no1pony Samba Member
Joined: March 24, 2010 Posts: 82 Location: Dover, Delaware
Posted: Wed Aug 26, 2015 8:12 am Post subject: 78 2.0 FI type 4 distributor orientation + misses/backfires |
Hello, I have done multiple searches and gained a ton of knowledge from this site but I am having an issue with my bus that I need some help with.
Here is some details on my bus and the issues I am having. My bus is a 78 with 2.0 FI still installed. I bought the bus non running and after it sat for many years. I pulled the motor and just did basic clean up, tested fuel injectors, replaced manifold seals ,plugs, wires along with various other parts. The bus' wiring harness was fried from what appeared to be excessive over cranking or shorting out somehow. Harness and ECM have been replaced along with double relay. I have remove and cleaned the tank and new fuel pump and filter. Reinstalled the engine and It will start and run however not well. Compression test reveals about 150 - 162 on all 4 cyl. The engine misses and backfires. Here is where I think the problem is but I need some insight. There was no distributor when I got the bus and I am running a 009 with the points set to .016 and the dwell at 35. When I put the pulley at what I believe is TDC the distributor points to the 7 O'clock position not 5' O'clock. I have set the plugs accordingly but is it possible that the pulley is off 90 degrees? I am losing my mind because I can not get this thing timed correctly. I have tried to adjust the valves but I am worried that I am doing it with the engine not on TDC. Any held would greatly be appreciated.
Thank you _________________ 1966 Beetle Restoration almost done
1972 Ghia with the worst bumbers in the world.
78 Bay Window Project
Posted: Wed Aug 26, 2015 9:18 am Post subject: |
If a Mod thinks this would be better suited for the general Bay Window forum please move it accordingly. Thanks _________________ 1966 Beetle Restoration almost done
78 Bay Window Project |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Aug 26, 2015 3:41 pm Post subject: Re: 78 2.0 FI type 4 distributor orientation + misses/backfi |
no1pony wrote: |
When I put the pulley at what I believe is TDC |
So you are saying you don't have a timing scale on the shroud?
You'll do much better in the bay forum with this. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Aug 26, 2015 3:56 pm Post subject: |
First thing to do is find TDC on n°1 cylinder, then mark that on the pulley (white-out (liquid paper) works well), down the front where you can see it. Then set your timing static to 5° BTDC or whatever it is supposed to be for your engine. Once you get it running, you can mess around with it, I'm not sure how the 009 timing curve suits the type 4. |
Posted: Wed Aug 26, 2015 7:26 pm Post subject: Re: 78 2.0 FI type 4 distributor orientation + misses/backfi |
busdaddy wrote: |
no1pony wrote: |
You'll do much better in the bay forum with this. |
I'm sorry I was not clear on that. I do have the timing scale. I was having trouble being certain I was on TDC. It was more if a confidence issue that I was actually there. _________________ 1966 Beetle Restoration almost done
Posted: Wed Aug 26, 2015 7:43 pm Post subject: |
FreeBug wrote: |
Thanks, I went to Ratwell's site and followed the procedure and that was very helpful.
I made a lot of progress this evening however still not there. Here is what I did.
I ditched the 009 when I found in my stash a single vac advance 205 (don't remember the rest of the part number) distributor. I installed new points and condenser. I set the points at .016. When I installed the distributor I immediately notice the rotor would be in the 5 o'clock position that at least seemed normal to me. I static timed it at 7.5 BTDC.So I was now confident to move to the valves. I brought the valves out to loose then turned the adjuster until it touched the valve then 1 1/2 turns in. I followed the firing order turning the pulley 180* for each valve. I fired up first crank. Success right? Not quite.
I was checking the dwell which is at 28 when it started misfire and every once in a while a small pop. I started one at a time pulling a plug wire to see which cyl it was. It's #1 no difference at all with the wire removed. I can see the spark while removing the wire. The plug is gapped correctly but very fouled. Tomorrow I will swap it with another cylinder to see if it moves. Any more suggestions? _________________ 1966 Beetle Restoration almost done
Posted: Wed Aug 26, 2015 8:15 pm Post subject: |
no1pony wrote: |
I started one at a time pulling a plug wire to see which cyl it was. It's #1 no difference at all with the wire removed. I can see the spark while removing the wire. The plug is gapped correctly but very fouled. Tomorrow I will swap it with another cylinder to see if it moves. Any more suggestions? |
Not much, aside from a compression test, if that goes well swap the injector electrical plugs and see if the miss follows along (batch fire, wires are not cylinder specific), if not swap injectors bewteen cylinders. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Thu Aug 27, 2015 1:48 pm Post subject: |
Dwell should be 48-50 degrees not 28... |
Posted: Thu Aug 27, 2015 6:34 pm Post subject: |
I still have some work to do but its running. Brand new plug was bad. Also a large vacuum leak at the EGR. Tomorrow Ill Work on points and dwell to dial it in. I drove it a couple miles and filled her up and put in some injector cleaner. Here is a video of it running. If you have a moment I need some feedback be because the idle seem to be rising the longer it runs lol. Perhaps the injectors are clearing up.
https://www.youtube.com/watch?v=V2855nkopdw
THANK YOU for the advice and help. _________________ 1966 Beetle Restoration almost done
