brainwash Samba Member
Posted: Sat Aug 22, 2015 5:07 pm Post subject: Newbie Q: How do I treat this pitting? |
I just wire wheel brushed the rain channels and some of the top of my 78 Westy and have come across some not previously visible pitting. I guess the PO had painted over rust? What should I do here? I've wire wheeled it as much as possible not sure how to treat it.
_________________ '78 Westfalia |
Deutsch Samba Member
Joined: August 07, 2003 Posts: 295 Location: E-town, KY
Posted: Sat Aug 22, 2015 5:25 pm Post subject: |
If its not too deep, I'd paint the pitted metal with PPG epoxy primer. Then apply a thin coat of body filler onto the primer to fill the pits. _________________ The German |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Aug 22, 2015 6:29 pm Post subject: |
Treat all the bare metal with Rust-Prep or similar phosphoric acid rust killer first, before filler or spraying primer etc. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Aug 22, 2015 6:54 pm Post subject: |
Both answers are correct. The best way would be to get a spot blaster and really get that rust cleaned out, then epoxy primer. If you dont have access to a blaster (although if your restoring a car/bus I would get one) then some phosphoric acid before your epoxy. I know it looks like you got all the rust out with the wire wheel, but you didnt. So it needs to be treated first. |
Posted: Sat Aug 22, 2015 8:44 pm Post subject: |
I've got some rust bullet metal blast with phosphoric acid in it. Was told that 4:1 water:vinegar solution would work but plunked down the $20 (pound foolish?).
Will be needing a blaster of some kind soon, but not planning to shoot my whole bus. Wanting to remove as much rust as I casn for now and save up for a professional paint job some day. _________________ '78 Westfalia |
modok Samba Member
Posted: Sun Aug 23, 2015 11:30 am Post subject: |
That is more than clean enough to apply paint. Just paint it!
You'd have to be seven feet tall to see the pitting......so why fix it? |
Posted: Sun Aug 23, 2015 12:54 pm Post subject: |
Don't spend $5000-10,000 on a professional paint job. Paint it yourself for $1000 and you will be able to spot repair/paint it when it gets dinged up. _________________ https://imgur.com/user/FisherSquareback/posts
buguy Samba Member
Posted: Sun Aug 23, 2015 2:33 pm Post subject: |
modok wrote: |
Now punch yourself in the nuts for saying that! |
Posted: Sun Aug 23, 2015 3:16 pm Post subject: |
Mike Fisher wrote: |
Don't spend $5000-10,000 on a professional paint job. Paint it yourself for $1000 and you will be able to spot repair/paint it when it gets dinged up. |
I'm liking the sound of that much better!
I'm new to the body/painting world, but willing to learn! As long as the cash outlay for equipment capital doesn't hit the thousands. And since I've got the roof off and am painting the top and rain channels, may as well remove everything else as well.
In that case, should I just gut it and have it blasted professionally? _________________ '78 Westfalia |
raygreenwood Samba Member
Posted: Sun Aug 23, 2015 7:28 pm Post subject: |
brainwash wrote: |
Will be needing a blaster of some kind soon, but not planning to shoot my whole bus. Wanting to remove as much rust as I casn for now and save up for a professional paint job some day. |
Uh....no. .....water and vinegar will do nothing. It may remove a little rust.....but will NOT produce iron phosphate conversion....which is what phosphoric acid does.
Its nit just the use of a generic acid....jts a specific acid.
Also....for pitting clean it first with small amounts of hydrochloric/muriatic acid. It will dissolve every spec of rust down to bare metal even in the smallest pits.
Rinse it with a small amount of baking soda and water. ...then rinse again with clean water. Lit it sit for a day or two and create a fine layer of surface rust. Then hit it with phosphoric acid to convert that fine layer of rust to iron phosphat.....which is ideal primer.
Phosphoric acid is useless in bare metal. It must have rust to convert.....or it does nothing. The issue is that it, cannot convert what it cannot soak into. It will not, convert rust deeper than .002-.003" thick. So if you first dissolve thick rust then let it flash rust and then treat with phosphoric acid....you know its converted all the way through. Ray |
Posted: Sun Aug 23, 2015 8:19 pm Post subject: |
raygreenwood wrote: |
Thanks for the great advice, Ray! _________________ '78 Westfalia |
benchracer1 Samba Member
Joined: September 24, 2006 Posts: 583 Location: ramona
Posted: Tue Sep 29, 2015 5:29 am Post subject: |
I've heard that muriatic acid can actually change the properties of the metal and make it brittle. Are you talking about very small amounts? ....Steve |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Tue Sep 29, 2015 10:19 am Post subject: |
benchracer1 wrote: |
This is true, but it takes quite a bit of time.
Small amounts. Short exposure.
For small areas, a teaspoon of acid, a few minutes at most. Rinse time. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Tue Sep 29, 2015 10:54 pm Post subject: |
What is considered short exposure |
Posted: Wed Sep 30, 2015 4:03 am Post subject: |
Oops, I see where you said a few minutes at most. |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Sat Oct 03, 2015 2:03 pm Post subject: |
brainwash wrote: |
In that case, should I just gut it and have it blasted professionally? |
How'd it go so fast from treating a few unnoticed/unexpected pitted spots to completely gutting the bus? Maybe I'm just getting old or something. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
buguy Samba Member
Posted: Sun Oct 04, 2015 5:31 pm Post subject: |
If you are restoring the whole thing. Then, yes. Gut it and have it blasted. Its really the only good way to be sure all the rust is gone. |
Jon's62 Samba Member
Posted: Thu Oct 08, 2015 7:50 am Post subject: |
Once the rust was gone, I would spray with high build primer then apply filler (from a pro paint shop supplier, not the cheap stuff). |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Thu Oct 08, 2015 9:52 am Post subject: |
buguy wrote: |
modok wrote: |
haha, I was thinking that. If I was 7 feet tall, wouldn't I be farther away from the pitting? _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
