vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Aug 10, 2015 11:33 am Post subject: Non-returning or sticky brake pedal |
What all is supposed to cause the brake pedal to return when it is released?
In my '73, it has started to be very slow to return to the resting position. The brakes are holding until it has returned. (and slowly releasing as it returns.)
I can pull it up with my foot to the resting position.
Related, I think, is that the feel while pressing the brake pedal seems weird. Hard to describe, almost notchy I guess. So it seems like the resistance is there either direction (pushing or releasing).
For a temporary measure, I hooked a bungee cord to the brake lever underneath and the bumper and this helps return the pedal more quickly and makes the bus a little more driveable.
I've been hosing the area of the return spring with penetrating oil the past couple days but no improvement yet.
The master cylinder is new, as are the front hoses and a caliper that was sticky. I think I ended up replacing the rear cylinders but I don't remember for sure at the moment...
In the '73 Thing I'm working on, the brake pedal also returns slowly. In it, the master cylinder isn't even installed at the moment so I know the problem is likely in the pedal cluster. Working that one with my hand feels similar to the symptoms the bus is now showing, so I'm thinking maybe I have some corrosion in the pivot point where the brake pedal attaches to the rod.
Is the spring at the pivot point in those the only real thing that is supposed to return the brake pedal? (With the Thing, I was thinking it might work better when I get the master cylinder installed but now I'm not sure.)
Maybe all they need is to be pulled apart and greased? Other things to check? _________________ Dave Cook
1973 Wild Westerner
My Thing |
Malokin Martin Samba Member
Posted: Mon Aug 10, 2015 12:10 pm Post subject: |
Via pure laziness I have been dealing with this for a year and would like to know as well. I've gotten so used to pulling it back with my toe it's kind of part of driving at this point. |
Zeitgeist 13 Samba Member
Posted: Mon Aug 10, 2015 12:14 pm Post subject: |
I'm currently in the middle of this same misadventure with a '77 van. The calipers were both seized and the pedal was sticking in the down position. I lubed the pivot, but the pedal was still sticking, so then I pulled the booster. I found that the booster was stiff, so I peeled back the boots and sprayed silicone in there, and then worked the actuator rod in and out until there was smooth non-sticky operation. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Tcash Samba Member
Posted: Mon Aug 10, 2015 12:48 pm Post subject: |
#12 spring is broke, #3 bushing rusted, #25A rusted.
thanks to mayor ratwell
Good luck
Tcash |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Mon Aug 10, 2015 3:45 pm Post subject: |
In addition to the pedal/linkage return spring, there are two piston return springs inside the M/C, and a hurkin
big conical return spring in the booster, and maybe more springs in the booster valving. Those are some strong-ass
springs, so you got some serious problems with your brakes somewhere. I don't know if compensating port
blockage in the M/C would prevent piston return like that, but it's worth checking by making sure there's at least
a little play between the pedal linkage and the booster operating rod where they join up.
You could try disconnecting the vacuum line from the booster and seeing if the pedal returns. If it does, then probably the booster valving is shot. _________________ '67 bug: seized by the authorities
Tcash Samba Member
Posted: Mon Aug 10, 2015 8:19 pm Post subject: |
I don't know if compensating port blockage in the M/C would prevent piston return.
If this happened the pedal would still return, but the brakes would remain applied. Smoking brakes are the result.
Tcash |
Posted: Tue Aug 25, 2015 4:39 pm Post subject: |
Zeitgeist 13 wrote: |
I'm currently in the middle of this same misadventure with a '77 van. The calipers were both seized and the pedal was sticking in the down position. I lubed the pivot, but the pedal was still sticking, so then I pulled the booster. I found that the booster was stiff, so I peeled back the boots and sprayed silicone in there, and then worked the actuator rod in and out until there was smooth non-sticky operation. |
Finally had a few minutes to spend attempting diagnosis.
I pulled the pin that connects the brake pedal to the booster rod just behind the spring. With that undone, the brake pedal springs back to it's position easily.
