Deh Shark Samba Member
Joined: December 09, 2006 Posts: 704 Location: U.S. Virgin Islands
Posted: Thu Aug 13, 2015 7:05 pm Post subject: 48 ida Carbs Jettings for 2387cc |
Hey Fellas!! I know that jetting for 48IDA carbs over the internet is not the way forward, but I was wondering if with the experience you have or those that have 2387cc motor with 48 IDAs.
You could give me the most popular jetting sizes for 48 IDAs with 3rd progression hole, F7 emulsion tube 160 and the idle jet 70 and 120. Street/strip 2387cc. Tropical weather with 20 to 400 feet above sea level. I'd start the timing at idle to start at 8 degrees BTDC. 10 to 1 static compression. 2inch Merged Header System
Going in a Dune Buggy.
But here is my engine specs.
86mm forged crank and flywheel wedge-mated
94mm pistons w/ valve pockets
webcam 226 camshaft
226 webcam has a 304º 278º 0.610" 15.49 108º
webcam lifters
straight cut gears
CB 5.7 H-beam rods
1.4 ratio rocker arms
Superflow heads w/ 44 x 37.5, Match ported Manifold. Ported heads.
High volume full flow oil pump 30mm
Aluminum case w/ center shuffle pins
racer spacer
Berg valve cover adapters
Chromoly push rods
Chromoly head studs(1/2 in longer)
Scat spring loaded push-rod tubes (would prefer JayCee's)
Hardned lash caps
JC long barrels
.060 copper head shims
Thanks!! _________________ AH TIYAD AH DAT DEH BAI!!!
Organize folks are just to lazy to look for stuff!!
55 3 fold Ragtop
Manx Dune buggy 2387cc |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Aug 13, 2015 11:33 pm Post subject: |
I'm running 60/110 165/200 40 vents and f2s. This should be very close starting point. The difference will be your vents and alternatively your mains. I love your rims. Careful with the scat spring tubes. I couldn't get them not to leak. Spring for the jaycees. Do it right the first time or get empi SS Windage tubes. Make sure you hold on to your hair and buckle up. That thing is so light with that much motor, you're going to the moon sir. A wheelie bar might be a good idea too w/ lights... _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Fri Aug 14, 2015 5:36 am Post subject: |
Thanks a lot for the response jfats808. I do appreciate the kind comments. I can definitely try that 60/110 165/200 40 vents and f2s set up. & see how that works out. Also.. Jaycee spring loaded tube I will get for sure. I'm just learning the 48IDAs also this is my first big motor. It was built in 2009 but I never ran it. Just getting couple more parts for it first start up in a month or so. _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Fri Aug 14, 2015 1:28 pm Post subject: |
Thanks roachdub58!! I got this color off of a Porsche. I got a build thread in the dune buggy section. US Virgin Islands Manx _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
maui Samba Member
Posted: Sun Aug 23, 2015 10:59 pm Post subject: |
42 vents. 165m 200a F7. 70 idle = race. 170m 200a F2 70 idle street. All at sea level. |
Posted: Mon Aug 24, 2015 5:47 am Post subject: |
Thanks alot Maui! I will def try that. Motor is almost completed. Just need a few more stuff _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
quii Samba Member
Posted: Mon Aug 24, 2015 6:34 am Post subject: |
With the 3rd progression hole, I'd say you probably could stick with a 55 or 60 idle jet.
I ran 65 idles myself, but that's with E85 (requires ~35% more fuel)
IIRC the "rule of thumb" is 4.1-4.3x venturi size for main jet, so I'd say 165-170 mains should be a good start, but every engine is different. |
Posted: Mon Aug 24, 2015 4:44 pm Post subject: |
I never knew the formula Quii! U gotta put me up to speed on that. _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Aug 24, 2015 8:58 pm Post subject: Web 226 |
Keep an eye on your valve train and guides! The Web 226 is a violent, pointy camshaft.
I tried using it for two years and then yanked it out. I couldn't find very many who had experience with it (when I decided to try it), but after posting my poor results, others contacted me with similar experiences.
