kencan Samba Member
Joined: January 12, 2010 Posts: 1 Location: SOUTHWEST USA
Posted: Tue Sep 01, 2015 11:30 am Post subject: Intake manifold boots |
I have a 1600 double port that I am replacing the intake boots on to cure a vacuum leak. I have inspected the castings and the pipe. both are in good condition. Have new boots from Wolfsburg.
I am now ready to install the new boots. I do have the engine out for more checking, so replacement is easy.
My question is, does any one use any kind of sealant on the joint? If so what is good? Would red silicone be good? Or is it best to install the boots with nothing on them?
Thanks to you for any help or suggestions.
Ken |
Brian Samba Moderator
Posted: Tue Sep 01, 2015 11:34 am Post subject: |
No, but I never had good boots. A functional alternative to boots is using radiator hose with big ol hose clamps. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
mark tucker Samba Member
Posted: Tue Sep 01, 2015 4:00 pm Post subject: |
use the boots. I used the silycony ones and the poly ones never had any issues with either. but the poly ones dont like cemicles&oils...well none do. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Sep 01, 2015 4:06 pm Post subject: |
All you need is the boots. Wolfsburg West ones are superior to others I've read about on this forum. I used them and no issues.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
sb001 Samba Member
Posted: Tue Sep 01, 2015 5:10 pm Post subject: |
They should make a special tool for getting those rear nuts off, damn.
That is all. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Tue Sep 01, 2015 11:18 pm Post subject: |
I neglected to say that you also need the clamps!
Richard O'Brien |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Sep 02, 2015 7:01 am Post subject: |
sb001 wrote: |
They should make a special tool for getting those rear nuts off, damn... |
Make some tools, like cut-down and ground-down wrenches, use sockets with universal built in, use 1/4 inch drive tools, use wobbly extensions, even use steel nuts that use a 12mm wrench for clearance (have same thread of 8 x 1.25mm), available from Japanese vehicle parts department (called JIS nuts) and even at Ace Hardware near me. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Sep 02, 2015 7:19 am Post subject: |
what nuts??? |
My-hobbies Samba Member
Joined: August 27, 2015 Posts: 13 Location: Boston area
Posted: Wed Sep 02, 2015 7:20 am Post subject: |
I have replaced my boots that were cracked when I got the non-running dune buggy I have. I used the red silicon boots. I used a small wipe of white lube grease to help the parts slide together and to improve the seal (not that it may have needed improving). The lube did help when trying to wrestle the manifolds on, working around the tight space of the alternator perch and intake manifold studs. |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Wed Sep 02, 2015 9:41 am Post subject: |
You never use sealant on plumbing deafeats the purpous of an air tight seal. you could lap it in with a pin tip of white lithium. |
Cusser Samba Member
