Idle 1990 Cab
Forum Index -> Water-cooled VW Share: Facebook Twitter
davidohious
davidohious is offline
PostPosted: Fri Sep 04, 2015 7:47 am    Post subject: Idle 1990 Cab Reply with quote
1990 Cab. Car runs fine but has a clunky/rough idle. it isn't too high or low just can feel it in the car when at stopped but once i drive off the car runs fine. any possible causes or fixes? I just had the engine/radiator flushed out and new thermostat put in. Thanks
ps2375
ps2375 is offline
PostPosted: Fri Sep 04, 2015 8:10 am    Post subject: Reply with quote
Vacuum leaks, dirty injectors, timing, airfilter.... what management is on it? CIS-e?
kamzcab86
kamzcab86 is offline
PostPosted: Fri Sep 04, 2015 10:23 am    Post subject: Reply with quote
Digifant. No Cabriolet ever came with CIS-E.
Clean/replace the grounds.
Remove and clean the ISV using carb cleaner.
Ensure the idle is set correctly: http://forums.vwvortex.com/showthread.php?731083 .
~Kamz Anxious
2016 Golf GTI S
ps2375
ps2375 is offline
PostPosted: Fri Sep 04, 2015 5:37 pm    Post subject: Reply with quote
I lost track of what came with what after the mid 80's.
DoubleDee
DoubleDee is offline
PostPosted: Sun Oct 11, 2015 6:34 am    Post subject: Reply with quote
Knock sensor? Check knock sensor for cracks, bad wiring. and proper nut torque to block.(important) ANY issues replace it.
Spray brake clean to find any idle change for vacuum leak.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
