esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Tue Nov 24, 2015 8:19 pm Post subject: Re: Megasquirt 2 system assembly and installation |
found time to get some more stuff done:
Got the shroud welded up and finished. Venturi ring in, and decided on a location for the wasted spark coil.
Painted it and got the flaps mounted
Bolted it all together to check the fit
The new CB manifolds must be a shade taller than the old ones, so the berg linkage arms are now too long. I'll have to shorten them and re cut the threads.
I need to one up with a location for the intake air temperature sensor. The filter top is obvious, but sort of clumsy. I'm the type of guy that breaks little plastic things that stick up, so I'm looking for a better location.
Possibly I could sneak up between the barrels here
so it would sit between the velocity stacks like this, but obviously shorter
And while thinking about this I discovered,
That the gaskets supplied by CB don't do what they are intended to do.
That bit of light is coming from underneath where the gasket is missing.
duh.
So, I also have to block off the fuel filter and distributor. Cut off a piece of 1/2" aluminum bar, and will machine a block off plate, and found a dead 009 to plug the hole. It actually looks like I can knock out the bushing and run a 3/8" tap in it for a breather fitting, nice!
Nice to know the no name 009 is good for something. |
esde Samba Member
Posted: Tue Nov 24, 2015 8:21 pm Post subject: Re: Megasquirt 2 system assembly and installation |
edit dup
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Tue Nov 24, 2015 8:36 pm Post subject: Re: Megasquirt 2 system assembly and installation |
thats some nice work! and it is coming out good!! cant wait to see it finished. _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Nov 24, 2015 9:05 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Mario has a very reasonably priced distributor plug if you are looking for something.
They come with an AN-8 or AN-10 fitting to if you want to make it a vented plug or you can get them as just a plug......
I have the AN-8 vented plug and put a cap on it for now.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
esde Samba Member
Posted: Tue Nov 24, 2015 9:11 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Yeah, I know he does. But the box of taps was next to the dead distributor, as if it was meant to be..
and it doesn't cost me squat. But I will cut it down so it just peeks out, and probably use a stock clamp to hold it. |
esde Samba Member
Posted: Wed Nov 25, 2015 7:13 pm Post subject: Re: Megasquirt 2 system assembly and installation |
distributor plug done. Easy, took a few minutes on the lathe, and running the tap in after knocking the bushings free. Hardest part was digging up a new o ring
little to do finishing up the fuel pump plate
I've decided to use the big bulkhead connector for the wiring harness, so that'll chew up some time. Has anyone ever come up with a semi standard schematic for what pins are to what wires? I know it's a long shot, but..
SD |
Chip Samba Member
Posted: Wed Nov 25, 2015 8:02 pm Post subject: Re: Megasquirt 2 system assembly and installation |
I ended up getting rid of my big master plug in my latest wiring redo. It just didn't provide enough terminals and in the defeated the purpose of having the main plug. Everything is looking good!
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Nov 26, 2015 6:55 am Post subject: Re: Megasquirt 2 system assembly and installation |
The Molex big plug I used from page 1 has 31 terminals, and you can get different pins for different gauge wiring. There's also a 14 pin version in the same size shell. I'm going to run the Microsquirt which only has 35 pins in it's connector. What I did is make a big diagram "key" listing to go with the msextra picture diagram. It's just a big number list matching my plug wire number with the Microsquirt plug. As long as I don't lose the key it's easy peasy. I did have to improvise with pins 32-35 though.
First, I scribbled up a picture of what my harness needed to be
Then, I wrote this up to match. It's made it pretty easy while you take breaks and come back to the wiring. You just match numbers and wire color.
Like Chip said, if you don't plan it out real well you'll come up short. I was able to come up with a bunch of unused pins, that I pre-wired and labeled on my key.
I got all the stuff from waytekwire.com. I got their $23 Weatherpack/"barrel terminal" hand crimpers too. You have to be careful you get the matching stuff, it's easy to order the wrong thing. The bulkhead nut had to be bought in a pack of 5 so I have 4 extra. I can throw one in an envelope if you want and get you part numbers. Pm me if you need _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
esde Samba Member
Posted: Thu Nov 26, 2015 10:15 pm Post subject: Re: Megasquirt 2 system assembly and installation |
After some more turkey and a nap, tapped the top of the passenger side throttle body for the intake air temperature sensor. Tap size is 3/8npt, and the tap isn't square to the throttle body; the plug end of the sensor is tipped out slightly. I had to do it this way or you'd never get a wrench on the sensor to turn it in
So much for "always modify the cheapest part"
(which I generally agree with)
It seems like a decent location, certainly out of the way and protected
If it doesn't work out I can always put a plug in it.
SD |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Fri Nov 27, 2015 5:15 am Post subject: Re: Megasquirt 2 system assembly and installation |
looks nice and neat there! _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
esde Samba Member
Posted: Sat Dec 12, 2015 8:10 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Finished the engine harness tonight. It took a while as I wasted a few of the weather pack terminal ends learning how to use the crimper, and then I didn't have enough of the 20 gauge pins for the bulkhead connector..
Here's an OK crimp on one of the terminals
I didn't fork out $100 bucks for the real weatherpack crimp tool, I bought the $45 knock off. It's entirely possible the right tool makes the job a little easier, but I doubt it. You have to hold the wire in terminal, AND the silicone seal, keep the stripped end in just far enough (all this with one hand mind you) and then line it up with the jaws of the crimper, which is stepped, and then quickly hope you get it right. I imagine it's impossible if you have bad eyesight or shaky hands.
Then pick what wire goes where, click it home, and make sure the corresponding wire is in the correct spot.
I made a little chart, will add it to my notes.
