Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Sun Aug 09, 2015 1:57 pm Post subject: Italian 44IDF´s bypassing too much air at idle |
Hello
I have got a car in the shop for tune up and a couple of repairs.
Now, one of the reasons I got it was that he could not back it down enough to get a decent idle, like 900 rpm or so, unless the timing also was backed down to like 5 degrees AFTER TDC.
I took the carbs off and had a thorough look at them, thinking that something prohibited the butterflys to close. But no. They close as good as can get. I couldnt really find anything wrong with them, so I installed them again, only to experience the same behaviure.
Bypass valves are 100% closed, so that´s not it. It seems that the carburettors are dragging air from somewhere else (!)
Has somebody experienced that issue before ? Cure ?
Thanks
Torben |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Aug 09, 2015 4:04 pm Post subject: |
What size is the engine?
I am also looking at a similar, but probably different case, here what I found is even though both throttle plates looked like they closed ok, the shaft was warped enough to cause the first progression hole to be ever-so-slightly solicited.
I could never get fron-to-back snail readings even, was even beyond the range of the bypass's flow ability to correct.
orders a new shaft and waiting to see...
What are you seeing on the snail? Doei it still have the choke slider-valve thingys? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sun Aug 09, 2015 8:55 pm Post subject: |
Make sure the carbs are not units designed for "single" use....like with holes in throttle plate.
I would also check for vacuum leaks.... Early HPMx's had a bad rep for leaking at the throttle shaft. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun Aug 09, 2015 10:58 pm Post subject: |
I have a set from an alfa, the throttles had too much end-play, and wore the sides of the throttle plates.
Looked ok at first, but with flashlight on other side I can see gaps all the say around throttle plate! |
Posted: Mon Aug 10, 2015 1:18 am Post subject: |
2165
Butterflys close, and no slack. |
Posted: Mon Aug 10, 2015 7:44 am Post subject: |
You are making an incorrect assumption that just because the bypass screws are closed, that they are sealing and no air is passing through them. Just sayin'.
Use a snail gauge and figure out which bbl is the one with the problem. It may be more than one FWIW.
Intake leak will also do it. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
mark tucker Samba Member
Posted: Mon Aug 10, 2015 8:53 am Post subject: |
my gess would be intake or shaft leak or the bypass screws are sorta afu....or possiably a set of ported heads that went a bit too far. any vacume ports or hoses any where? |
Posted: Mon Aug 10, 2015 9:29 am Post subject: |
The snail gauge show the same within 0,5.
The bypass srews or seats my be the problem. I replaced the carbs with a Spanish set I had on the shelf this afternoon, because I had dyno time and needed to finish the car for delivery. I will take a very thorough look at them when time permits.
I´ll post the dyno sheet later. It came out quite nice for what it is.
But thanks for chiming in.
T
Posted: Mon Aug 10, 2015 9:30 am Post subject: |
some IDF throttle shafts also leak at the center locations, where it's bushed (no bearings). _________________ It's just advice, do whatever you want with it!
käfertom Samba Member
Joined: November 08, 2010 Posts: 48 Location: Germany
Posted: Thu Aug 27, 2015 1:28 pm Post subject: |
Alstrup wrote: |
T |
Any update? |
drumbum68 Samba Member
Posted: Fri Aug 28, 2015 4:58 pm Post subject: |
Sometimes people strip 'em down for a soak, but don' remove shafts or bearings, bye-bye grease. Older webers used shielded bearings (leak like a sieve w/no grease) instead of sealed like dell'orto. |
