Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Thu Aug 20, 2015 3:07 pm Post subject: What all is in the tunnel... |
What all runs through the tunnel besides the shifter rod? _________________ Change is Opportunity!
Instagram=metaltwister
Last edited by Metal Twister on Thu Aug 20, 2015 4:56 pm; edited 1 time in total |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2765 Location: The World's Motor Capital
Posted: Thu Aug 20, 2015 3:58 pm Post subject: |
From the gallery:
Posted: Thu Aug 20, 2015 4:59 pm Post subject: |
A picture is worth a thousand words... Thanks Much! _________________ Change is Opportunity!
Instagram=metaltwister |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Thu Aug 20, 2015 8:05 pm Post subject: |
Very cool! I'm thinking about fitting a bus fuel tank under the back seat with a notch in the tank to clear the tunnel. If I could sneak a 1" round tube low on the tunnel all the way across it, I could then use a nipple on each side of the tank to connect them together using a soft line through the 1" metal tube. By doing that I could use one fuel sending unit and no need for a fuel selector switch from side to side.I would only need a fuel selector switch for the main or aux tank. Thanks for the help and thanks to Capt. Spalding for the inspiration. _________________ Change is Opportunity!
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5680 Location: Manhattan, Kansas, USA
Posted: Fri Aug 21, 2015 5:24 am Post subject: |
Those are cool pics, I clicked the thread because I was mulling over whether coolant lines could run in the tunnel earlier today.
As for the gas tank-I think it'd be easier and you could have higher capacity if you just had it under the rear seat on the driver side. Better yet, have one fabricated to fit the area exactly. It could fill the whole space under the driver side, and potentially extend over the top of the tunnel for a little more space. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Aug 21, 2015 9:03 am Post subject: |
Actually that was my first thought. Build two custom custom tanks that would fit on each side of the tunnel. Having built a good number of fuel tanks I have found it much easier and quicker to modify a tank if one can be found that is close in size. I actually measured the type 2 bus tank. With the 2.5" body lift it will fit very nice under the rear seating area. The filler spout is located on the end of the tank and would make a perfect place to cut in a filler door just below the rear passenger side door. I was just curious where I could sneak a equalization tube from side to side. With the body lift I need to make a couple new seat risers so the battery's will end up under the two front seats. I
