Sandjunky Samba Member
Joined: August 03, 2015 Posts: 292 Location: New Mexico
Posted: Sun Sep 06, 2015 11:37 am Post subject: My Chenowth Build/Resto project... |
I figured I'd start a build thread instead of starting a new thread for every question I have.
So now I have a size/configuration problem. The rail came with high back poly seats, which I like. The previous owner had them bolted to the floor pan, which I don't like since it doesn't seem safe; I want my seats mounted to the chassis and not a sheet metal floor pan.
The problem is I'm 6'2" and with the seats mounted to the floor pan they are too straight up and my head rides very close to the roof bar so I can't just fab in flat seat mounts. I want to mount the seats leaning back a few degrees.
As it is now, roughly:
How I need it, which gives me more head room and a better shoulder belt mounting angle on the bar behind the seat:
The problem though is to mount it where I need it the bottom of the seat is below the floor pan and I lose ground clearance.
I can use 1.25" tubing and fab in seat mounts that mount from the bar in front of the seats back to the torsion housing. and then plate it to protect the seats and my ass.
This opens a whole new can of worms. Even mounted to the floor pan, sitting in the seats puts the steering wheel on my legs so leaning back is going to make my legs ride higher and make it impossible to steer. To raise the steering wheel I am going to have to remove and relocate the X-brace supports for the front of the rail.
All of this could be avoided if I can find high back seats with a little more lean when mounted flat. Then I could fab in flat bars that are level with the chassis instead of dropping the mounts below the floor pan.
Even with all of that I still only have about 2" of head clearance so I'm probably going to have to cut the roof bars out and bend new ones to towards the center and go with the T-Top option.
Any ideas? I don't mind cutting and fabricating, but if there is a simpler solution then I am open to suggestions.
Thanks |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Sun Sep 06, 2015 12:57 pm Post subject: |
I had the same problem.
It hurt but I cut the roll cage and raised the whole thing 8"
With yours it looks like you cut probably just cut out the A post and roof bars, leaving the B post and it s,bracing alone and fab a new roof bars and a taller A post.
You can rais your dash post at the same time and solve the steering wheel issue. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
Joined: August 31, 2013 Posts: 12847 Location: North Carolina
Posted: Sun Sep 06, 2015 1:16 pm Post subject: |
How about elevating the leading edge of the seat, this would lean the seat back & could also reduce the tendency to submarine or slide forward. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
cbeck Samba Member
Posted: Sun Sep 06, 2015 3:08 pm Post subject: |
Corbeau and mastercraft both make seats that recline and look to be not quite as tall in front but I would want a bar/bracing for the back to keep recline mechanism from giving. My poly seat mounts hang down about 2 inches and I forced my floor pan to conform before I bolted it down. When I cut mine in half I intend to install suspension seats then fab my new roll bar to fit me. |
Posted: Sun Sep 06, 2015 3:41 pm Post subject: |
Sorry, you already covered the issue with raising the leading edge. I personally would shitcan those seats, there is absolutely no support in those things & the threaded bosses will pull out of them as you tighten them down & they'll likely toss you out or fold backwards & break your back in the event of something serious. I'm almost thinking about a bomber style seat with good padding. That way you could bolt the rear edge directly to the floor & raise the front. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2644 Location: West Coast (Michigan's)
Posted: Sun Sep 06, 2015 3:56 pm Post subject: |
I have fiberglas seats which are next step up from crappy plastic seats like you got. I wanted to lean mine back, but there were all kinds of things making it tough. For one the steering wheel went further into my crotch and also the top of the windshield frame will be right infront of my face. I fabbed up some brackets to lean back the seat which bolt to my 1/4" aluminum floor(pretty safe) and I'll just have to deal with the inconveiniences that go along with it. Hoping someday I will have some money to pick up some compact suspension seats that work better.
_________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Sun Sep 06, 2015 5:24 pm Post subject: |
Thanks for the suggestions guys. I haven't thought about raising the A-pillar. Its easy enough, but I'd like to leave that as a last resort option. I only have a 1.25" bending die so buying a 1.5" die would be $$$ that I could put into a Beard seat or something similar.
I've thought about it all day and I think I can fab in proper seat mounts with the 1.25" tubing that would only take away 2" of ground clearance and it wouldn't have any catchy edges. I can also integrate a battery carrier. I didn't like the floor pan the builder used anyway. It doesn't mount properly at the torsion housing since the center bars that mount the engine sit lower than the edge bars that connect to the torsion housing leaving the rear of the pan unsupported. You can see a nasty battery acid stain where the battery (likely also mounted to the floor pan) took some damage.
Anything different puts my head 1" from the roof bar and I know my driving well enough to know that is going to hurt! |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Mon Sep 07, 2015 7:33 am Post subject: |
Those seats can cause serious damage to your back. Bite the bullet now and design for suspension seats. Makes a huge difference in driver comfort, safety and keeps your body and arms from flying around. I am 6` 3`` and raised my roof about 4 inches, so I have plenty of clearance with a helmet . _________________ rant _ classified ads with out pics are almost worthless |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Mon Sep 07, 2015 12:15 pm Post subject: |
I had the same issue. I'm 6'2" and 285. No headroom, and the low windshield and those crappy seats combined to give me a really bad neck and back issue. I cut out my rear seat mount, used 3/16th x 2" steel bar and bent new rear seat mounts that sit below the rails. Mine sits high and doesn't go 'off-road' so it's not an issue.
