clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Sun Apr 03, 2016 6:32 pm Post subject: Re: Megasquirt 2 system assembly and installation |
I run a Bosch pump from a 94 Volvo 940 turbo which is supposed to be 230 hp.
The inlet on the pump is 1/2 inch and the outlet is 1/4 inch. I don't think the size really matters much at 43 lbs.
Unless you are planning on more than 300 hp.
I also use the 32# injectors from that car.
You can't beat the OEM Bosch pumps for reliability. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
esde Samba Member
Joined: October 20, 2007 Posts: 5927 Location: central rust belt
Posted: Tue Apr 12, 2016 6:51 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Im really getting an education with this install, crash course style. Here is the relay board in, unit wired, grounded, and powered up.
I went through the sensor calibration pretty effortlessly, and everything works as it should, so I'm pretty stoked! Pulled the fuses for spark and fuel so that I could spin it to check crank signal. N-N-N-N-Clunk, N-N-N-N-CLUNK. What the hell? Something catching at between 20º and 30º BDC. Pulled the plugs, rockers, belt, no change. Pulled the motor and found the balance weight here
was tagging the cross shaft bushing here
I ground off the weight and made a new one to mount under the bolt, accounting for the additional distance from center. Back together and into the car, spun and no crank signal. Went back though the hardware manual, and realized when I soldered the board I left the jumpers out, as I wasn't sure if I was using a Hall or VR sensor. There are two jumpers to position, and without them the MS won't read anything. Here's one, the copper bit just to the right of the "GRIPPO" text
And just like that, when I spin it the crank signal shows up
Just waiting on one more thing to fire it up, some injector o-rings. I have a small weep on two of the injectors at the fuel rail, and I think the bore in the rail is a bit big. Or the current o-rings are too small, or poor quality. Anyway, I ordered some 14.5mm seals from here
http://www.fiveomotorsport.com/electrical-connectors/
as I read that the extra .5mm is a fix for the sloppy fit, we'll see. The hardest part right now is not starting something else while the car is on the lift and I wait for parts.. I want to drive this thing.
SD |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Tue Apr 12, 2016 11:37 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Nice one, it's getting there! _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
esde Samba Member
Posted: Tue Apr 19, 2016 9:07 pm Post subject: Re: Megasquirt 2 system assembly and installation |
No time to mess with it till tonight. First thing I did was check the timing, to make sure what the MS was reading as TDC was actually TDC. I've gotta hand it to Mario from Dubshop, his instructions for installing the trigger wheel are great, and the timing was spot on! I primed up the oil system, installed the fuses, and gave it a whirl. No luck. I remembered being confused by the wiring for the two coil channels and switching them, and tried switching them back. Bingo, it fired right up and runs well.
After getting a belt on it, and dropping the idle to around 1000rpm, I checked it out. Good oil pressure, zero leaks, no bad sounds or vibrations..
Of course now I have to put the car back together and learn how to tune this thing. There are a few things to work out though: The fuel relay, it is cycling on and off very quickly, it's essentially buzzing. The pump pumps, and the fuel flows, but it doesn't seem right. Am I onto something? Or leave it be? And the system won't shut down with the key. That I can probably figure pretty quickly. My charging system is the suspect, as it shuts off when the engine isn't running, but once it's running it stays running. I've known something wasn't right for a while, looks like now is the time to sort it..
