passe Samba Member
Posted: Tue Sep 22, 2015 9:54 pm Post subject: Runs bad when cruising!!! |
My 1641 with c25 cam mildly ported heads.Bosch 019 dizzy. Ict 34's with jets 55/140. It idles fine, pulls fine and strong under acceleration!! But runs bad when cruising mid throttle!!! |
cbeck Samba Member
Posted: Wed Sep 23, 2015 5:29 am Post subject: |
Like a big cam lope? carbs out of synch. |
passe Samba Member
Posted: Wed Sep 23, 2015 8:52 am Post subject: |
I have tried to sync with a snail guage! But I shall try once more!!! |
VWBUGGAH Samba Member
Posted: Mon Nov 30, 2015 11:03 am Post subject: Re: Runs bad when cruising!!! |
My motor would miss at certain rpm and while cruising too...I changed plugs and that solved it...sometimes simplest things work lol...Try changing plugs if you haven't already. |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Mon Nov 30, 2015 11:39 am Post subject: Re: Runs bad when cruising!!! |
Check your idle jets. When you're cruising you are typically on the idle circuit. A small amount of trash can make a big difference. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6031 Location: CONGERS, N.Y.
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Mon Nov 30, 2015 12:17 pm Post subject: Re: Runs bad when cruising!!! |
Have someone push the gas pedal to the floor. Are the butterfly's in BOTH carbs fully open? |
Posted: Mon Nov 30, 2015 12:59 pm Post subject: Re: Runs bad when cruising!!! |
sounds like the LINKAGE isn't synced. Just because it's synced at idle, doesn't mean it is at part throttle. You must check this. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon Nov 30, 2015 2:09 pm Post subject: Re: Runs bad when cruising!!! |
John I think check the cable is Fix car lesson #1. I myself forget it.
Loose linkage or cable can cost a few hp and drive you nuts trying to figure it out.
I went crazy because my carbs were racing like crazy whenever I stopped. Timed the car, adjusted the mixture, adjusted the valves, used the snail synchronizer , got the best idle I ever had. Got in the car ran great to the next stop light, same problem. This time I did not shut the engine off and when I opened the hood it idled perfect !!!!!!!!! I had a rain deflector that caught the rain that came from the hood louvers, it got loose and was lightly hitting my linkage. I ripped it out an threw it as far is I could! _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
rgdedge Samba Member
Joined: October 17, 2006 Posts: 862 Location: Seymour, TN
Posted: Tue Dec 01, 2015 8:02 pm Post subject: Re: Runs bad when cruising!!! |
My 36mm delloratos started cutting out at cruising speed a few years back. I tried cleaning them, checked the linkage, plugs, points. It ended up being lean at cruising speed due to the ethonal in the gas. went up a size on the idle jets and its running great like it always has for the last 25+ years.
Tim _________________ ()o\|/o() |
