ceedubbya Samba Member
Posted: Sat Dec 06, 2003 6:05 am Post subject: class 11 help? |
| does anyone where i can get info on class 11 baja's?..mainly the suspension..if any different from stock. |
Dono Power Samba Member
Joined: April 25, 2003 Posts: 72 Location: Benton Arkansas
Posted: Sat Dec 06, 2003 6:49 pm Post subject: Class 11 |
Im building a Class 11 style car also. You can get rule book from SCORE for the "real" Class 11 race car. I am building a 66 body on a late IRS 68 pan ( Yeah 68 IRS..think autostick!!! ) with a 3 inch body lift and with 3 inch front lifted spindles. I cant decide on tire size/type and which method to use on lifting the rear end. The car is straight and clean with a factory metal sunroof and the pan I restored the pan about 2 years ago to duplicate a friends killer all original 66 Beetle. Its like new with all new parts, pans, paint etc. I bought the friends 66 and had all of this "left over". The motor put aside for it is a late Dual Port 1600 with a Engle 100 cam, Compufire DIS IX and a stock tricked out 34 carb.
Finding info on these cars is tough. There is a killer pic of a Class 11 style "comanduer" car in the forum today. I had a Class 11 a few years ago and had a blast driving it and it drew all kinds of attention!!! This one will be Bigger and better than the last one. I would think these cars would be more popular!! _________________ Thanks,
Dono Power
P.A.C.E Buggi Werks
Benton Arkansas
Diagnosed as a Sambachodriac. |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1508 Location: Finland, Jakobstad
Posted: Wed Dec 10, 2003 3:59 pm Post subject: class 11 help? |
| I had a 70 and a 64 "baja" several years ago.No fiberglass kit,just cut the fenders and add bigger tires.I have always liked the way class 11 vw's looked and didn't know how to get the bigger tires under them.I have a 69 I want to "raise" a bit.Thanks for the feedback on the subject! |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4131 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Fri Dec 12, 2003 12:33 am Post subject: |
They usually just have stock rims and a Knobby 29' tire? _________________ There are 3 kinds of people in this world, The kind that can count and the kind that can't.
GO SEAHAWKS!!! |
62ragman Samba Member
Joined: November 01, 2003 Posts: 100 Location: San Dimas,CA
Posted: Sat Dec 20, 2003 12:47 am Post subject: |
| The suspension is stock per the rule book,but if your not going to race build it the way you want. www.score-international.com has the rule books for sale for like $15 if you still want one. Also www.chenowth.com sells a Class11 roll cage that would be a good start, it has to be welded in though. Good luck. |
KDF Baja Samba Member
Joined: October 25, 2003 Posts: 247 Location: Minnetrista, MN
Posted: Tue Jan 06, 2004 8:40 pm Post subject: |
speaking of class11, who has used the chenowth or similar rollcage?does it actually support you in a rollover or is it just for show? i know the cage surrounds the driver, does it go back into the rear seat area? _________________ 72 baja up for sale/trade! moving to WI in march, bug must go!
89 suburban |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2977 Location: altus, oklahoma
Posted: Tue Jan 06, 2004 9:18 pm Post subject: |
| the chenowth kit is the real deal, and yes it will help in event of a rollover. you can forget the rear seat, because several tube brace the rear torsion tube and frame horn,etc. my rollcage is a different design but the rearseat is still eliminated. there is a couple of photos of my ride in the readers rides section |
68deluxe Samba Member
Posted: Tue Mar 02, 2004 10:13 pm Post subject: |
| Just wondering if there is a particular year bug better suited to Class 11 racing or are they all pretty much equal? Does anyone know if type 2 transaxles are ok in class 11 (just ordered the Score rule book). Thanks- |
Posted: Wed Mar 03, 2004 4:07 pm Post subject: |
| '69 and later are better as you are limited on suspension, so the balljoint front end will last ok. Be sides they are cheaper than the eariler ones. Only type one parts are allowed, no bus boxes. |
Kafer Wolf Samba Member
Posted: Tue Mar 16, 2004 6:19 pm Post subject: |
if type 1 suspensions are used, are they still stock or are they modified for strength?
how do you lift the suspension? is a class 11 essentially a stock beetle?
also, any good website with lotsa class 11 pics?
class11s are cool IMO, way cooler than bajas...  |
vwclass11 Samba Member
Posted: Wed Mar 17, 2004 2:59 pm Post subject: |
Here is my street legal class 11 car.
Posted: Thu Mar 18, 2004 2:28 am Post subject: |
cool class 11 car!
are those rear suspension all stock? won't the cv's break down in that angle?
how did you raise the front suspension? |
Posted: Thu Mar 18, 2004 7:36 am Post subject: |
| Well in the rear I am using thing flanges,bus cvs, bug axles, stock trailing arms, and modified type 1 stub axles. Pretty much stock vw. In the front I cut and turned the front end, I have 3 inch raised spindles with disc brakes from SoCal Imports. You should check the thread "Lifts and CVs". Anyways hope this helps. I also posted pictures of the rear suspension in the off-road gallery. |
DanGreen Samba Member
Joined: November 24, 2003 Posts: 182 Location: Goleta
Posted: Sat Mar 20, 2004 2:09 am Post subject: |
| are the spring plates as far as they can go or did you leave some space for them to travel? ...... are they touching the stops? |
Posted: Sat Mar 20, 2004 2:39 pm Post subject: |
| No, the spring plates are not touching the stops. There is probably 2 inches from the spring plate to the stop. One added benefit is that I did not have to fight the spring plates to get them back on, also makes for a smoother ride since the torsion bars are not preloaded that much. Pretty much rides like a stock bug. |
