RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Fri Aug 14, 2015 8:18 am Post subject: Arco is top tier fuel? |
Anyone using it in an Air cooled? Been using Union 76 or Chevron and have stayed away from Arco because of the cost. Cheap gas meant cheap additives. Its like 25cents cheaper than 76/Chevron is right now. Years ago I used it but was advised that it didn't have a very good "package" incorporated into it and 76/Chevron would be a better choice due to the fact they went above and beyond what the Government requirements were. |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Fri Aug 14, 2015 8:44 am Post subject: |
I got a tank of Arco gas in Hoquiam OR on our trip last month and had problems right away ended up changing the fuel filter out. The only Arco gas I got on the trip. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
insyncro Banned
Posted: Fri Aug 14, 2015 9:05 am Post subject: |
Stewart's 91 E free is all I run now.
They purchase it in Canada where they don't require ethanol in the mix.
Really good stuff and you feel the difference immediately, plus when idling it is smooth as silk.
Real Gas |
Terry Kay Banned
Posted: Fri Aug 14, 2015 9:13 am Post subject: |
This is all that I use--right from a pump--
Sunoco® 260 GTX™ is an unleaded racing fuel that contains no oxygenates and no metallic additives. 260 GTX is a good fuel for many applications that need more detonation protection than typical street gas provides, yet cannot use a leaded fuel. It has been shown to produce repeatable power levels in small block V8 engines to 12:1 compression ratio, and will tolerate more compression in engines with smaller or more efficient combustion chambers. Turbocharged and supercharged race cars that require an unleaded fuel are good candidates for Sunoco 260 GTX.
When Sinclair / then became Arco was around here in the Midwest it was decent fuel--don't know what happened to it when it got out west --
_________________ T.K.
insyncro Banned
Posted: Fri Aug 14, 2015 9:20 am Post subject: |
TK, I used to run Sunoco Race Fuel when I worked at the track.
ELF before that.
Now we have to buy 55gallon barrels so we get oxygenated 112 and mix it with the 91 E free to make a road mix.
Mostly for the 2 strokes and race machines we have, but plenty gets sent through a Van, WBX and Subaru engines. |
RCB Samba Member
Posted: Fri Aug 14, 2015 9:22 am Post subject: |
Terry Kay wrote: |
Sunoco® 260 GTX™ is an unleaded racing fuel that contains no oxygenates and no metallic additives. 260 GTX is a good fuel for many applications that need more detonation protection than typical street gas provides, yet cannot use a leaded fuel. It has been shown to produce repeatable power levels in small block V8 engines to 12:1 compression ratio, and will tolerate more compression in engines with smaller or more efficient combustion chambers. Turbocharged and supercharged race cars that require an unleaded fuel are good candidates for Sunoco 260 GTX. |
As usual TK; that's good to know. Do you have any comments on ARCO fuel?? |
RCB Samba Member
Posted: Fri Aug 14, 2015 9:25 am Post subject: |
Terry Kay wrote: |
Thats swell TK. Any comments/experience with ARCO fuel?? |
Terry Kay Banned
Posted: Fri Aug 14, 2015 9:28 am Post subject: |
Pay attention Bobby---jump back 4-5 posts.
No issues, good gas. _________________ T.K. |
RCB Samba Member
Posted: Fri Aug 14, 2015 9:33 am Post subject: |
seventyfo wrote: |
I got a tank of Arco gas in Hoquiam OR on our trip last month and had problems right away ended up changing the fuel filter out. The only Arco gas I got on the trip. |
THANKS for staying ON topic. This is about ARCO fuel. Was the ARCO you used from an out of the way station ?? Was the fuel filter full of rust ? Do you think the running issues were caused by the fuel ? Trying to get some feedback from people who use ARCO for fuel.
Oil prices are at an all time low yet the pump doesn't realize it. Not long ago gas at my station was $ 2.99 a gallon and now with lower oil prices its $ 3.45 a gallon. Big difference..no?
I know California has different blends and all, but those who actually use ARCO ( the topic of my posting ) are welcome to chime in if they use ARCO as fuel for their Vanagon. |
Terry Kay Banned
Posted: Fri Aug 14, 2015 9:34 am Post subject: |
"POWER TO USE, NOT ABUSE"
Bobby,
Could have been the gas station who is selling the gas.
I've gotten bad loads of gas in my days, from some obscure stations out in BFE.
Anything is possible.
Or are you saying that all of the Arco gas from every station is all bad? _________________ T.K.
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Aug 14, 2015 9:37 am Post subject: |
RCB,
I use mostly Chevron/Texaco.. 76 and Shell.
An occasional tank of ARCO is fine. And I doubt you'd have issues even if you used it ALL the time.
