct 06, 2016 9:12 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Tcash wrote: |
Good luck
Tcash |
Where would #5 go on a 79, and on no other year of bay? I did #1, #2, 2x#3 on my 79 just wonder if I missed number 5. _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Tcash Samba Member
Posted: Thu Oct 06, 2016 10:09 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
captincanuck wrote: |
Where would #5 go on a 79, and on no other year of bay? |
Does not fit a T2. Fits T25 79-92. I will have to edit that.
Thank you
Tcash |
Posted: Sun Oct 09, 2016 3:34 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So the front end got the same treatment as the rear!
Prior to placing the bumper back on, the bus got some scrubbing:
Still working out my dumbass mistakes made on the carbs and timing, so no camping this past weekend.
Weather is getting good though, someone wiggle their nose or say some voodoo bus magic, I'm needing some help! _________________ The Bus Barn Ltd. Co.
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Oct 09, 2016 4:15 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Looking real good, Sam. And seeing your wheels has made up my mind about how I'm going to do mine. I like the white and chrome with the orange bus. Not sure about the white walls, though.
Thanks for posting the update. Yours was the first rebuild thread I read on Samba, so it's good to hear the progress. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
