electronictofu Samba Member
Posted: Tue Sep 01, 2015 5:07 pm Post subject: Rear disc brake options and compatibility |
Hey all,
I've spent a lot of time diving into front disc brake threads and know which route Im going there, but it'll be a while. I've got a lowered stock setup, all new drum in front, so it's good for now. My rear is a type 1 long axle, with type 3 drums and pads. The type 3 parts are hard to find, I looked for pads before but couldn't find any that lined up right. There's a place in So-cal that makes them and swaps them out, but I figure if I'll be investing cash into the rear, just do the disc brakes, since Im going 4 wheel disc in due time anyways. Preferably I'd start up front, but in this case I may do the rear.
I know there are some threads for this, but none too too recent unless I missed it? So, with a type 1 68' long axle rear on a 65' bus, and off-set lowered spring plates, what kinds are available currently? Are we buying bug rear disc brakes for this?
Also, the MC needs to be swapped out I'm sure. I hear the asian ones aren't too shabby?
Thanks in advance. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Sep 01, 2015 8:22 pm Post subject: |
cdennisg wrote: |
It is generally a bad idea to have more braking power in the rear of a vehicle than in the front. If you install rear discs, install front discs to match, or don't do it at all. |
Stock setup = stock rims? = 5x205?
That might limit some of your options... especially if 14".
Take a look at/call:
Wagenswest
CB performance
CSP
Airkewld _________________ aka: Evan
Joined: February 03, 2003 Posts: 127 Location: NOR-CAL
Posted: Thu Sep 03, 2015 8:04 am Post subject: |
15" wheels
5x205/ Wide 5.
I'll try to give them a buzz this week. |
