gin23deluxe Samba Member
Joined: April 18, 2005 Posts: 30 Location: bridgwater, somerset
Posted: Sun Aug 23, 2015 7:56 am Post subject: Help building a Vintage speed style motor |
Hi guys Im looking for advice help on building a vintage speed/okrasa style engine, i have a rag top oval but it has a 58 industrial engine bolt on dynamo stand. although its nippy i ' d like more, i do have a 1776 t/p but its wrong for the car.
The car came with a period correct spare engine, i have also bought an abarth exhaust and a bosch 010 distributor.
I would like to build a big bore engine, 1500 would be ideal
What can i use internally crank rods, cam, barrels&pistons, will later heads fit
I'm not too worried about using non okrasa stuff, if i can retro fit later parts easily enough i would rather that down to cost. I don't have stacks of money spare, so i need bare this in mind.
Any help would greatly be recieved
many thanks mark hopley |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Sun Aug 23, 2015 6:49 pm Post subject: |
I look forward to following your thread.
I also want to build a period correct looking motor for my 54.
With that being said I do believe there are many people who like the vintage hot rod look but are not to worried about using all vintage parts.
It will be very informative to read the advice you receive.
Good luck with your build. _________________ 54 Bug
56 convertible |
GTV Samba Member
Posted: Sun Aug 23, 2015 7:02 pm Post subject: |
FYI a '58 engine has an integrated generator stand. If yours bolts on, it is later. They are completely different, and most parts are not interchangeable between the two.
Post a picture of your engine. _________________ EMPI Power Rules! |
Posted: Mon Aug 24, 2015 1:27 am Post subject: |
Hi yes thanks. I wouldnt break the engine in the car for parts as it was a nos zero mile industrial motor, be sacrilegious to break it, but thanks
Cheers mark |
Posted: Wed Aug 26, 2015 5:19 am Post subject: |
engine code on the engine in the car is 122-222876
spare engine is 1-500698
also has AO 27 stamped lower and
to the side of the pedestal 1577627
anyone help please
mark |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7221 Location: Videbaek Denmark
Posted: Fri Aug 28, 2015 5:44 am Post subject: |
gin23deluxe wrote: |
1200 34 hp
The other number I do not recognize.
Pictures ? |
Posted: Fri Aug 28, 2015 8:42 am Post subject: |
Hi thanks allstrup what year do you think, post 60 I reckon
Cheers mark |
