erik_powell Samba Member
Posted: Thu Aug 27, 2015 3:50 pm Post subject: 2332 cc |
Thinking of building a 2332 cc dual port or something a little smaller, unsure of horsepower, so how much does one put out? Going to be running dual carbs but not sure what to get. Also will a type 3 irs with 4.12 gears hold up to this simply as a daily driver? Going to be running 31 inch tires front and back. What kind of striker kit, or Carburetors should I get? I have quite a few questions so any help is much appreciated. |
Brian Samba Moderator
Posted: Thu Aug 27, 2015 4:01 pm Post subject: |
For a bug, bus, t3, ghia, thing or other?
4.12 with 31's may be interesting, you could go dangerously fast in that. I have a 002 with a r&p of 5.375 with a 2110cc and I can turn my 31's pretty well. In 4th I'm at 80 mph @ 4k rpm. That's in a single cab too.
What kit? How much do you know about strokers? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Aug 27, 2015 4:03 pm Post subject: |
Brian wrote: |
What kit? How much do you know about strokers? |
Sorry, it's a bug
But I was looking, and scat sells a kit to make one a striker motor. I know you'd have to have to case and heads bored to make it work. Is scat a good brand? Only been involved with vws for a few months so still kind of a newbie |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Aug 27, 2015 5:26 pm Post subject: |
Scat rods and forged cranks are great quality. Dependant on who does the scat heads now, depends on the porter. If you are keen on a scat kit, read the scat engine kits topics using search. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Thu Aug 27, 2015 5:35 pm Post subject: |
Have someone who know what they're doing build it for you. Well worth it rather than buying an expensive kit and something going wrong on your hands.
Baja bug? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Thu Aug 27, 2015 5:41 pm Post subject: |
Brothers VW is currently doing SCAT's heads right now. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
