arizonabuckeye Samba Member
Posted: Fri Aug 28, 2015 4:22 pm Post subject: Ultra sonic cleaning |
So I started working on a carb rebuild and was looking into how people clean their parts. I found that pros use ultrasonic cleaners to get their parts/bodies super clean. My question is, if I bought said cleaner, would there be an interest in using it? Meaning would sending your parts to me to clean be something you would be interested in? How much would you pay - $20? I am sure there are companies that already do that and charge an awful price for it. I wouldn't be looking to make a profit just to pay for the machine... |
grandpa pete Samba Member
vwnut1 Samba Member
Posted: Fri Aug 28, 2015 8:24 pm Post subject: |
Ditto on that. Now if this were a Porsche forum... _________________ 1957 VW Oval Resto Mod |
Gratsoy Samba Member
Joined: April 12, 2009 Posts: 316 Location: Vancouver, B.C.
Posted: Fri Aug 28, 2015 8:28 pm Post subject: |
I own one of these things. I did a fuel pump in it and wasn't super impressed TBH. However, YMMV - I plan on testing out different cleaning solutions. |
Posted: Sat Aug 29, 2015 10:18 am Post subject: |
Gratsoy wrote: |
Oddly enough that is what more research has turned up... Some people swear by them and say their parts have never been cleaner and that as far as carb cleaning it is the only way to clean the small channels etc. others say it barely touched their stuff... |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Aug 30, 2015 8:43 am Post subject: |
I think you can buy those at Harbor Freight for next to nothing. |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun Aug 30, 2015 9:58 am Post subject: |
My favorite for carbs and fuel pumps is Berryman chem dip and a clean brass brush, plus compressed air.
I saw a tutorial thread on here where a guy used a little home made bench blaster with soda, and I vowed to try that; the stuff turned out looking new.
I haven't tried it yet, though. _________________ Plate of shrimp |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Sun Aug 30, 2015 10:20 am Post subject: |
panicman wrote: |
My favorite for carbs and fuel pumps is Berryman chem dip and a clean brass brush, plus compressed air. |
X2 on this method.
I still do a carb dip before I use the sonic cleaner.
Sonic cleaners work great on carburetors.
It cleans out the inner passages of the carb nothing else can get to.
buguy wrote: |
I use a friends and its the cheap one at Harbor Freight. Just a mix of water and vinegar... makes the garage smell great!
I think she said there are two sizes. Get the bigger one... worth it.
http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
planenut Samba Member
Posted: Sun Aug 30, 2015 2:29 pm Post subject: |
Strait GUNK works great. Just rinse with water. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Aug 30, 2015 3:37 pm Post subject: |
I clean my distributors with a hot pot and lemon juice makes the shop smell even better than vinegar and waaaaaay better than Berryman's. I suspect If I had to clean the 3-4 distributors a week with Berryman's I wouldn't be around anymore. I'd be averse to putting Berryman's down the drain but a little oily lemon juice... _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Aug 30, 2015 5:14 pm Post subject: |
tasb wrote: |
I clean my distributors with a hot pot and lemon juice makes the shop smell even better than vinegar and waaaaaay better than Berryman's. I suspect If I had to clean the 3-4 distributors a week with Berryman's I wouldn't be around anymore. I'd be averse to putting Berryman's down the drain but a little oily lemon juice... |
It does bear mentioning that I double glove and don't breathe over the open can of chem dip. Also, I don't do nearly as much daily stuff as a lot of you guys. This is not stuff I would risk constant exposure to, and no way would I dump it down the drain.
Arizona- that is exactly the soda blasting rig I was talking about! Makes me want to pick up a junk carb just to try it out! _________________ Plate of shrimp |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Sun Aug 30, 2015 7:41 pm Post subject: |
I use these. http://m.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
I put about 1" of simple green in it, and fill the rest with hot water. It has a built in heater that will make the water too hot to touch. It will fit a disassembled solex no problem, and an idf will just barely poke out. I run it for a couple cylces, then rotate the part then repeat about 4 times. About 30min later the carbs are spotless.
I use mine for everything. I really use it while building engines. I run all my Pistons, rings, rods, bearings, etc. through it. Just pull them out and blow them off. Way cleaner and easier then carb or brake cleaner.
When the water starts getting really dirty I start cleaning my tools with it. You will never again have that nasty junk stuck down inside a deep 13mm socket again.
Give it a try. For $89 you can't go wrong. Take a 20% off coupon and it's even better.
Brian |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Mon Aug 31, 2015 5:42 pm Post subject: |
If you have any air trapped in the carb passages it wont work. Rotate them until bubbles quit escaping from the part then turn the U/S back on.
The proper cleaner works far better than any home brew concoction...
Often home brew leaves residue if not removed and rinsed properly.
I use a dedicated 'shellac buster' full strength for extreme situations. |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Tue Sep 01, 2015 7:45 am Post subject: |
The joke potential here is limitless! _________________ Everything known to man has been written.
Readers are Leaders! |