I echo the jetting comments above...I switched from F7 to F2 and got a smoother driving experience with the larger vents. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Mon Aug 24, 2015 9:08 pm Post subject: |
Neil68 thanks for your suggestions regarding the Web 226. You said it was violent. In what kind of way? I thought it would be kind of similar to a FK8. _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
neil68 Samba Member
Posted: Mon Aug 24, 2015 10:42 pm Post subject: Web 226 vs Engle FK8 |
I've also used the FK8. It's a much smoother cam that is a nice street cam with some racing capability when you want to accelerate.
Engle FK8: 258 deg (0.050"), 298 deg running, 0.382" lift (lobe), smooth lobe.
Web 226: 278 deg (0.050"), 304 deg running, 0.407" lift (lobe), pointy lobe. _________________ Neil.
quii Samba Member
Posted: Mon Aug 24, 2015 11:21 pm Post subject: |
Deh Shark wrote: |
I never knew the formula Quii! U gotta put me up to speed on that. |
I have it from here - this article really helped me to dial in my carbs. Nice read.
http://www.aircooled.net/vw-carburetors-jetting-102/
My carbs on normal petrol (99 octane) needed 185 main jets (44mm venturi * 4.3 = 185). And that worked perfectly - the AFR on the Wideband gauge was spot on. Think I ended on 225 for E85, but that's another story, as E85 requires more fuel. |
vwsb74 Samba Member
Posted: Tue Aug 25, 2015 10:18 am Post subject: |
jfats808 wrote: |
I'm running 60/110 165/200 40 vents and f2s. This should be very close starting point. The difference will be your vents and alternatively your mains. I love your rims. Careful with the scat spring tubes. I couldn't get them not to leak. Spring for the jaycees. Do it right the first time or get empi SS Windage tubes. Make sure you hold on to your hair and buckle up. That thing is so light with that much motor, you're going to the moon sir. A wheelie bar might be a good idea too w/ lights... |
I'm running 110/60 idles 155mains 200airs 37 vent . Slightly lean . You think I should go 100holders? _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Tue Aug 25, 2015 10:43 am Post subject: |
Lean where? Be specific. What emulsions. _________________ 2276 IDA's 86C 11-1 DD !
vwsb74 Samba Member
Posted: Tue Aug 25, 2015 11:29 am Post subject: |
jfats808 wrote: |
Lean where? Be specific. What emulsions. |
Sorry I thought it's clear since I asked about idle holder . Lean at idle. Before transition. I can cover the tiny bit of hesitation if I go 120/65 idles but too rich. _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
Posted: Tue Aug 25, 2015 1:18 pm Post subject: |
Try it. _________________ 2276 IDA's 86C 11-1 DD !
Posted: Tue Aug 25, 2015 4:25 pm Post subject: |
Good info fellas.. I got one more Question... Can a Part# 2008 Magnaspark II distributor works with a 6AL Digital MSD Box?? CB is out of the 2007 Magnspark II Distributor.
Thanks.. _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Wed Aug 26, 2015 7:56 am Post subject: |
Hi CB no longer will stock the 2007, only the 2008, yes you can run the 2008 directly to any CD box, the wire that went to the negative side of a coil from the 2008 will go to the points trigger input on the CD box.
Or alternatively you can remove the igniter module from the CB 2008 Distributor and you will have a straight magnetic pickup which was the CB 2007. ( the wire with the orange stripe from the magnetic pickup is the positive )
I would probably wire it as a 2008, that way if your CD box ever craps out its easy to go back to direct to coil.
Cheers |
Posted: Wed Aug 26, 2015 3:29 pm Post subject: |
Thanks alot Kroc. I guess I will get the #2008 from CB. I was leaning on just getting the good ole 8485 MSD Distributor & call it a day. But that thing is still kinda pricey. But I just want to plug n play style of Dizzy to the 6AL Digital MSD Box. _________________ AH TIYAD AH DAT DEH BAI!!!
55 3 fold Ragtop
