ed_andersen Samba Member
Joined: January 20, 2010 Posts: 21 Location: Barboursville, Virginia
Posted: Fri Aug 28, 2015 10:43 am Post subject: Old VW Motor? |
I have a split case w/ a cast in generator riser w/ dual port heads and carbs. Has not been touched since acquired back in the mid 70's or so. Serial number on front of Gen mount is 20-1125569. Any ideas? VW? Porsche? Let me know. Thanks Ed
Also I checked and crank is an 8 dowel. Block serial # is Type II June 1955 build. Added serial # pics and carb/dist.
I added 5 pictures in Gallery.
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Fri Aug 28, 2015 10:50 am Post subject: |
A pic will solve the mystery. One tip, a Porsche will have three piece cyl and head top cover tin and a vw will be one piece.
Dan |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri Aug 28, 2015 10:56 am Post subject: Re: Old VW Motor???? |
ed_andersen wrote: |
I have a split case w/ a cast in generator riser w/ dual port heads and carbs. Has not been touched since acquired back in the mid 70's or so. Serial number on front of Gen mount is 20-1125569. Any ideas? VW? Porsche? Let me know. Thanks Ed |
Well, if it was just the 1125569, that is a VW 36hp engine case number. Does the "20-" look the same? Or was it stamped after?
Most likely a VW _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Fri Aug 28, 2015 11:04 am Post subject: |
The 20 is stamped in and is quite different then the 1125569 font. |
Jonnyla Samba Member
Joined: November 11, 2013 Posts: 101 Location: Mesa, AZ
Posted: Fri Aug 28, 2015 11:32 am Post subject: |
Looks like Porsche to me! Heads for sure! _________________ '55 3 fold sedan, stock with lower stance (project)
'57 sedan, future old speed outlaw style (project) |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Fri Aug 28, 2015 11:49 am Post subject: old shit |
Heads are definetly Porsche.The heater boxes too.So someone could have put Porsche heads and carbs on a VW bottom end. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Brian Samba Moderator
GTV Samba Member
Posted: Fri Aug 28, 2015 12:20 pm Post subject: |
Started life as an August 55 Bus engine. It would be interesting to see what they did internally (if anything) to compliment the high flowing Porsche heads. It would be REALLY cool to see that thing rebuilt in a Wolfsburg bus!!
You cashed in there, that's an unbelievable find! _________________ EMPI Power Rules! |
Posted: Fri Aug 28, 2015 1:14 pm Post subject: |
That is a early Porsche engine. The early ones used a vw engine case and it could be as big as 1500cc, 1300cc or 1100cc. Don't let anybody steal it from you it is worth good $$$$. The crank and rods are not VW spec and the stroke could be as long as 74mm. Porsche went to there own three piece case in mid 1954. The numbers on the case don't match any in my Porsche spec book for a two piece case.
One thing I am not sure of is the lack of the Porsche tach drive off the oil pump. Could of been someone replaced a bad Porshe case with a VW one.
Dan |
Posted: Fri Aug 28, 2015 1:44 pm Post subject: |
Also didn't the oil filter tap into the generator stand? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sat Aug 29, 2015 5:41 am Post subject: |
In reply to oil press pickup - look at the gen stand just below motor # boss - there appears to be a tapped hole with a plug in it. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
bluebus86 Banned
Posted: Sat Aug 29, 2015 11:45 am Post subject: |
Get on the "356 Registry" site as a guest and email them with your engine information, and photos. someone their will be able to tell you exactly what engine that is , what car if was built for etc....
Porsche did modify VW cases for they early 356 cars before they started making their own crank cases. Pre-A Porsche 356's might use this motor and these cars are highly valuable and folks will pay big money to get the correct engine for their restored car (often over the decades the original early Porsche engine's were removed for upgraded motors and the original motor sold off or discarded, hence restorers often need to located the correct motor.)
so contact the 356 Registry, they will have the answer to your question, maybe even a offer to buy it! But since it is not a Four Cam motor don't think you can retire on the proceeds. but it still might be worth a good deal to the right buyer.
Vintage hot rod VW also used this kind of motor, pulled out of a wrecked 356 or a 356 that received a bigger motor back in the day. As Vintage VW speed stuff this motor is also valuable specially with all the period correct air cleaners and carbs.
nice find _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
56bugdan Samba Member
Posted: Sat Aug 29, 2015 12:34 pm Post subject: |
Looks like a Porsche 356 or 912 engine to me but that's based in what my fathers 356 and my 912 engine looks like. Problem is, haven't actually looked at them in a while so I don't remember for sure. For some reason I think the 912 has bigger heads and carbs than that but I could definitely be wrong. Definitely Porsche though so like what was said earlier, don't let it go for VW money. I know with ours we had Porsche guys offer crap money and try to tell us that "it's just a Volkswagen engine" to try to eat us down on price. If you told the same guys that their 356 was just a glorified VW they'd have a stroke. Good luck with it |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Sat Aug 29, 2015 2:38 pm Post subject: |
As stated it is a Porsche 1955 356 engine and the Solex 32PBJ was used one year only I do believe.
The oil filter return hole is in the Gen stand that shows a plug.
I once owned a 57 356A with the 40P11-4 Carbs.
VW mechanic (retired) |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Sat Aug 29, 2015 6:09 pm Post subject: |
It's likely a Pre-A 356 Porsche engine. As I understand it, the Pre-As had 2-piece engine cases, like a VW engine, then went to 3-piece cases for 356 A/B/C. Rectangular exhaust ports and trapezoidal valve covers indicate Porsche as well.
Unless it's a completely modified VW engine with Porsche components.
Now, if only it had 2 distributors, either mounted in parallel at the heads (early) or near-perpendicular near the fuel pump (later), you would have an incredible (and valuable) engine...
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
GTV Samba Member
Posted: Sat Aug 29, 2015 7:16 pm Post subject: |
If it is a Porsche engine than please explain why the engine number doesn't start with a "P" and instead has a "20-" prefix, which is early bus. _________________ EMPI Power Rules! |
Danwvw Samba Member
Posted: Sat Aug 29, 2015 7:35 pm Post subject: |
I have had several similar Porsche Engines but never saw one like this with the 2 piece case! Yes the Porsche engines were prefixed with a P!
It would be really exciting to know the Bore and Stroke! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sat Aug 29, 2015 8:06 pm Post subject: |
Like I said earlier, most likley it is a porsche engine that had a bad case and someone substuted a vw case. 1954 was the last year to use the two piece VW cases. There were pre A's with the three piece cases.
My 57a has a vw split case diff in it that I put in it many years ago as they are the same (cheap way to fix it) a common practice to use VW parts when there was no difference between them.
Dan |
