.D.J. Samba Member
Joined: November 19, 2011 Posts: 67 Location: New Hampshire
Posted: Sat Aug 29, 2015 7:32 am Post subject: Quick fuel filler neck question |
I've got my filler neck out, put the elbow back on at the correct angle. Now I'm trying my best to get the damn mercedes rubber hose on the tank side, there's no way, my engine is in. What can i put on it to help it along...spit? Very awkward angle. What did others do? _________________ 63 Beetle, 78 Bus |
grandpa pete Samba Member
Ian Samba Moderator
Posted: Sat Aug 29, 2015 8:51 am Post subject: |
i use wd-40 as lube, but only when i'm working on cars.
later _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
.D.J. Samba Member
grandpa pete wrote: |
dish soap....very little ; spread it on with your finger
push the hose on at an angle and turn it as you do . |
Yeah that isn't doing it... I can see why every picture I see of this being done the engine has been removed. _________________ 63 Beetle, 78 Bus |
Ian Samba Moderator
Posted: Sat Aug 29, 2015 8:52 am Post subject: |
I've done it with motor in and with motor out. It might help if you drop the motor down (take top trans bolts out, take moustache bar bolts out, lower it with floor jack slowly).
If you got the firewall out, you should be in the clear.
Lots of cussing, red spots on wrists, and medical marijuana may be required.
Like I always say, it might suck, but it's gunna get done! _________________ All your Buses are belong to us.
.D.J. Samba Member
Posted: Sat Aug 29, 2015 8:57 am Post subject: |
Ian wrote: |
Like I always say, it might suck, but it's gunna get done! |
Just got it! Holy hell what a pain! My wrists are all cut up, knuckles bloody, but it's in and I feel good about it. Thanks for the help. My kids know a lot more swears now... _________________ 63 Beetle, 78 Bus |
cmonSTART Samba Member
Posted: Sat Aug 29, 2015 5:07 pm Post subject: |
Yes, do share. I have one of those in my future... _________________ '78 Bus 2.0FI
de K1IGS |
SGKent Samba Member
Posted: Sat Aug 29, 2015 6:25 pm Post subject: |
cmonSTART wrote: |
Yes, do share. I have one of those in my future... |
then you have this to look forward to
Quote: |
Just got it! Holy hell what a pain! My wrists are all cut up, knuckles bloody, but it's in and I feel good about it. Thanks for the help. My kids know a lot more swears now... |
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Aug 29, 2015 7:10 pm Post subject: Re: Quick fuel filler neck question |
.D.J. wrote: |
I've got my filler neck out, put the elbow back on at the correct angle. Now I'm trying my best to get the damn mercedes rubber hose on the tank side, there's no way, my engine is in. What can i put on it to help it along...spit? Very awkward angle. What did others do? |
One of the most useful tools in my arsenal is a Snap On radiator hose pick that has been shortened and rounded a bit. If I could only carry a dozen tools with me, the radiator pick might well be one of the tools I would choose to take.
I wonder if you took the hose down to a muffler shop if they could expand it a tiny bit for you without harming the hose? Would make life easier if they could. |
SGKent Samba Member
Posted: Sat Aug 29, 2015 8:48 pm Post subject: Re: Quick fuel filler neck question |
Wildthings wrote: |
.D.J. wrote: |
usually so will hot water. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
.D.J. Samba Member
Posted: Tue Sep 08, 2015 7:49 pm Post subject: |
so please tell ...how did you get it back on ?? |
Little bit of soap and I got really pissed off and raged out. I had the metal filler neck out and I repeatedly put the rubber hose on/off to stretch it a bit. That may have helped. _________________ 63 Beetle, 78 Bus |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Tue Sep 08, 2015 9:12 pm Post subject: |
I agree with Gary- Hot water and an old baseball with the cover off helped expand my buddy's hose enough to put it on easily. Also agree with Wildthings, that radiator hose pick is the nazz- end up using it for all kinds of shit. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Tcash Samba Member
Posted: Tue Sep 08, 2015 10:27 pm Post subject: Take a hose off, Put a hose on |
Removing a hose.
Note how the hose tool does not come to a sharp point. It is more of a blunt point.
Work the point of the tool just under the edge of the hose and spray wd-40 in the gap. Then continue working the tool around the circumference of the fitting spraying as you go until the hose breaks free.
Installing a hose.
Spray the inner diameter of the hose with wd-40. Start the edge of the hose over the fitting by hand. With the tool pull the rest of the lip over the fitting. Spray fitting and with a slight twisting motion install hose.
FAQs - WD-40 Company
wd40.com/faqs
WD‑40
It is safe to use on metal, rubber, wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40® Multi-Use Product. |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Wed Sep 09, 2015 8:00 am Post subject: |
Ian wrote: |
We are of the same philosophy.
I'm gonna have to do this soon enough. Engine's out tho. Thanks for the info dudes _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Wed Sep 09, 2015 8:07 am Post subject: |
secretsubmariner wrote: |
Ian wrote: |
I'm gonna have to do this soon enough. Engine's out tho. Thanks for the info dudes |
Certainly do it while the engine is out. 10x easier. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Fri Sep 11, 2015 7:25 pm Post subject: Re: Quick fuel filler neck question |
.D.J. wrote: |
What is the Mercedes rubber hose? _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
Tcash Samba Member
Posted: Fri Sep 11, 2015 7:48 pm Post subject: Re: Quick fuel filler neck question |
otiswesty wrote: |
.D.J. wrote: |
What is the Mercedes rubber hose? |
http://www.thesamba.com/vw/forum/viewtopic.php?p=4835840#4835840 |
