gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Fri Oct 02, 2015 12:30 pm Post subject: |
double post _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
Mavelotta Samba Member
Joined: March 27, 2006 Posts: 50 Location: Monroe, Wa.
Posted: Wed Oct 14, 2015 11:07 am Post subject: |
Your another person who could use these EFI manifolds I'm working on! I'm always a day late and a dollar short... Nice work so far Seth!
_________________ The Dub Shop
[email protected]
Facebook-Tech-Store |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Oct 14, 2015 3:10 pm Post subject: |
Mario, I've watched your progress designing and prototyping those with great interest, no doubt they fill a void in the market. I just bought a set of the offset manifolds with injector mounts, so I'm good. Or at least I hope I am.
Question: what retains the injectors and fuel rail on the CB offset manifolds? I see no tapped hole or provision. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Wed Oct 14, 2015 3:38 pm Post subject: |
Normally they are supplied with an extended stud and extra nuts, with a small bar of aluminium that pushes the rail down onto the injectors, I'll have a look and see if I have pics of mine
Actually scratch that I just saw your inj are mounted on the TB's, mine are inboard of the manifolds, so.........not sure how they are retained _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
esde Samba Member
Posted: Wed Oct 14, 2015 6:11 pm Post subject: |
66brm, I was originally going to mount the injectors in the throttle bodies, so I wouldn't have to lose the match ported manifolds that I have. But, when I mocked it up, the slightly wider engine puts one fuel rail right against the body. I'm not comfortable with the small chance that some wheel hop could result in a high pressure fuel leak, so I stepped up to the manifolds with the inboard injector mounts. Might have a try copying the port matching that Tims did on the original manifolds.
I had to shave .5mm off the outside of the generation 3 injectors for them to seat into the manifolds. The fuel rails I had from something, and there are hold down brackets with them, but nowhere to cinch them down. Scoured the CB box, I found the mounts studs and gaskets, but nothing to help me out. If nobody has a picture of what's supposed to be I'll ping CB or Mario to ask.
SD |
66brm Samba Member
Posted: Wed Oct 14, 2015 7:26 pm Post subject: |
http://www.noh2o.org/viewtopic.php?t=1255&postdays=0&postorder=asc&start=120
Down the page a bit is a pic of my engine with inboard injectors. The right one has the retaining tab, click on the pic for a bigger view _________________ Aust. RHD 66 Type 1
modok wrote: |
esde Samba Member
Posted: Wed Oct 14, 2015 7:44 pm Post subject: |
Thanks! OK, I can make that happen, it's about as simple as it gets huh?
Is that a valve on the drivers side rail for checking pressure? |
Posted: Wed Oct 14, 2015 7:56 pm Post subject: |
esde wrote: |
Here is CB's solution
Here is my solution
[email protected]
66brm Samba Member
Posted: Wed Oct 14, 2015 7:59 pm Post subject: |
Yeah its just a shrader valve tapped into a 1/8 npt thread, I've been thinking of putting a gauge there to monitor rail pressure (oh and that's the passenger side ) _________________ Aust. RHD 66 Type 1
modok wrote: |
Singerdude Samba Member
Joined: March 07, 2015 Posts: 464 Location: Quebec, Canada
Posted: Wed Oct 14, 2015 11:16 pm Post subject: |
Kudos on the FI setup esde, one day Perhaps... Right now my carbs are new and the next 3 year's budget is already spent... |
esde Samba Member
Posted: Thu Nov 12, 2015 10:01 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Slow progress, as I've got 10 projects in the fire at once. And the engine was apart, so I had no way of going any farther with the wiring harness. But, finally stuff is happening again.
So, I did have a shot at porting the intake manifolds to match the Tims stage 2 heads
It went pretty smoothly after I got some fresh carbide burrs and a few 60 grit tapered cartridge rolls. Still a little touch up to go, but it matches the heads pretty closely
Spent some time getting the pickup for the trigger wheel mounted. Here I tried to mount the pickup behind the bracket, but then I had to slide it way out to meet the pulley, and it was barely under the nut.
So I flipped the pickup to the front of the bracket. It's adjustable, but I had to trim the back of the bracket so it would sit closer to the case. If I had taken a deeper cut out of the pulley for the trigger wheel there would've been more room. But, sinking the wheel deeper in the pulley also limits the thread of the screws that fasten the wheel. I played it safe.
And got on to the wiring harness
I had assembled the wires to their plugs previously. Next was to route them, so I mocked up each side of the engine.
The CB short manifolds don't make it easy, this wire has to sneak out through the middle of the manifold
And the when the lengths were good, feed it through some larger loom, and shrink wrap the ends.
I've held off on the other side, as I'm not 100% on my coil location. Pretty sure that top center of the rear of the shroud, (front actually ) as it's just out of sight, but I'll be able to reach the wires.
