sweetlemon63 Samba Member
Joined: November 30, 2008 Posts: 13 Location: fontana, califonia
Posted: Sat Aug 15, 2015 8:00 pm Post subject: Touareg problems |
i was test driving a 04 touareg v8, it would not go over 45 mph, even the dealer couldn't figure it out. what could have it been. really clean car everything was great but that. i was really close to buying but didn't please help thanks. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sat Aug 15, 2015 8:16 pm Post subject: |
Walking away from it was the best thing you could have done, your wallet thanks you. There's a reason the dealers pet name for them is "toe tag". _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
jmartin7 Samba Member
Joined: March 03, 2011 Posts: 213 Location: Memphis,Tennessee
Posted: Mon Aug 17, 2015 12:08 am Post subject: |
I am going to assume that the transmission was shifting, but it just would not accelerate past 45. I bet there where a lot of trouble codes even if there where no warning lights. Modern water-cooled VWs will go into what is known as limp mode if certain issues are detected by the ecu. Anyone looking at a newer VW that is out of warranty should bring a VW specific obd2 scanner to check for codes and emission readiness. One of these scan tools such as a Vgate VS450 can be found online for about $40. A generic odb2 scanner might pull trouble codes but a quick check of the emission readiness will determine if the codes had just been reset before your test drive. It takes several key cycles without trouble codes for it to past an emission readiness test. |
scirocco81 Samba Member
Posted: Tue Sep 15, 2015 7:29 pm Post subject: |
The dealer knows and told the car lot exactly whats wrong with the car and its probably either catastrophic or prohibitively expensive to repair. Theyre hedging their bet you'll buy the car anyway hoping its an "easy fix".
Hard to believe the instrument cluster and MFI weren't going off like fireworks. |
