sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Mon Aug 17, 2015 7:38 am Post subject: Big Sur trip & Hard start when left hot |
My Thingster has a minor problem. If I have been driving for a while and everything is up to temperature. it is difficult to start.
If I leave it for a few hours it starts right away on the first turn.
I initially thought an electric fuel pump, maybe the gas had evaporated out of my twin Weber 40's, but that can't be right or it would not start easily a few hours later.
The other thought is a coil, but when it starts it runs great.
How do I check the coil , or do I just put in a new one?
PS Coming back from camping at Big Sur last weekend through King City, where it was 112.3 F, my oil went up to 240 F so I slowed down to 60 in the 70 limit part of US 101, it then can down to under 220 F.
I guess that driving in the heat with a bikini top is not great for people and Things. _________________ 63 singlecab
73 thingster
74 Thing
Semper_Dad Samba Member
Posted: Mon Aug 17, 2015 8:20 am Post subject: |
Most likely the coil. As the coil gets hotter, the windings expand and possibly develop "opens". As things cool down, windings reconnect. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
sam_w Samba Member
Posted: Mon Aug 17, 2015 8:37 am Post subject: |
I will get a new coil, but once it starts it runs really well, so does the hot coil work well when the engine is running? _________________ 63 singlecab
73 thingster
74 Thing |
sam_w Samba Member
Posted: Mon Aug 17, 2015 9:22 am Post subject: |
We had a great time with our little San Jose VW group, the group campground at Plaskett Creek campground was booked a year in advance,
Solomon Grundy & I drove up to the ridge behind the campground and had a great view, I was happy with the bumpy ride.
73 thingster
74 Thing |
Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Mon Aug 17, 2015 9:51 am Post subject: |
Very nice! love Big Sur and its windy days. Back in the Air Force days I got to visit there often. _________________ Change is Opportunity!
Instagram=metaltwister |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 377 Location: Victorville
Posted: Mon Aug 17, 2015 10:42 am Post subject: |
Looks like a lot of fun have spent a lot of time in Big Sur. My best memory was when we rode our bicycles from San Fran to LA we camped over night just below the long grade from the camp ground. that was a fun first thing to do in the morning.
GB |
Schwankster Samba Member
Joined: January 07, 2011 Posts: 65 Location: San Antonio, Texas
Posted: Tue Aug 18, 2015 12:11 pm Post subject: |
My Thing has the same issue. I've got the stock engine, carb, distributor, & coil. It will start almost the instant the key is turned when it is cold (after I first pump the gas pedal three times), but when it is hot from driving for a while it is more of a challenge to start. It usually happens after I have stopped for 10-20 minutes or more. If I just shut it off, run into a store and come back out within a few minutes it'll start right up. If I shut it off for a little while (lunch, shopping, etc) it doesn't want to start with just a quick turn of the key.
I found that when I crank it (when hot) and it doesn't start in a second or two, I put the gas pedal to the floor and keep cranking. It will usually start in another few seconds when I do that. As soon as the engine starts I let off of the gas pedal and everything is fine. It has been doing that since I bought it a few years ago, and it took me a while to figure out what worked to get it to start when it is hot. |
Posted: Tue Aug 18, 2015 12:45 pm Post subject: |
We have found that here in the High Desert of CA that most of the time it is vapor locking. The fuel boils out of the carb. I have an electric fuel pump on my 74 and when it is hot I just turn the ignition on and let the pump run for a couple of seconds and the car starts right up but not as fast as when it is cold. One trick we used many years ago was to put wooden cloths pins on the metal line that comes through the back of the engine about 3 were used and it stopped the vapor locking problem. It works as I saw many VWs cured when I used to work in a VW only shop. I have a rubber line coming through the back on my 74. My 73 has no problem when it is hot but has a complete new fuel system from tank to carb.
GB |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Wed Aug 19, 2015 10:50 am Post subject: same problem here with hot re-start |
Hi Sam, (and the rest)
I too have this problem, even with a replacement carb, on long runs,
cut engine off, let it sit for 10m to 3hrs, you have to floor it to start.
if it sits overnight, starts without touching the gas pedal.
One of our "Thing Brothers" from West Va was disscussing this same issue with me at Kubeltrefen in Ohio a few weeks back,
he mentioned (having his carb worked on I belive) but the carb's float setting (needing to be set with shimmed washers), that an old vw guy he knows pulled his carb and distributor apart and cleaned readjusted/assembled them and it fixed his problem.
But it sounded like this "hot start issue" leaned more toward being related to the carb/float shim setting.
i've also heard the heat riser tubes for heating the carb can get stopped up and can cause similar issues (but more like icing while running).
I have no personal experience with this shim adjustment for the float in the carb. (other than this show discussion)
Anyone know/heard bout that one?
sure seems to be a common problem and one I'd love to fix myself!
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
sam_w Samba Member
Posted: Wed Aug 19, 2015 10:56 am Post subject: |
I have gotten a new Bosch high energy ignition coil, to install, and will try the clothes pins on the fuel line.
After that I will try an electric fuel pump, I have been recommended the CBPerformance one. Any comments?