So the problem is either in the booster or the master cylinder. I'll be super pissed if it is the master cylinder again! I replaced the original one with a rebuilt from the FLAPS in December because it was leaking fluid into the booster. I replaced that one with an exchange a couple months ago because it was leaking past internal seals or something and not working well either.
I guess I'll try to pull the boot back off the booster and see if some spray lube in there helps out. _________________ Dave Cook
1973 Wild Westerner
My Thing |
busdaddy Samba Member
Posted: Tue Aug 25, 2015 4:47 pm Post subject: |
Drowning the internals of the booster with hydrocarbons isn't a good idea, some of the rubber parts don't like it. But if the previous master already filled it with brake fluid don't get your hopes up that it'll magically heal itself, that stuff corrodes exposed steel parts like the valve faces and seats in there. If it's slow coming up try disconnecting the line from the engine (plug the engine end and expect more foot effort to stop), if it stops dragging on the return you may have found the issue. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 25, 2015 5:06 pm Post subject: |
busdaddy wrote: |
Drowning the internals of the booster with hydrocarbons isn't a good idea, some of the rubber parts don't like it. But if the previous master already filled it with brake fluid don't get your hopes up that it'll magically heal itself, that stuff corrodes exposed steel parts like the valve faces and seats in there. If it's slow coming up try disconnecting the line from the engine (plug the engine end and expect more foot effort to stop), if it stops dragging on the return you may have found the issue. |
The poster I quoted said he used silicone lube. I know solvents are bad, and I cleaned the booster out with alcohol both times I had it apart. Is silicone also bad for the internals? _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Tue Aug 25, 2015 5:16 pm Post subject: |
No, silicone should be OK unless one of the propellants or solvents in it hurts the rubber. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 27, 2015 5:52 am Post subject: |
I looked at several cans of silicone spray at the store yesterday and all but one warned of containing petroleum distillates---the WD-40 brand did not. So I bought that. It did seem to quiet the squealing speedometer in my Thing.
I sprayed it into the front of the boot this morning and worked the pedal from below. It seemed like maybe it was working slightly better/easier... There is a very defined catch as the pedal goes down, and also as the pedal returns. It'll go past the catch as you press the pedal, but the catch is there.
I guess I'll wait and see if the silicone works its way in there a little and frees things up or not.
While I was under the bus, a little kid walking to school stopped and said hi. He said he liked my VWs and he was going to save to buy one when he was 18. He said he was 7, so I told him he'd have time to save! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Egan Custom Guitars Samba Member
Posted: Sun Aug 30, 2015 8:29 pm Post subject: |
I am right now trying to diagnose the exact same problem on my 77 Bay window. I'm very interested to see how you make out with this, I peeled the boot back tonight but realized I do not have silicone spray, so I will wait until tomorrow. |
Posted: Sun Aug 30, 2015 8:41 pm Post subject: |
Oh man, not what I was hoping to hear. I am trying to avoid buying a new booster. |
Posted: Sun Aug 30, 2015 8:48 pm Post subject: |
Do you hear the idle on the engine change when you get past that "notchy" point? Have you tried driving the van? My brakes basically go 1-2-10 in terms of reaction time when pushing the pedal down. |
Posted: Mon Oct 12, 2015 11:21 am Post subject: |
So the silicone lube seems to have worked.
I sprayed some one last time before reinstalling the splash pan (didn't really need to be removed to do this, but I also lubed the linkage up front) into the boot where the rod goes into the booster.
At that time, I noted the return most of the way was pretty good, but there was a little bit of a notchyness for the last 1/4 inch or so of travel.
Today I was driving the bus and tested it a bit, and even now that last bit of notchyness seems to be gone and it seems to be working a-ok.
Hopefully the "fix" will last! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Oct 12, 2015 7:58 pm Post subject: |
Don't forget to clean the filter in the front section of the booster as described in the Bentley manual. It provides the atmospheric air (pressure) to release the vacuum boost.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sat Feb 13, 2016 9:55 pm Post subject: Re: Non-returning or sticky brake pedal |
Hey vwwestyman....are you able to give a description of where you were spraying the silicone lube into? Or even a picture?
Thanks! |
