benchracer1 Samba Member
Joined: September 24, 2006 Posts: 583 Location: ramona
Posted: Tue Sep 15, 2015 10:01 am Post subject: Jumped out of 4th gear |
had a shift rod coupler come loose last night and the car jumped out of 4th gear a couple times. Does two or three times popping out damge the slider or gear teeth? I got in to late last night to tighten it and run around the block and I had to leave town early this morning for 5 days. hoping to tighten it up and be back on the road......Steve |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4857 Location: sanger ca
Posted: Tue Sep 15, 2015 10:48 am Post subject: |
The coupler will not hold it in gear, the slider is already worn _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Sep 15, 2015 11:05 am Post subject: |
I'm kinda thinking that the coupler wasn't pulling it all the way in gear. It was very loose. I'm hoping that is it...Steve |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Sep 15, 2015 12:19 pm Post subject: |
benchracer1 wrote: |
Normally when a car jumps out of 4th, there are multiple problems. We just did a bus that needed internal transmission work, a rebuilt shifter, had a bent shift rod, and had a blown up coupler. Once all of that was fixed, it worked perfect. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Tue Sep 15, 2015 1:16 pm Post subject: |
Yeah, I just put a new (used) slider and gear in it. It was working great til the coupler came loose. I guess I have 2 posible outcomes. Tighten the coupler and all is good or tighten the coupler and it still jumps out of gear.....lol.just really don't want to go back into it..steve |
Posted: Tue Sep 15, 2015 1:49 pm Post subject: |
https://weddleindustries.com/products/1000171/1001449
Here you go, gearboxes are starting to get pricey _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Tue Sep 15, 2015 7:09 pm Post subject: |
I may end up going that way if it still jumps out. Sux to have a problem like that as your heading out the door for 4 days. I guess I'm just hoping that if the loose coupling was the reason (not getting it all the way in gear) it happened that it didn't damage the gear or slider....Steve |
Doug Berg Samba Member
Joined: March 18, 2015 Posts: 137 Location: Fallon NV.
Posted: Tue Sep 15, 2015 8:36 pm Post subject: |
Did you put the new / used slider & gear in,,, cause of this problem??? previously jumping out of gear??? (and the problem is still not fixed???) Short throw shifter & no traction bar??? "pulling itself out of gear"???? (used mounts???) something must be pulling on it for the coupler to come loose!!! Doug... |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Wed Sep 16, 2015 5:49 am Post subject: |
Couple Q's come to mind....
Did you check the 'dog' teeth on the gear before installing it?
Did you install the new or used 3-4 slider facing the correct way?
Did someone fix Doug's key board so the CAPS LOCK wasn't stuck on? |
Posted: Wed Sep 16, 2015 6:42 am Post subject: |
As much as I hate to admit it, my buddy that was helping me tightened it finger tight and forgot about it. This is why I generally work alone. Yeah it was popping out before. Groove on slider is facing 4th. I'll tighten up the coupler Saturday and post what happens |
Posted: Wed Sep 16, 2015 7:10 am Post subject: |
Exessive movement in the mainshaft will also cause it to jump out of fourth gear also _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Sep 16, 2015 7:58 am Post subject: |
It was a good tight trans except for fourth. I don't know the history of the gearbox or why it originally jumped out gear. I didn't find anything suspect inside, but Ive only done maybe a half dozen trannys. Will post results saturday....Steve |
Posted: Sat Sep 19, 2015 7:53 pm Post subject: |
Quick update. Still jumps out of 4th. Back at it in a couple weeks....Steve |
Posted: Wed Mar 23, 2016 8:45 pm Post subject: Re: Jumped out of 4th gear |
I guess im going to pull the trans next week and rerepair 4th gear. It actually stays in 4th fine just cruising down the road. Not until you start to put a load on it does it pop out. You can actually put your finger on the shift lever and it stays in even under load. Gotta be something very minor. IM definitely going to make sure the shaft isn't moving in the case. Anybody got any idea on what to pay particular attention to? ......Steve |
Bruce Samba Member
Posted: Thu Mar 24, 2016 1:16 am Post subject: Re: Jumped out of 4th gear |
Due to the angle of the helix cut gears, the main shaft is pulled forward when you apply power. This moves everything on the main shaft. The fork is not attached to the main shaft, so effectively, the fork pulls it out of gear when the shaft moves forward.
Look to see if the main shaft ball bearing has pounded into the nose cone. Every 73 and later gearbox I open up has some degree of pounding. I've measured the movement to be over 1mm. _________________
Posted: Sat Mar 26, 2016 10:24 pm Post subject: Re: Jumped out of 4th gear |
I'll post back after I get it apart....Steve |
Posted: Thu Sep 01, 2016 8:57 pm Post subject: Re: Jumped out of 4th gear |
well after a year i got it apart. To me the adjustment looks good. I have posted pics of 3rd, neutral and 4th. tomorrow ill disassemble the stack and post some more pics....Steve
Posted: Fri Sep 02, 2016 8:24 pm Post subject: Re: Jumped out of 4th gear |
damn, i guess missed this. I guess the slider and hub are done. I feel a bit stupid but live and learn.....Steve
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Sat Sep 03, 2016 7:45 am Post subject: Re: Jumped out of 4th gear |
What do the teeth look like on fourth gear? Can you cut the fat teeth off the synchro cone? |
Posted: Sat Sep 03, 2016 9:26 am Post subject: Re: Jumped out of 4th gear |
I think my best option is a new synchro hub and slider |