I think I will leave the current coil in place and add the second coil as I have seen in some off-road vehicles. _________________ 63 singlecab
73 thingster
74 Thing |
apba12m Samba Member
Joined: November 08, 2011 Posts: 76 Location: michigan
Posted: Wed Aug 19, 2015 6:18 pm Post subject: |
I also had this problem right after I bought the thing. I replaced the coil, carb, plugs, e.c.t. nothing fixed it.. pulled the motor and found the cooling fins on the heads plugged with dried mud and bottom tins missing. replaced the pistons and cylinders and rebuilt the motor. the motor now runs like a watch and starts all the time no problem.. |
Solomon Grundy Samba Member
Joined: December 26, 2004 Posts: 746 Location: Silicon Valley
Posted: Sat Aug 22, 2015 7:31 am Post subject: nice |
Nice photos! I bet that was a nice drive.
also, this talk about the hard "hot start" issue got me digging again.
Rob and Dave' Vw page has a bunch of stuff on there about this issue, but it sounds like it can be a multitude of issues.
2 articles grabbed me at first:
Solving overheating problems
and
Vapor lock
(my search link below)
http://www.vw-resource.com/vw-resource.com_non_ssl...oom_sort=0
The things that grabbed my attention reading the articles was:
ethanol fuel and it's tend to cause a lean running issue, which causes excess heat, they mentioned changing the jetting to help fix this(on pict 30/32 and pict 34 carbs)
and
for engines with 1 carb the heat risers being too hot and essentially boiling out the gas from the carb.
I learned about hot heat risers, I watched a buddy of mine say hmm, what's this pipe here for and proceeded to touch it when hot and promptly removed his fingerprints from his finger! Ouch!!
In my case after a 30m+ drive, my THING may not start with 1 turn of the key like she usually does when cool, I have to floor it, crank it and watch a plume of smoke roll out.
I've noticed upon getting home after a drive if I pop the hood, let it sit for 30+ min, it usually starts right up to go in the garage.
Question, if finding the exact culprit causing this hot start issue proves to be a challenge,
any thoughts on a electric fan of some sort to either blow in cool air or blow out heat from the engine bay?
reason I mentioned that is in my "tests" of the redneck air conditioner using a cooler, I bought a "bilge pump fan" from wal mart of all places, it's a 125cfm fan 12v for hooking into 3inch tubing for air flow for boat bilges, I've also read of some hot rod guys using them for carb cooling for this very issue.
Thoughts/ suggestions anyone?
my thoughts (for my THING) is this,
possible heat risers are too hot
carb jetting too lean
engine rubber seal does have a few bad spots but I wouldn't think they are bad enough to cause this issue.
rebuilt volkzbitz pict 34 carb, single vac can dizzy (new)
Timing off (could be too advanced?)
other than this hard start issue when hot it seems to run fine.
Although from Kubeltreffen it also seems I have the SLOWEST thing in the bunch, ALL you guys left me in the dust!
Anywho, thanks for the photos guys very nice and this is a good discussion about hot starts!
T
PS: More digging on Rob and Dave's vw page, on rebuilding the pict 34 carb, I bet this is what the fellow at Kubeltreffen was trying to explain...
http://vw-resource.com/carb_41.html
The proper float valve washer must be used for the specific type of carburetor. The 34 PICT/3 carburetor uses the 0.5 mm (.020") gasket. A micrometer helps to make the distinction.
Note: It is very important that you install the correct needle seat gasket. This gasket sets the fuel height in the float bowl; erratic behavior may result if the gasket is not correct. _________________ ****************************************
1973 - Thing
sam_w Samba Member
Posted: Sat Aug 22, 2015 8:57 am Post subject: |
Nice post Doublecannister,
I unfortunately have a 2054cc motor with Weber 40's, so the heat riser is not an issue.
BTW driving up the dirt road hill with greater than 10% grade in first, I just went perfectly in first gear between 2000 AND 4000 rpm. I am really happy with my torquey stroker motor.
I don't think the fuel can have evaporated out of the carbs or it wouldn't start first turn next morning.
I am doing 2 things before my next trip,
1) add new Bosch High Energy coil
2) add clothes pins to the fuel line ( I don't know why this is meant to work, but I have read about it.
I hope to to the trip to KTE again, maybe 2016. _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Sat Aug 22, 2015 11:50 am Post subject: |
sam_w wrote: |
I hope to to the trip to KTE again, maybe 2016. |
Hey Sam,
Yeah you are way different from a stock setup, but figured something may jar a memory or a suggestion from someone.
This seems to be a common issue among the threads I've read for the ones that have the problem, it's been a laundry list of items that can cause or fix it.
sorry you didn't make KTE this year, I was NOT feeling my best at this event, I had been 2 days severely ill prior to going, had a stomach bug or something, came within hours of deciding go-no go. To dern close to call but even feeling like crap I enjoyed seeing old friends and meeting some of our samba buds!
maybe we'll catch ya next time Sam, good luck in your quest to fix this issue.
If I have any luck with mine I'll post if it'd help.
1973 - Thing
bigbussur Samba Member
Joined: January 02, 2007 Posts: 122 Location: Santa Barbara CA
Posted: Mon Aug 24, 2015 12:36 am Post subject: |
I remember I had the hard start issue on both of my buses and I ended up wiring in one of the hot start relays into the starter. Never had the issue again. Lot of heat is built up around those starters. |
carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Mon Aug 24, 2015 11:10 pm Post subject: |
The "clothes-pin" trick has been around for years. The wooden pins absorb heat from the metal fuel line to prevent hot spots that cause the fuel to boil, turning it to "vapor" that "locks" the fuel in the line so it can't flow to the carb. _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
Posted: Mon Aug 24, 2015 11:12 pm Post subject: |
