Maxoceanblue Samba Member
Joined: June 27, 2013 Posts: 429 Location: Pensacola, FL
Posted: Sat Aug 29, 2015 9:07 am Post subject: Flywheel lock won't fit |
Is it possible I have a larger flywheel? Trying to take it off and the flywheel lock won't line up with the hole in the case I'm to run a bolt through. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
KTPhil Samba Member
Posted: Sat Aug 29, 2015 9:39 am Post subject: |
Pictures would help. Some flywheel locks have two sides (6V and 12V). |
Posted: Sat Aug 29, 2015 11:50 am Post subject: |
Lock fits on the teeth but won't line up with the hole in the case to run a bolt through
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Sat Aug 29, 2015 1:55 pm Post subject: |
Can't see the hole. Is it as simple as just turning the crank/flywheel slightly? _________________ 1958 Karmann Ghia owner |
planenut Samba Member
Posted: Sat Aug 29, 2015 2:56 pm Post subject: |
Did you try to turn it over? |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Aug 29, 2015 5:02 pm Post subject: |
Northof49 wrote: |
Can't see the hole. Is it as simple as just turning the crank/flywheel slightly? |
Or maybe drill a new hole in the case? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Aug 29, 2015 6:16 pm Post subject: |
I've tried flipping it over. It won't fit within the teeth is I flip it over. I know how its supposed to work. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Aug 29, 2015 6:53 pm Post subject: |
Well, you know there is nothing wrong with your case or flywheel, right?
And, by your pictures that tool indeed looks like it is a Generic VW 6/12 volt flywheel lock tool that has been used at least once before, right?
What does that leave? Looks to me like it's tooth on the left may be bent outward, and the tooth on the right bent inward, so I'd blame the tool as your issue. Causes could be poor quality steel or mis-use.
Your choices are either get a better/new one, or force that one into submission by first installing it loosely using a longer bolt then drawing it into engagement with the flywheel teeth using the bolt threads to pull it in tight. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Sat Aug 29, 2015 7:41 pm Post subject: |
Here is what it looks like flipped over. Only one tooth engages with the tool. The problem is the whole on the lock doesn't line up with the hole on the case. It's not a matter of turning the flywheel. The flywheel seems to be a larger diameter. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Sat Aug 29, 2015 8:01 pm Post subject: |
That tool doesnt look healthy but try screwing it in and letting it catch on the right end to remove the gland nut or left end to tighten should be ok. _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Sat Aug 29, 2015 8:49 pm Post subject: |
iowegian wrote: |
Northof49 wrote: |
drilling a new hole is a really bad idea! Don't do it! _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
Posted: Sun Aug 30, 2015 6:01 am Post subject: |
caleb0101 wrote: |
iowegian wrote: |
Northof49 wrote: |
drilling a new hole is a really bad idea! Don't do it! |
Why do you have to spoil my fun? |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Aug 30, 2015 6:26 am Post subject: |
RareAir wrote: |
6v flywheel is 180mm. 12v flywheel is 200mm. Is your car an auto stick model?
Is the front tin causing an obstruction for allowing the lock tool from sitting properly? |
not always- I have a 200 /o-ring- 6vt flywheel for my bus. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sun Aug 30, 2015 8:28 am Post subject: |
I confess I've never seen the wisdom of using this tool, when a simple angle iron bolted to the flywheel does a far better job. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
grandpa pete Samba Member
Posted: Sun Aug 30, 2015 9:09 am Post subject: |
You rich guys crack me up ;
Just go out to the Air Conditioned garage and cut up some iron pipe and make one !!!
YES it works FINE !!!
AND it's fully adjustable ; if it doesn't fit the flywheel groves just wack it with a big hammer
_________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Sun Aug 30, 2015 10:03 am Post subject: |
Rare air, what am I to measure, the diameter? From edge to edge of mine is 275mm
It's a manual. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
Posted: Sun Aug 30, 2015 10:11 am Post subject: |
It's an 8 dowel flywheel, if that makes a difference. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
