babyhummer Samba Member
Posted: Sat Feb 21, 2004 3:20 pm Post subject: radio or not to radio |
| "Hey", to all thinger's out there. I would like to get some opinions on the radio question. I am debating about putting one in. #1 is it worth cutting the dash for? #2 will you ever be able to hear the darn radio going down the road ? #3 and is it worth for some stranger coming by , seeing it and then taking off with it. I can live with the great sound of the vw engine alone, just wanted to know what others have done. thanks. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6397 Location: Rio Rico Arizona
Posted: Sat Feb 21, 2004 4:01 pm Post subject: |
| I have chosen the no radio route for the reasons you came up with as well as not wanting to damage it or the speakers if out without the side curtains and it rains. |
edgy Samba Member
Joined: January 22, 2003 Posts: 424 Location: Bel Air, Maryland
Posted: Sat Feb 21, 2004 7:00 pm Post subject: |
| My son has a cd player/radio mounted under the dash. It is in a box made just for that. He has speakers mounted in the holes near your feet and in the holes on the sides behind the rear seats. The radio can be heard although the car is noisy when above 60 mph. |
fretless Samba Member
Joined: October 07, 2002 Posts: 72 Location: Vista, Ca.
Posted: Sat Feb 21, 2004 7:09 pm Post subject: |
| Yea, I am going to instale CD/Radio soon. the speakers up front will go where edgy's are. the back one's will be some kind of indoor outdoor speakers. edgy were did your son find that box for the radio? |
g1142y Samba Member
Joined: February 22, 2004 Posts: 4 Location: Chatham, IL
Posted: Sun Feb 22, 2004 11:26 am Post subject: |
Hi All,
Yes, I am a FNG (that's military for Fine New Guy...I cleaned it up.)
I bought my Thing last fall and have been reading the forum for a couple of months...just had to reply about the radio issue. Being an old farm boy at heart, I found a tractor cab radio in a slim plastic case that attached perfectly under the glove box. The speakers are also in the case so it was an easy installation. The case is the length of the glove box and about 2 1/2 inches wide. It's not the best of sounds but plenty good for me. The radio has a casette but probably a number of different radios would fit in the case. Also, I used a short, flexible rubber antenna mounted just outside of the hood cable handle. I sent a picture to Mike Basso who said he was looking into providing these cases. If you check farm stores you will find a variety of options.
Glad to be on board, Gary _________________ Gary |
edgy Samba Member
Posted: Sun Feb 22, 2004 3:58 pm Post subject: |
| Underdash box for radio was from Best Buy. I thing it was about $15 and included the hardware to mount the radio in tte box. We removed the ash tray and monted it just to the right of center. That way it did not interfere with the defroster duct. |
g1142y Samba Member
Posted: Sun Feb 22, 2004 6:38 pm Post subject: |
Edgy,
I think your arrangement would be the best for sound quality. There are speakers & panels made just for those spaces and the spaces themselves should add to the quality just like any speaker in a box. Mine has the advantage of being cheaper and easier overall...but you need to know I generally listen to talk shows rather than music. After all I'm a grandpa from an earlier generation. _________________ Gary |
edgy Samba Member
Posted: Sun Feb 22, 2004 7:35 pm Post subject: |
We made our own speaker panels. Speakers came from Radio Shack. Used 1/4" plywood and covered them with black vinyl. Looks great and sounds fine too.
I suspect you will be able to hear as well as Rush can. |
chinarider Samba Member
Joined: November 08, 2002 Posts: 273 Location: San Francisco, CA
Posted: Wed Mar 03, 2004 5:27 pm Post subject: |
I took my radio out pending a little body work and complete repainting, but the setup that was in there previously was a good workaround for the above mentioned problems.
The stereo was mounted inside the glove box, using velcro to hold it in place, rather than screws through the metal (the bottom of the glovebox has a snug-fitting piece of carpet material, so the velcro does not need to attach directly to the painted metal surface). It stays put, and there's plenty of room to store other things in there, too. The stereo itself has a removable faceplate, but additionally, all of the wire connections are male/female plugs, so you can either take the face off (for quick stops, etc., or take the whole radio out in less than a minute if you plan on parking it long-term).
Honestly though, I find that while I'm driving down the road I tend to listen more closely to the sounds coming from my engine than to those coming from my speakers! |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1542 Location: Nebraska
Stapler123 Samba Member
Joined: March 03, 2004 Posts: 18 Location: Tucson, Arizona
Posted: Sat Mar 06, 2004 10:29 pm Post subject: |
| I've got my radio mouted in the glovbox , but so it looks like a continuation of the dash, except its made out of Stainless steel. It worked out pretty good in the end. I have two 6 inch speakers mounted in the little area under the dash next to your feet.. on the side. When im going really fast "bikini top" I can still hear it, though I wouldn't say its a hi fidelety experience. I'll take a pic tomarrow and link it for yall. |
nthang Sambassador
Joined: February 05, 2003 Posts: 158 Location: Up Stream
Posted: Thu Mar 11, 2004 2:50 pm Post subject: Radio |
Here is what I did: http://www.thesamba.com/vw/forum/album_page.php?pic_id=34335 .
Sound is purely personal. Do you like listening to talk or music while driving?
I like music blaring sometimes, so I installed a cd/radio. You do not have to cut into the dash, though. The opening for the glove box is big enough to install a panel (spot weld) in the opeing and still have room to work the light and trunk release and some storage. You can install the radio and "theft proof" the connections, then, weld the panel with radio in it. That will foil all but the determined theif.
I also installed good (infinity) speakers front and back for quad sound. The front are in the boxy pocket below the dash, adjacent to the plastic foot rest thingys. I made a cover that snugs and screws into that pocket for the 4" speakers. You can do the same in the rear adjacent to the gun mount bracket, in those pockets. Mine are farther back in custom boxes installed in the corners of the back shelf above the motor. A lot of water will ruin speakers. I recommend that you stop and close the lid on the Thing, every time you find yourself driving in a rain storm! _________________ NTHANG, LLC |
74ThingMike Samba Member
Posted: Sun Apr 11, 2004 12:48 am Post subject: prefence really |
| i would put it in the glove box, then you can have tunes and still have the simpicity and sexy apperence it should have |
Posted: Sun Apr 11, 2004 7:38 am Post subject: |
hey ya'll, well i have read all the comments and have decided to put a radio in the glove box since that seems to be a safe area. thanks a bunch to all of you who have shared their thoughts. thanks again.  |