Find a set of Miata seats on craigslist, or better yet, wider search with 'searchtempest.com'. $100 and your back will love you for it.
I still plan to cut my "A" pillar and raise my windshield about 4" this winter. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Mon Sep 07, 2015 2:41 pm Post subject: |
Axitech wrote: |
I still plan to cut my "A" pillar and raise my windshield about 4" this winter. |
Miata seats! Great tip, thanks. |
griffs68 Samba Member
Joined: August 01, 2015 Posts: 47 Location: Bakersfield, CA
Posted: Tue Sep 08, 2015 7:41 am Post subject: |
they make leaned back fiberglass seats I cant remember who sales them but they are made. just the back leaned back and seat flat |
Posted: Tue Sep 08, 2015 2:48 pm Post subject: |
griffs68 wrote: |
I think I'm just going to spring for some sort of suspension seats. I already have lower back issues so I might as well make it as comfortable as possible.
Does anyone have experience with the EMPI suspension seats? They look like Beard seats, but a hell of a lot less expensive.
I got a killer deal on the Beard in my mini and I absolutely love that seat! |
cbeck Samba Member
Posted: Tue Sep 08, 2015 4:37 pm Post subject: |
My freinds mastercrafts have been in his mudtruck forever, his 100$ seats off ebay have stitching problems after one year. corbeaus start at 199$ |
dustymojave Samba Member
Posted: Tue Sep 08, 2015 5:42 pm Post subject: |
People I know who have bought the EMPI suspension seats were real happy at 1st. But they have all quickly complained that the seats were falling apart and they regretted buying them instead of spending more $$ for something to last better. _________________ Richard
SoCalBajas Member
Posted: Tue Sep 08, 2015 6:38 pm Post subject: |
dustymojave wrote: |
People I know who have bought the EMPI suspension seats were real happy at 1st. But they have all quickly complained that the seats were falling apart and they regretted buying them instead of spending more $$ for something to last better. |
Copy that. Is anyone else running Miata seats? Judging by Web photos it looks like they are lower profile in the seat bottom than the poly seats that I have so I would have better mounting options and possibly the ability to slide the seat.
Probably better to spend money in the seat department if you're going to have stock suspension for a while. |
Posted: Wed Sep 09, 2015 1:11 pm Post subject: |
Man I hate analysis paralysis! SEATS!!!
Cheap reclining Miata seats ~$219 per pair. In that price range I figured they would last about a minute off road.
EMPI Beard knock offs- like dustymojave pointed out... durability isn't there.
Kirkey- EXPENSIVE! Worth the price? Definitely. I know a lot of people running them in the online minibuggy community. The problem is I don't want to spend $800-$1000 for seats/covers.
These classic bucket seats are cheaper, but I'd still be in the $600-$700 range. I like them since they are very low profile in the seat and I can mount them flat and level to the pan with an 18 degree tilt. From an aesthetics POV I think the classic seats look better in a rail.
http://www.summitracing.com/parts/kir-41700v/overview/ |
Posted: Wed Sep 09, 2015 7:08 pm Post subject: |
I paid $100 for leather Miata seats( no speakers). They came with sliders, and recline/tilt forward for behind seat access. I rarely go off-road, except for dirt roads and sand roads, but do have about 12k miles on since installing them. I put a nice set of Cabelas seat covers on them, and I use a tarp to keep rain and sun off when I am not driving. They are holding up very well, which is sort of remarkable when you consider that my fat butt is nearly 300 pounds. Yeah, I'm fat!
Miata seats will last. Also, Mazda is not the only car maker that made a smaller seat. Toyota, Nissan, the domestics all probably have seats that will fit. Take some measurements and go to the local junkyard to look around.
Bottom line: used seats from searchtempest are a lot less expensive than new Beards, and you aren't paying shipping. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
Posted: Thu Sep 10, 2015 12:10 pm Post subject: |
I've decided to go ahead and use the seats I have for now instead of spending the budget on seats. I still need shocks, brake lines, possibly brakes, and a few other things.
I started fabbing in some seat mounts. This is what I have so far.
I made the mounts flush with the bottom of the seat so that I could get the seat low enough to be comfortable without losing too much clearance and this saves 1.25". I'll also place the bottom to protect the seat.
Turned out to be a pretty good fit.
Clearance.
I'll fab in a tube across to tie into and then gusset that tube to the center tubes that it will just clear. That should give me plenty of strength during bottom outs.
I'm hoping I can pick up some tubing and finish up next weekend so I can paint it and start reassembly. |
Posted: Thu Sep 10, 2015 10:40 pm Post subject: |
That's OK for dunes. I don't recommend doing that for any other sort of offroading. _________________ Richard
SoCalBajas Member
Posted: Fri Sep 11, 2015 1:04 pm Post subject: |
That's OK for dunes. I don't recommend doing that for any other sort of offroading. |
I see where you're coming from, but I think it will be fine. It is going to be solid with each seat being welded at 6 points to the chassis and plated on the bottom.
The pic above makes the clearance loss look really bad, but that is because the outside bars raise up to connect to the torsion housing. In the pic the rail's center bars are on the other side and the seat mounts and they are only about 1.5" below that. |
