strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Thu Aug 27, 2015 5:46 am Post subject: |
icemanhd wrote: |
Thanks for the Info strelnik! It did come with a double pulley but the 24V alternator isn't there although I suspect it was there at one time since it has the double pulley. I did get some info from the previous owner that he changed the symbols to what he thought was a mountain division and that the original symbol had the horizontal line with 2 dots at the top and there was an "X" in the box which he understood to be infantry. |
You are absolutely right X across the entire box means infantry, the idea is the line of the X = crossed rifles in simple symbology _________________ L'audace! L'audace! Toujours l'audace! |
Posted: Thu Aug 27, 2015 5:55 am Post subject: |
icemanhd wrote: |
You are absolutely right!! X across the entire box means infantry, the idea is the line of the X = crossed rifles in simple symbology _________________ L'audace! L'audace! Toujours l'audace! |
HUGO bOSS Samba Member
Joined: April 27, 2008 Posts: 2602 Location: Madeira Island - Portugal
Posted: Mon Aug 31, 2015 12:31 pm Post subject: |
icemanhd wrote: |
Finally figured out (thanks to Zeke's help and translation) how to get the light switch into the convoy (covert) mode using the "Notek" convoy lights. See pics below showing conventional nighttime lights and the covert/convoy mode. There are 3 (Hella) convoy lights on the back, when activated you are supposed to be able to see only 1 of them at 75 ft, 2 at 50 ft, and when 25 ft or closer all 3. There are also some downward projecting lights on the front of the car but I think the bulbs for those are out.
I searched and searched onlineand didn't find the "trick" for the lights switch. There is a small button on the shaft of the switch you have to press in (like with a key or small phillips) which allows you to move the lock out from the right side of the switch to the left. Once you do that you can move the switch into the various covert night time modes. The switch itself is shown in figure 49 and 50 in the German Army Manual posted in the manuals section here
http://www.thesamba.com/vw/archives/manuals/1983_1...ge_062.jpg
Great car! Fantastic!
I'm also restoring one from BW... I have looking for several information on the net for several years and found this sometime ago:
http://www.rk-reinstetten.de/berichte/taktische_zeichen/Taktische_Zeichen.pdf
Yours isn't there...
About the rear lights... the midle one should be for the brakes... _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=538182 |
Bugs4Life Samba Member
Joined: February 17, 2007 Posts: 232 Location: Nor-Cal
Posted: Fri Jan 01, 2016 4:04 pm Post subject: Re: 1974 German Army Thing |
Nice find, very few of these in the States, and hard to find parts for them. I ship a lot of parts in from Germany for mine. Let me know if you are looking for anything. Also try sending away for it's Birth Certificate. It took me little more than 10 months to get mine, but was worth it.
_________________ 72 181 Ambulance
62 Ghia |
icemanhd Samba Member
Joined: May 07, 2007 Posts: 275 Location: Camano Island, WA
Posted: Tue Jan 12, 2016 1:57 pm Post subject: Re: 1974 German Army Thing |
I'm "in the queue" for the birth certificate, paid for it September 10th last year but understand with their current backlog it could take "up to" 9 months. Lately I have had the thing over at my retired VW mechanic/buddys place to address some minor rust repair on the LH rocker and hit any vulnerable areas with POR 15 for future protection.
Had a minor hunt to track down the replacement bulbs for the headlamps (not sealed beam units like on US spec cars) but after some searching found some Hella H83190001 S11 45/40W Bulbs for $4 each _________________ 71 Drag Ghia
67 Bug, Hot VWs feature car
68 912
76 912E
87 911 Carrera |
Posted: Sat Mar 26, 2016 8:55 am Post subject: Re: 1974 German Army Thing |
Finally, 6.5 months later the birth certificate arrives and confirms the engine is original. Odd-interesting that it showed the car delivered to Germany as "personal" given that it has bundeswehr acquisition stickers on it. Also puzzling on the M85 "doubling of the serially intended gasoline amount" I assume this refers to the auxiliary tank.
68 912
76 912E
87 911 Carrera |
SilverThing Samba Member
Posted: Mon Mar 28, 2016 12:42 pm Post subject: Re: 1974 German Army Thing |
Glad you finally got yours. I'm still waiting on the one for my 1973 Thing.
Yours is certainly puzzling. I would have expected option code M63 to be listed on yours and it is interesting that they list the colors as olive and the destination as personal.
The description on your code M051 is interesting to me. The microfiches I have list 051 as preparation for second alternator. Minor difference, but it makes yours sound like an industrial engine. LOL
M060 and M552 are because yours is a 1974. The military typically ordered them without engine heat, but with a gas heater. Engine heat was standard 1974 and later and the gas heater was optional. Prior to 1974 there was no engine heat available and the gas heater was standard.
M267 is also interesting to me. They call it a motorway radio. In the 181 microfiches I have it is listed as a different final drive ratio (4.375). Check your transmission code for me. I'd be willing to bet it is GA. The option was supposedly discontinued after 1974, but many factory brochures I have in my collection still list the optional final drive ratio.
M085 takes the cake as far as interesting is concerned. I can't find any reference to it in any of my microfiches. The description sounds to me like an enlarged gas tank that is twice as big as normal, but that would be a little bit crazy in a 181. Maybe it is the spare tire can, but that is normally included under M63. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Posted: Wed Mar 30, 2016 6:14 pm Post subject: Re: 1974 German Army Thing |
I did some poking around online and M085 seems to refer to the amount of fuel that VW would put in the fuel tank when it left the factory. The assumption is that this is intended for vehicles that need to be driven for delivery (driven off of a train for example). _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
Posted: Wed Jun 29, 2016 8:21 am Post subject: Re: 1974 German Army Thing |
Thanks to K-mann at Romtoc I have a new Olive Drab top for the German Army Thing putting it back to its original glory. No surprise, it turns out olive drab isn't a popular top color for convertibles. I checked with TMI and several other places, nobody wants a green top......
68 912
76 912E
87 911 Carrera |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 241 Location: St Louis, MO
Posted: Thu Jun 30, 2016 8:55 pm Post subject: Re: 1974 German Army Thing |
SilverThing wrote: |
Take a look at the lower pulley, if it has two grooves instead of one, it is set up for the second generator to generate 24 volts needed for NATO radios. There may also be a bracket to the left of the engine for the second generator. |
Posted: Thu Jun 30, 2016 9:47 pm Post subject: Re: 1974 German Army Thing |
Also, take a look under the left side of the rear seat, there should be a bracket to install a second 12 volt battery, there is one present on my US 1973 Thing, made in Mexico. |
