griffs68 Samba Member
Joined: August 01, 2015 Posts: 47 Location: Bakersfield, CA
Posted: Tue Aug 25, 2015 10:31 pm Post subject: Full engine upgrade plus powder coating. |
Well I guess I jumped into the fire pits.
Pulled my alternator off and apart to powder coat the case/ stand/ fan/ pulleys/ and engine tins.
I would like to go ahead and replace both bearings and the brushes while I have it down.
Only thing is I can not seem to find anywhere that sells internal parts for these things.
I really dont want to go get a reman one and steal the guts out of it.
As for the engine up grade looks like I will be going from a 2180 to a 2276
from dual 44s to dual 48s and from low compression to around 10.5:1
1.4 ratio rocker arms and good cylinders/pistons. and a set of highly modified heads ported to about the max allowed.
will post pictures after a minute |
Dale M. Samba Member
Posted: Wed Aug 26, 2015 4:46 am Post subject: |
As for brushes and bearings check with any specialty automotive (truck) electrical repair shop in your city...
Bearing may also be found at any good industrial bearing supplier...
You have to think outside the "VW parts suppliers" box...
http://lmgtfy.com/?q=bosch+alternator+brushes+replacement
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Wed Aug 26, 2015 12:11 pm Post subject: |
there should be a stamp on the bearings that ought to get you at the least the dimensions. From there you can get any bearing with those dims your heart desires. If I can find seals to fit an old steering box you should be able to do this alt. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
HikFab Samba Member
Joined: December 01, 2013 Posts: 34 Location: Garden Grove
Posted: Wed Aug 26, 2015 5:36 pm Post subject: |
Engine sounds like a real heavy breather
Is it a sand-dune killer? |
Posted: Thu Aug 27, 2015 8:13 am Post subject: |
Yes sir will only be in the sand. Im hoping with this upgrade and some good tuning work to get somewhere around 200 horse to wheels. |
HikFab Samba Member
Posted: Fri Aug 28, 2015 2:51 pm Post subject: |
Looking forward to some pics. |
Posted: Sat Aug 29, 2015 8:10 am Post subject: |
Oh and when alternator powder coating is done, be sure to run ground wire to case.... Power coating is a vinyl base and will insulate alternator case from "stand" and probably will not work without proper ground...
Posted: Sat Aug 29, 2015 6:01 pm Post subject: |
Thanks for the tip dale. I had figured that. I will do both a ground wire and getting a good ground through the case by cleaning off some coating |
Posted: Tue Sep 08, 2015 8:15 pm Post subject: |
Got some of the stuff back from powdercoating.
I think it looks good for a start! |
HikFab Samba Member
Posted: Tue Sep 08, 2015 10:46 pm Post subject: |
Great Start. That looks like a first class powder job. |
Posted: Wed Sep 09, 2015 4:14 pm Post subject: |
300 for blasting and coating and cooking.
I also had alot of chrome pieces that take more to blast. they did what you see plus valve covers, alternator bracket, front arms. |