A chemical engineer (in my family) who works for a major refinery here.. says most all gas sold (legally) in CA is fine since its all formulated to meet the strict CalEPA seasonal standards.
However, the varying brands have differing cleaners/additives and Rolf (now retired SF Vanangon go-to mechanic) always recommended a good HWY run to clean out injectors now and then.. and/or some Lucas or other "injector cleaner" run in every 4th or 5th tank.
Cheers,
j _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Terry Kay Banned
Posted: Fri Aug 14, 2015 9:39 am Post subject: |
Marathon gasoline is good stuff.
They add Chevron Textron to their fuel--never had any issues with it. _________________ T.K. |
insyncro Banned
Posted: Fri Aug 14, 2015 10:17 am Post subject: |
RCB wrote: |
insyncro wrote: |
Real Gas |
So...no comments/experience with ARCO fuel?? |
Sunoco is better, my opinion.
Plus, my Sunoco Fuel rep lives 15minutes from my shop and delivers |
Tully Mars Samba Member
Joined: November 30, 2006 Posts: 93 Location: Wheat Ridge CO
Posted: Fri Aug 14, 2015 11:19 am Post subject: Arco is top tier fuel ?? |
I run Arco quite often and have never had a problem. Burn the Costco stuff too. Is there better gasoline in SoCal for a Vanagon? Don't know. But I am not paying 50 cents per gallon extra for Chevron gasoline. _________________ I'm a man. But I can change.
If I have to.
I guess.
_______
84 Wolfsburg Westfalia
Hobie Cow |
Terry Kay Banned
Posted: Fri Aug 14, 2015 11:57 am Post subject: |
Bob,
Is it one Arco station selling you bad gas, or all of them in your surrounding area?
If the answer us one, go to another and see what happens. _________________ T.K. |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Fri Aug 14, 2015 12:14 pm Post subject: |
We have been using Arco gas for several years now for our fleet vehicles. There seems to be an Arco on every corner in SoCal, with 6 Arco's within two miles of my office. Prior to switching, we used Shell. When we ran Shell fuel, our trucks had zero fuel related issues, other than the occasional fuel filter due to high miles. For the record, each of our 15 trucks typically runs through 50-70 gallons of fuel in a week, purchased from random Arco stations throughout the Los Angeles / San Diego / Inland Empire area
After switching to Arco, 2/3rds of our trucks have had fuel issues, bucking, stalling, loss of power, etc, with no respect to the age of the vehicle. One Transit Connect Van, with less than 40,000 miles on it, was diagnosed by the dealer as having a bad throttle body, by another mechanic as having a bad computer. I brought it back to the office and treated two tanks of fuel with Marvel Mystery Oil. Symptoms completely disappeared, power was restored... for the next 10,000 miles. We now treat all vehicles to a tank of MMO fuel every month. In my own work truck, I stop at Shell or Chevron every fifth tank or so.
In my wifes Tiguan, she swears it runs worse with Arco gas. We normally use Shell or Chevron in it. My 1.8t in the Vanagon doesn't seem to care either way, but based on our fleet experience, I typically only use Arco for the occasional fill up.
YMMV...Anecdotal at best...That's what she said... _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Fri Aug 14, 2015 10:35 pm Post subject: |
Not to be the country bumpkin here, or anything, but I usually use what's cheapest. Even in my aircooled (1964 forty horse bug - admittedly, not a Vanagon), it has never given me a problem.
I have to admit, I don't know if my vehicles would work better if I used more expensive gas.
Chuey |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Fri Aug 14, 2015 11:32 pm Post subject: |
Multiple cars and no problems with arco, including my 68. Every out of town I run a bottle of injector cleaner/fuel system cleaner though. Most of the family uses it too. _________________ Stupid people do stupid things. |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Sat Aug 15, 2015 6:18 am Post subject: |
Arco is fine, quit stressing. Any stories of bad gas are due to the station, not the refinery.
I don't use Arco anymore because of their stupid central payment kiosk thing. I really don't want to wait in line behind the dirtbag trying to stuff wadded up singles into the machine so he can get 3.00 worth of regular to get to the crack house.
but the gas is fine man, no worries. My has car has had hundreds of gallons of that stuff run through it with zero issues. Also Terrible Herbst, Costco, various no name middle of nowhere gas station gas, etc.
It's not a Bugatti Veyron, it's a low compression engine that'll run on goat piss if it has to. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Sat Aug 15, 2015 9:16 am Post subject: Arco is top tier fuel? |
I would not consider Arco a top tier fuel. Same with Valero. I only run 76, Chevron or Shell in all my cars and my air cooled ones get an occasional shot of Marvel Mystery Oil as well. The cars run as well as can be expected on CA's ethanol laced crap gas. I've heard good things about Costco gas but since I'm not a member I cannot personally vouch for it. |