SD |
esde Samba Member
Posted: Tue Apr 19, 2016 9:08 pm Post subject: Re: Megasquirt 2 system assembly and installation |
esde Samba Member
Posted: Tue Apr 19, 2016 9:09 pm Post subject: Re: Megasquirt 2 system assembly and installation |
modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
Posted: Tue Apr 19, 2016 11:42 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Chip Samba Member
Posted: Wed Apr 20, 2016 6:17 am Post subject: Re: Megasquirt 2 system assembly and installation |
Engine run on can be solved with a diode in the alternator light circuit. It's a trick common with cars with MSD systems. There is documentation from MSD regarding it. Google it for better info. |
Posted: Wed Apr 20, 2016 10:17 am Post subject: Re: Megasquirt 2 system assembly and installation |
Chip B. wrote: |
yep my alternator swap did this, snipped the blue wire to the GEN light under the dash, soldered in a diode with the band facing the regulator, NOT facing the light. and then low and behold it worked fine
Test it by when you turn off the key and it keeps running, pull the GEN light wire off and if it kills it, thats your issue _________________
Alstrup wrote: |
esde Samba Member
Posted: Wed Apr 20, 2016 4:51 pm Post subject: Re: Megasquirt 2 system assembly and installation |
So, what was the rating on the diode that you used? As it's just a blocking diode on a small warning light I'm not sure how to size it. |
63single Samba Member
Joined: May 02, 2004 Posts: 122 Location: west coast of fla.
esde Samba Member
Posted: Wed Apr 20, 2016 5:54 pm Post subject: Re: Megasquirt 2 system assembly and installation |
that does sound like it, thanks!
Of course radio shack is out of business, I'll have to make a few calls tomorrow |
esde Samba Member
Posted: Wed Apr 20, 2016 7:23 pm Post subject: Re: Megasquirt 2 system assembly and installation |
I rummaged through the box of leftover bits from building the megasquirt board, and found these
Maybe Mario will chime in and tell me if they were in fact supposed to be "leftover", but I suspect they are. Anyway, I'm going to install it tomorrow night, probably at the idiot light end and not the alternator end.
Mario chimed in on the MS/facebook page, and clued me in to the fact that it was my fast idle relay making the buzzing, not the rule pump relay. I'll have to turn that off as there is no stepper motor or fast idle valve.. |
esde Samba Member
Posted: Thu Apr 21, 2016 7:55 pm Post subject: Re: Megasquirt 2 system assembly and installation |
The diode solved the shut down issue. I soldered it directly to the bulb holder, and put a male spade connector on it, and covered it with some shrink wrap. Easy. The buzzing was the fast idle relay, which I removed and turned off in tuner studio. Engine seems to run well, but a cooler seal leak (ugh), and lazy alternator will get fixed before driving. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Apr 21, 2016 8:18 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Lazy alt? I just noticed recently that John at AC.net sells an uprated regulator for these alternators that may help _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Fri Apr 22, 2016 1:15 am Post subject: Re: Megasquirt 2 system assembly and installation |
esde wrote: |
Cool about the engine turning off! _________________
Alstrup wrote: |
Mavelotta Samba Member
Joined: March 27, 2006 Posts: 50 Location: Monroe, Wa.
Posted: Wed Apr 27, 2016 12:23 am Post subject: Re: Megasquirt 2 system assembly and installation |
Nice work sir, you have been hard at it for awhile now. Sounds great already! _________________ The Dub Shop
[email protected]
Facebook-Tech-Store |
esde Samba Member
Posted: Mon May 02, 2016 10:31 pm Post subject: Re: Megasquirt 2 system assembly and installation |
First test drive, around the block twice.
the cars a damned missile now
I pulled back into the shop to track down a buzzing sound, maybe the fan. Somethings up with one of my carb linkage rods, so I'll swap on some spares.
But damned, coming back under the highway, where I can hear it really well in the tunnel (and nobody is walking or parked ever) I rolled into the throttle in first, the engine comes on hard and breaks the tires loose. Second time around, tried it in second gear, same result. Acceleration is amazing. Engine falls back to a tick tick tick idle. And this is just on the base tune. |
DeathBySnuSnu Samba Member
Posted: Tue May 03, 2016 4:42 pm Post subject: Re: Megasquirt 2 system assembly and installation |
What is the rest of your combo?
Displacement, heads, cam ect.
Good to hear that things are starting to work out!
Just wondering what to expect from my ms project.
2387 and a fk10, ported 050 heads. |