Also contemplating a bulkhead plug, to disconnect the whole harness, but not sure I feel like crimping another 40-50 connections. We'll see, it would maybe be a convenience, but I certainly don't need it.
SD |
esde Samba Member
Posted: Fri Nov 13, 2015 8:28 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Time for a little advice. I had the intention of switching from the scat doghouse shroud to a stock doghouse, and installing a larger type 4 oil cooler. Here it is, in all of it's filthy glory. Bonus, the new sidewinder header clears the thermostat so I can hook the flaps up too..
a peek at how much larger the type 4 cooler is
I have seen first hand the drop in oil temperature when switching back to an original factory doghouse shroud, and when using the larger type 4 cooler. So I'm confident it will help to keep the temps in check, before it was right on the edge..
Of course this has nothing to do with the fuel injection installation except for this
So, the fuel rail and shroud want to occupy the same space. Kind of a bummer, but I'm already planning to modify the shroud to make it work.
I'm not running heat (car has a gas heater for when I need to defog the windows) so the plan is to cut and cap the left and right outlets. Then I will trim the protruding corners. Imagine a cut line along the cardboard I've held up here
One each side of the shroud, the farthest vane feeds the heater box outlet. As long as I open this vane back to the cylinder head (on each side) I won't have any air fighting a dead end, and have full cooling.
So, what am I missing? Is this the long way about it, or is there a better shroud option?
SD |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Nov 14, 2015 8:11 am Post subject: Re: Megasquirt 2 system assembly and installation |
esde wrote: |
SD |
If I remember correctly some have trimmed the bottom of the two ends of the fuel rail at a 45 degree to give enough room for the plugs to connect to the injectors so they are parallel with the fuel rail....if you can understand what I mean.
If you look at Mario's pic in your thread you can see with his endpieces the injectors are turned and have clearance.
It might be easier to get his endpieces otherwise instead of butchering a shroud.
I'm pretty sure there is enough meat on the CB rails to trim enough to get them turned. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
esde Samba Member
Posted: Sat Nov 14, 2015 11:00 am Post subject: Re: Megasquirt 2 system assembly and installation |
Clonebug, no doubt the other manifolds and/or rails would solve the issue. It seems that every picture of the cb manifolds with inboard injectors is using a 36hp style shroud, now I know why. But I already have these, and a small pile of doghouse shrouds to work with. So, I'll see if there's another way..
Honestly doesn't seem like much work, and I'm already committed to welding a shroud for the larger cooler, so..
Probably get started on it tomorrow when the family is out. |
Posted: Sat Nov 14, 2015 1:04 pm Post subject: Re: Megasquirt 2 system assembly and installation |
I would bet you would only have to take a little bit off those fuel rails to make enough clearance.
If you did that you wouldn't have to run that injector wire between the intake manifold forcing you to pull a TB in order to remove the wiring.
I don't know how much time I spent trying to route my wires so I could remove it without disassembling half the engine to get it out........ _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
esde Samba Member
Posted: Sat Nov 14, 2015 2:00 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Ok, I went down to my bench, and see what you are talking about. Trimming the end of the rail will probably allow me to swing that injector to the rear and make the connector access easier. Thanks for the tip. However, the shroud still needs to be neutered. My picture doesn't show it very well, but the injector and rail are pushed over to the outside by that part of the shroud. I read some more about modifying the shroud last night, and am pretty confident that it is going to work out. |
esde Samba Member
Posted: Mon Nov 16, 2015 5:53 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Got to work on the shroud. Here's what was removed
You can see that this is the "vane" that supplies air to the heater boxes. I opened it back up so it will blow at the cylinder heads.
And capped it, needs final welding
And while I was at it, welded the extension to cover the type 4 cooler
Now that I'm sure it fits, I can finish it and continue with the install..
SD |
esde Samba Member
Posted: Tue Nov 17, 2015 8:21 pm Post subject: Re: Megasquirt 2 system assembly and installation |
clonebug wrote: |
I'm pretty sure there is enough meat on the CB rails to trim enough to get them turned. |
Clonebug, thanks for the thought, it seems to have worked out pretty well. A 45º cut wasn't quite enough, so I ground a small radius.
Because of the offset manifolds, I only have to do one edge of each fuel rail. It barely fits, but it does.
I have to decide how to route the fuel line that connects the rails so that it doesn't interfere with the flap linkage bar, and get some nut serts to mount the wasted spark coil to the shroud..
SD |
esde Samba Member
Posted: Tue Nov 17, 2015 8:22 pm Post subject: Re: Megasquirt 2 system assembly and installation |
edit dup post
Posted: Tue Nov 17, 2015 8:50 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Very Nice!!!!
Glad I could help....
That is pretty well exactly what the fuel rail I saw that was modified looked like!!!!
esde wrote: |
clonebug wrote: |
Because of the offset manifolds, I only have to do one edge of each fuel rail. It barely fits, but it does. |
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
