murdercrkal Samba Member
Joined: December 05, 2010 Posts: 5 Location: Damascus, Oregom
Posted: Fri Sep 11, 2015 7:58 pm Post subject: Trans Problem |
Can anyone tell me what's going on with reverse? Start the car, shift into reverse, and after the vehicle begins rolling, push in the clutch with shifter still in reverse---car comes to an abrupt STOP. Does it every time. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Fri Sep 11, 2015 8:11 pm Post subject: Re: Trans Problem |
murdercrkal wrote: |
I'm just trying to figure out how you can have the transmission in reverse with the motor running and roll the car all while the clutch is engaged. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Posted: Fri Sep 11, 2015 9:15 pm Post subject: Trans Problem |
Sorry, probably did not clearly describe the problem. While backing up under power every time I push the clutch in the car comes to an abrupt stop. |
Posted: Fri Sep 11, 2015 9:27 pm Post subject: |
The only thing I can think of is that the clutch pedal is somehow binding up on the brake pedal - but that would happen in any gear and not just reverse. You've got a problem I've never heard of. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Posted: Fri Sep 11, 2015 9:40 pm Post subject: Trans Problem |
The owner of the shop that rebuilt the trans scratched his head and had a one-word comment "Bizarre". Can't wait to see what he finds when he cracks the trans open. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Fri Sep 11, 2015 11:19 pm Post subject: |
Release your hand brake.
Adjust your brakes so they aren't dragging when your foot is off the pedal. _________________
Posted: Sat Sep 12, 2015 7:09 am Post subject: Trans Problem |
Did both. Bear in mind it only does this when the trans is in reverse. Rolls back with no problem at all in nuetral. If it was the brake it would stop suddenly in neutral as well as in reverse. ??? |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Sat Sep 12, 2015 9:23 pm Post subject: |
Common problem when there is extreme slop in the pinion bearings. Once you let off on the gas in reverse the pinion gets sucked into the ring gear and binds up. If you have put many miles on the box with it this way the ring and point are probably toast. |
Posted: Wed Sep 23, 2015 8:14 pm Post subject: Trans Problem |
Never found out the source of the problem, but the shop that put in the rebuilt made good on it and I have another trans in and it feels perfect. Hats off to Always VW in Portland! |
