TX-73 Samba Member
Posted: Wed Sep 16, 2015 7:57 am Post subject: Where to start for sizing? |
It's time to get some tires for the bug - I've gone through a number of posts to try to figure out what size(s) to consider but I think I need some help.
I've got a new set of 5x15 rims with zero offset, here's some pics, as you can see they are about even with the outer fender lip.
The past versions on the car were 205/75/15 on stock looking rims, a bit too big for my taste but did not rub anywhere. However, I do like tires that don't look small for the wheel-wells, within reason.
The car has never generally sat low.
My local tire shop will mount several sizes on my new rims and let me take them home to put on the car, but I'm wondering what sizes are a good start? I know how the numbering translates to diameter, width etc, thinking maybe to start at 185-65-15 or thereabouts?
Any help is appreciated. _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
obesepolice Samba Member
Joined: January 19, 2012 Posts: 151 Location: Ft. Worth
Posted: Sat Sep 19, 2015 7:03 am Post subject: |
Im running 195/65 in rear and 175/65 in front on og sprint stars. The fronts are a little big but i needed tires and they were dirt cheap. Ill go a little smaller in the future. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sun Sep 20, 2015 8:40 am Post subject: |
Considering where your new wheels sit in comparison to your fenders a 195 may be too wide. I'd first try a set of 185/65s.
With a 5 inch wheel I wouldn't go wider than a 185/65 or 195/65 anyways. |
TX-73 Samba Member
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Sep 20, 2015 2:38 pm Post subject: |
I just bought a used pair of 205X70X15 Michelins for the back of my square. I have used 185X60X15 Firestones on the front. I won't buy any less than 60 Series profile tires.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Sep 21, 2015 9:28 pm Post subject: |
Front are 185/65/15 and rear are 205/65/15. No rubbing ever.
But the rears do have a slight bit of poke.
TX-73 Samba Member
Posted: Thu Sep 24, 2015 3:13 pm Post subject: |
That's a bit similar look to the 205 tires I had on the car before. I'd rather keep them within or equal to the fender lines, like the fronts that you have. thanks! _________________ My 1973 Standard Beetle Build SOLD
lolight70 Samba Member
Joined: August 22, 2013 Posts: 160 Location: West Australia
Posted: Fri Oct 23, 2015 5:52 pm Post subject: a |
Going thru a similar process atm
0 offset is a lot different than the std rims,they are et 34(mm) about inch and a half, thats 34mm towards the inside from the mounting face of the rims
Dont go too wide or it will scrape your fender |
ps2375 Samba Member
Posted: Tue Oct 27, 2015 8:21 pm Post subject: |
TX-73 wrote: |
That's a bit similar look to the 205 tires I had on the car before. I'd rather keep them within or equal to the fender lines, like the fronts that you have. thanks! |
Seems looking at my car, that side pokes a tad and the otherside is inside the fender almost as much as that side pokes(maybe a bit less). The weirdness of a 45yr old car. |
