renka Samba Member
Joined: September 23, 2010 Posts: 36 Location: Holland
Posted: Wed Sep 02, 2015 1:07 pm Post subject: Hazard warning light |
Help wanted:
Very busy with my son restoring a 63 (modelyear 64) crewcab, but one confusing detail. With the search done in the gallery we see dashes with and without the warninglight next to the fuelgauge
The wiring diagrams for usa models dont show a separate bulb/warning light?
In the partsmanual I came across partnumber 211 953 221 is this the small warning light with the chrome bezel?
But main question is did all the 63 cars have the hazard warning light for sure?
Thanks in advance
Cheers René _________________ to finish first, you first have to finish |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Wed Sep 02, 2015 1:56 pm Post subject: |
The hazard warning light to the left of the steering wheel/speedo pod was a 64' model year addition. Your bus may be a 64' model year, but it will have "leftover" 63' parts used on it, especially since it is a commercial vehicle. What they did at the factor when they had changes for the new year was to use up all the old model year parts on commercial vehicles (pickups & panels). I have a 64' model year panel camper that came out in November 63' and it has ice pick door handles and the air filter in the engine compartment is on the left side. 64 was the first year of push button door handles and the air filter was moved to the right side the engine compartment. If there are no signs of the hole being filled or "shaved" by a PO then I'd say it came from the factory with a 63' dash without a hole for the hazard warning light. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Wed Sep 02, 2015 2:08 pm Post subject: |
I have never seen a wiring diagram with that circuit. has anyone seen a factory '64 bus wiring diagram for a USA spec bus?
as far as I know, every USA spec '64 bus came with the warning light on the dash. I have seen hundreds of '64 buses and they all had them.
also, both of my '63 buses have the warning light on the dash from the factory, so it showed up in '63 model year. _________________ .
Wanted:
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Wed Sep 02, 2015 2:37 pm Post subject: |
What is the build date on the Mcode plate??
From "Progressive Refinements":
Much much more at:
http://oacdp.org/ _________________ In Stereo, Where Available! |
renka Samba Member
Posted: Thu Sep 03, 2015 10:12 am Post subject: |
thanks for the replies!
Build date from the M code plate is 05/9
where comes the feed to the warninglight from I guess from the relay anyone can give me a hint?
cheers René
take a look!
http://www.spijlbussen.nl/web/index.php/topic,6042.0.html _________________ to finish first, you first have to finish |
renka Samba Member
Posted: Thu Sep 03, 2015 11:00 am Post subject: |
Yes, but $40.00 is way too pricey. _________________ In Stereo, Where Available! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Sep 03, 2015 11:01 am Post subject: |
Yes. Here's a 65 diagram showing the hazard light set up
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Thu Sep 03, 2015 11:17 am Post subject: |
renka wrote: |
Build date from the M code plate is 05/9 |
That would be the day and month. What is the chassi number? You can "X" out the last two or three numbers if you are worried about that.
Have you looked up under the dash to see if there is any evidence of the E-flasher light hole? _________________ In Stereo, Where Available! |
renka Samba Member
Posted: Thu Sep 03, 2015 12:52 pm Post subject: |
Sorry no original dash to check dash was ruined already
Chassinr is 11628..
Cheers _________________ to finish first, you first have to finish |
Lind Samba Member
Posted: Thu Sep 03, 2015 12:52 pm Post subject: Re: Hazard warning light |
renka wrote: |
Help wanted:
Thanks in advance
Cheers René |
is your bus USA spec or Euro spec?
Euro spec buses did not have the flasher circuit.
post the whole M-code plate if you are unsure and we can decipher it. _________________ .
Wanted:
renka Samba Member
Posted: Thu Sep 03, 2015 1:02 pm Post subject: |
it is a usa spec offcourse M plate is clear to me thanks
the car came from Benicia _________________ to finish first, you first have to finish |
