theowendorff Samba Member
Joined: August 16, 2010 Posts: 12 Location: Cayucos, CA
Posted: Sun Aug 30, 2015 2:12 pm Post subject: Sputtering Bus |
After driving my '79 bay window 8 hours from San Francisco to Los Angeles, I noticed the bus sputtering at stops. The next time I tried to start it, the bus would not stay on, but just sputter out. If I floor the gas pedal, the bus stays on but at a VERY low idle. It feels like it is out of gas, but there is plenty of gas. Could this be a fuel filter issue? Fuel pump? Vacuum? Distributor looks good, no corrosion |
Posted: Sun Aug 30, 2015 2:42 pm Post subject: |
I think a vacuum leaks would be a like cause. Check for any hoses that might have fallen off or plain broke in two. |
SGKent Samba Member
Posted: Sun Aug 30, 2015 4:16 pm Post subject: |
did it start slowly over the whole trip or suddenly?
is it a 1979 Federal with points or 1979 California with an electronic ignition? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Posted: Sun Aug 30, 2015 4:27 pm Post subject: |
X2, points? or electronic, and if points is the rubbing block intact? (gap/dwell OK?)
And assumedly fuel injected, no? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Aug 31, 2015 7:55 am Post subject: |
Found a hose missing coming out of the charcoal canister, don't know if that makes a difference. It is a 79 federal with points. It is fuel injected. Rubbing block looks good. It started suddenly right after it had cooled down from the trip. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Aug 31, 2015 11:46 pm Post subject: |
Check the timing and dwell first before anything else. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
