dewbie Samba Member
Posted: Wed Aug 12, 2015 3:33 pm Post subject: 63 Beetle Hood Molding question |
I need help with Hood Molding on 63 Beetle. Purchased SS kit and all fit fine, but cannot get the hood molding to fit, the clips will fall out on each edge do I have to soder these in to make it fit? Or am I missing something? Thanks |
vwnut1 Samba Member
Posted: Wed Aug 12, 2015 4:23 pm Post subject: |
No soldering necessary! Is the new moulding German or Brazilian made? Did you purchase new GERMAN replacement clips? _________________ 1957 VW Oval Resto Mod |
dewbie Samba Member
Posted: Wed Aug 12, 2015 6:32 pm Post subject: |
vwnut1,
Thanks for responding, Actually I have no idea if they are German or Brazilian. Clips and molding kit was in package that came with car when I purchased car there were a lot of "extras" some old and some new. Just getting around to putting them on, and found that problem...didn't know exactly how to get around it. Sorry Love VW's just am a newbie at restoration...trying to do it all myself All I know is I seen Stainless Steel on the package and the correct year for the car "63.. Thanks for any help. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Aug 12, 2015 7:37 pm Post subject: |
The clips slide in the molding, you have to position them into the grommet on the hood one at a time and work your way from top to bottom...
Do you have the rubber grommets inserted into holes in the hood? |
dewbie Samba Member
Posted: Thu Aug 13, 2015 8:23 am Post subject: |
Yes I do have the rubber grommets, and I have done all the other moldings on the car with no problem. This one however on each end where the clips would go, they fall out of the molding, like the molding just reaches the hole from the handle in the hood to the hole before the emblem on the top of the hood, and you have to place the clips at the very end, but they do not have the over hang on the molding to hold them in..... hard to explain I guess unless you have experienced it or I am not using the correct terminology... |
turbotype1 Samba Member
Posted: Thu Aug 13, 2015 9:01 am Post subject: |
Could it be that the moulding is the shorter earlier one for cars with a hood crest above the handle? That might explain why the ends are "open" so the clips won't stay in..... ???
Just a thought _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
vwnut1 Samba Member
Posted: Thu Aug 13, 2015 10:57 am Post subject: |
Without seeing a photo I would say that your new SS hood moulding is defective and would contact the retailer for a replacement. Best of luck and keep us posted. _________________ 1957 VW Oval Resto Mod |
dewbie Samba Member
Posted: Thu Aug 13, 2015 2:50 pm Post subject: |
Thanks for all the input, and I was thinking the same thing on the shortness of it, and did call a couple distributors that sell these, and seemed that what I had was the correct size. So went to a local body shop just to see if there was a suggestion I had not thought of, and there was, and I was not sure I wanted to do it, but I did and it worked just fine. I placed molding on car and took measurements to where the "clip" would still clip into the molding, and just drilled a new hole there, which was just under the original hole, I did this on top and bottom hole only. That way the ending of the chrome molding still went over the original holes and I put the rubber grommets in the holes also to keep rain out. Didn't really want to do it this way, but it worked fine and put a smile on my face! Its nice to get something done been working on this for about 6 years now. Work in progress. Thanks for the help.
txoval Samba Member
Posted: Thu Aug 13, 2015 7:38 pm Post subject: |
I would have loved to see pictures, I've installed hood trim on all 7 rebuilds I have done. At the ends of the molding, there should be a small area without a "lip" so that you can slide the clips into the molding. Yes, the clips move freely back and forth once under that lip. You then carefully slide the clips one at a time starting at the top (or bottom) to the position of the grommet and push it in...then slide the next clip into position and push it in the grommet...repeat until done.
Is it an after market hood? Maybe the holes are in the wrong place?
Glad you got it done though |
dewbie Samba Member
Posted: Thu Aug 13, 2015 7:53 pm Post subject: |
"lip" that's the word I was looking for! I am sure this is an original hood to the car. Not sure where the trim was from was just purchased along with the car. Like I said all other trim went in perfect. the hood trim overlapped the top and bottom holes just 1/16 inch, so with no lip at each end of the trim for about an inch, I had no idea how else to get this on. Not the best way, but for me, it worked and the closer I get to getting this all done to drive I am happy. |
Vdubluver Samba Member
Joined: January 14, 2012 Posts: 199 Location: Springfield, Mo
Posted: Thu Nov 26, 2015 11:07 am Post subject: Re: 63 Beetle Hood Molding question |
Does anyone know where I can get quality hood molding clips for a 66?I see that WW sells a kit with 36 but I only need the hood clips.
Have I missed the "hood molding clip kit"? I know that they are generally a good company to do business with and the things they sell have always been a good fit. I just don't need that many clips. Thanks for any info |
*Darren Samba Member
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Thu Nov 26, 2015 12:53 pm Post subject: Re: 63 Beetle Hood Molding question |
Vdubluver wrote: |
Doubt you are going to find anyone that sells them individually. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Nov 26, 2015 2:08 pm Post subject: Re: 63 Beetle Hood Molding question |
Vdubluver wrote: |
I had to read this twice to make sure I wasn't witness to the cheapest beetle guy ever. Turns out I am. _________________
EverettB wrote: |
FU#5 |
Posted: Thu Nov 26, 2015 3:41 pm Post subject: Re: 63 Beetle Hood Molding question |
hitest wrote: |
Vdubluver wrote: |
I had to read this twice to make sure I wasn't witness to the cheapest beetle guy ever. Turns out I am. |
I missed/misread that part. Wow, spend the $10 already. |