Checked all of the wires for continuity, everything is good.
Here's the finished product:
So, I have to finish a bus project to free up my lift. Then I can get the car on, finish the fuel system lines, and start the actual installation. Hopefully I hear from Mario in the next few weeks so I can get a base tune to start the car.
SD |
Posted: Sun Dec 13, 2015 8:12 am Post subject: Re: Megasquirt 2 system assembly and installation |
esde wrote: |
SD |
I had a tough time getting a good crimp with the two crimpers I tried.
I ended up putting a tiny drip of solder on it to make sure it wouldn't pull out.
I used a couple of those weatherpak connectors on my buggy.
One for the EBC connector and another for connecting my reverse light to the removeable bumper in back.
I am going to try the DEUTSCH connectors next time since one of my crimpers came with a die for them. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
esde Samba Member
Posted: Mon Jan 18, 2016 3:54 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Pulled the beetle out of it's winter storage spot and got started this past weekend. Fortunately I've just gotten a lift and it makes some of the tasks much, much easier.
I had started working on the tank before I sent the car away months ago. I am using the CB tank outlet that is just one AN-8 fitting, and have my walbro GSL392 pump mounted in the same place the old carter pump was. Here you can see how the lines will route around the steering. I wanted to put the filter here also, but space is getting tight. It might go under the rear shelf where the hard line transitions to braided.
For a return I added an AN-6 bulkhead fitting to the top of the tank
In this location, you can reach a 3/8" flex head ratchet into the tank to tighten it, and it misses the sender arm.
And I have cut two openings into the tunnel, to help install both 3/8" stainless lines
Little at a time. SD |
esde Samba Member
Posted: Fri Jan 29, 2016 9:22 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Thought about a few ways to run the hard line, and came to this. I've brought it out of the tunnel where I cut the access, and routed it between the frame horns and trans, and then under the package tray. The connection to braided hose will be at the firewall.
In the front I brought it out on the passenger side
I would have preferred a different angle, but bending the 3/8 stainless without kinking it, and guiding it in the tunnel, well I'm just lucky to have gotten this piece in. Waiting on a 90º AN-6 union to complete the supply plumbing, and then I'll do the return.
SD |
esde Samba Member
Posted: Thu Feb 18, 2016 8:37 pm Post subject: Re: Megasquirt 2 system assembly and installation |
I've been working on this evenings and lunch hours, it's at the point where there are a thousand little things to track down and complete. I have the fuel lines in completely, the pump fired up, and only one leaky fitting to deal with. It's on a short hose that I can remove to fix easily.
I brought my fuel lines out of the tunnel right before the nose cone mount, and they go up between the trans and frame horn, and strap to the underside of the parcel shelf. It looks vulnerable, but is bent pretty tight, and I welded a piece of steel over it for good measure
The return is on the driver side, with a short hose to the regulator
You can see the 90º bend that is not connected behind the fuel rail, this hose connects both fuel rails. I had to change this end out for a 45º end to make it all fit nicely. If I had a stock cooler it would fit, but the extra width of the type 4 cooler makes space tight back there. Here you can see the front connections. The return comes out just behind the beam, and loops up through the steering box access cover to the tank. The pump is connected to a 10 micron filter
Here is the shot from underneath. I have to make a bracket to hold the line from the tank to pump secure to the stabilizer mount so there's no chance it rubs the tie rod
Wiring harness is in the car, finally. I had a dyslexic moment and drilled this hole on the passenger side before realizing I F'd up. D'oh!
I originally was going to use the injector bosses in the CB throttle bodies, but realized that the fuel rails would end up wider than the engine bay. So, I made some plugs for the unused ports. I was going to use some orings and set screws, but hell I have a lot to get done, so they got epoxied in place.
O2 sensor bung welded in, and sensor mounted again. Ran the wire from the sideband back to where the megasquirt will live, driver side under the rear seat.
Throttle bodies are just set in for the pic here. I have to trim the Berg linkage rods by a half inch, as for some reason they are too long now. It's probably the manifolds..
Anyway, getting closer. I'm struggling with using the MS and mac together for some functions, like loading the tune, but I will get it. Soon man, soon, spring is around the corner…
SD |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Feb 18, 2016 9:22 pm Post subject: Re: Megasquirt 2 system assembly and installation |
Looks nice.
Always has to be 1 mac user in the office. |
esde Samba Member
Posted: Mon Mar 21, 2016 4:37 pm Post subject: Re: Megasquirt 2 system assembly and installation |
duplicate
esde Samba Member
duplicate
esde Samba Member
ps2375 wrote: |
Well this has been the single biggest stumbling block, running everything on a mac. But I've got it figured out now, and I could do it again quickly, now that I know the bugs. Seems many have tried but they either gave up or didn't document how they got it working. In a nutshell, tuner studio for MAC is an older version of tunerstudio, and has a few bugs. I had no luck importing a .msq file, or opening an archived tune. TS wouldn't recognize the files, until after I registered the software (DOH!), but then it was convinced the files were corrupted or improperly formatted. I'm "computer challenged" so at this point I was dizzy and about to quit. Phil from tunerstudio suggested I try the Linux version, which is a more current version of software, but more difficult for an idiot like me to install. This version crashed a few times, till I figured out why. Then it loaded the tunes no problem, but wouldn't connect to the MS unit. I eventually figured out that the software connection default was "bluetooth", and it kept jumping back to bluetooth whenever I changed it. Let me tell you that having the linux and mac version of the same software saved on the mac didn't help. As soon as I canned the mac software, the connection stuck, tunerstudio connected with the ms unit, tune loaded, and I was happy. Headed over to the shop tonight to make up a panel, and mount it under the passenger side of the back seat.
SD
