Rippers Samba Member
Joined: September 08, 2011 Posts: 255 Location: London, England
Posted: Sat Sep 26, 2015 2:46 am Post subject: '63 6V Starting issues |
My newly acquired '63 1200cc bug is on all original 6V
The seller told it it started 'occasionally' it didn't start when I saw it but the deal was good and I wanted it so its my problem to fix..
Now I have searched and I realise this is a process of elimination.
The previous one told me he bought a new battery to fix the issue and that didn't work and he was convinced the bush needs changing on the starter in the gearbox housing and supplied one with the car.
I however am not convinced.. yes the bush probably doesn't help and I will change if needs must. The starter doesn't click or even make an noise. I haven't taken the starter off yet to bench test and will be doing that later today.
I think possibly there is an electric fault. The reason I say this is the battery when on charge with the charger connected says that battery needs charging and sits at 6.2v. I tried taking the cars wiring loom leads off the battery when charging and the charger says he battery is fully charged. Could this be due to something earthing out? or a bad earth? The battery strap on the battery is brand new and looks to be nicely connected to bar metal, I will check the gearbox strap today too. Anything else to look at off the tops of your heads?
Can you see anything obviously wrong with the way this is wired.. haven't checked the wiring diagram yet
Any help or pointers would be greatly received |
carcrazed Samba Member
Posted: Sat Sep 26, 2015 6:27 am Post subject: |
The way it is wired looks correct. It could be a number of things. Make sure you are getting 6 volts at the starter when you try and start it. If you are, then I would suspect the starter is bad. If not, something else is not supplying the voltage to the starter or solenoid. From there, work your way back to the ignition switch and make sure all wires are on there and hooked up correctly. As said many times here on the Samba...check your grounds as the 6 volt systems are VERY finicky about having good, clean grounds. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Sat Sep 26, 2015 6:30 am Post subject: |
There was another wore hidden in view of the first pic
Posted: Sat Sep 26, 2015 7:02 am Post subject: |
Progress so far
The bush looks fine to me!?!
The starter doesn't look too old and nice to see its a Bosch
With the battery out of the car I tried a positive lead to the push connector 50 and negative side of the battery to the main post and nothing its like the starter is dead. Am I testing it correctly?
Being this is a Bosch and fairly new looking is it repairable at home DIY? at first glance they are incredibly expensive to replace |
grandpa pete Samba Member
Posted: Sat Sep 26, 2015 7:19 am Post subject: |
The starter ALWAYS has battery and ground on it !!
You have to cross the big battery terminal to the terminal with the small wire on it with a screwdriver to simulate turning the key
Be careful the starter will try to pull itself out of your hands while doing this test .
you should have two people
make shure you cross to the top double terminal and NOT the single bottom one _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Sat Sep 26, 2015 7:47 am Post subject: |
Ok so if I touch the positive on the male tab the solenoid pops out fine
If I put the positive on the large outer threaded connector and put the screwdriver across this and the tab, solenoid pops out a bit erractially and it doesn't turn
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Sat Sep 26, 2015 8:15 am Post subject: |
Yes the starter will not turn when it's not mounted in the car unless it's a self-supporting starter.
The bushing in the bellhousing is what keeps the starter armature from binding when the starter is installed.
You can do that test with starter installed, just make doubly sure that the transmission is in neutral and the parking brake is set. If you leave the trans in gear you will run yourself over when the starter cranks the engine.
What are you using as your power source? A battery charger ain't gonna do it.
With starter installed and connected as it should be, bridging the 2 big terminals with a screwdriver should make the motor run without engaging the solenoid (i.e. motor will spin but engine won't crank). Be prepared for big spark show when you do this, don't hold onto the metal part of the screwdriver, and be sure not to ground the metal part of the screwdriver while it's in contact with the battery-connected post or you will smoke the wire and weld your screwdriver to whatever ground point you touch.
Jumping the big terminal from battery to the spade terminal where the ignition switch wire connects will make the starter and solenoid operate as if you turned the key, i.e. solenoid will activate and when it reaches the end of its travel the motor should turn, this one will crank the engine.
You see the two big posts on the back of the solenoid? One of them gets power from the battery. The other one has a very short braided wire that runs into the solenoid. Those posts enter the case of the solenoid and have contacts inside. When you hit the solenoid with 6v at the spade terminal, it kicks out the starter shaft and at the same time moves an internal contact which bridges those two posts inside the solenoid which shunts 6v direct from battery to motor. So when you bridge those two posts outside the solenoid, you are just sending power direct from battery to motor without activating the solenoid.
If it works properly in this test, you can start looking at voltage drop in the wire from the ignition switch. Also your trans ground strap needs to be in good shape for the starter to work reliably. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sat Sep 26, 2015 9:19 am Post subject: |
More progress, thanks for the replies so far!
OK I put the starter back in, cleaned up the tranny ground and still nothing doesn't even make a click.
I heard a multimeter to the male spade tab (50) and other side to ground and asked my son to turn the key to the starter and I got 6V.. so now I'm really confused
I searched and someone mentioned putting a lead directly between the male spade tab (50) and to the 6V directly on the battery.. and it spun and fired up!
So now I'm really confused if the starter and its bush are ok, the switch is putting 6V yet doesn't start it. How do I test the switch properly?
Am I missing something? can someone clever please tell me whats wrong pretty please |
Posted: Sat Sep 26, 2015 9:34 am Post subject: |
Rippers wrote: |
This may point to a sticky solenoid, where when you supply it with full current direct from the battery it activates no problem but the current coming via the ignition switch is insufficient to trip the solenoid. The right way to fix this would be to have the solenoid rebuilt and cleaned up internally. The less right but very effective way to get a lot more life out of things is to wire in a relay to the circuit so that the wire from ignition switch is merely tripping the relay (which doesn't require much current) and the relay shunts power directly from battery to terminal 50 to trip the solenoid. _________________ 1965 Volkswagen 1500 Variant S
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Sat Sep 26, 2015 9:48 am Post subject: |
I had a similar problem with my starter, also a rebuilt Bosch. Sometimes it started, sometimes it didn't. When I went under the car to jump the terminals, both the solenoid and the starter tested fine. Cleaned all the connections on both ends, checked the battery and the ground strap. Thought it was the switch but the meter showed it was getting full power at the starter. Took the starter off and once all the wires were disconnected it was clear that the post on the solenoid was not stationary. It moved in and out, left and right, up and down. Tracing those erratic start gremlins can be a real pain but there's really only so many things it can be. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
Posted: Sat Sep 26, 2015 9:55 am Post subject: |
Got the bugger!
Dry/corroded joint on the regulator lead it was literally rattling around inside the housing
Bit of plumbers flux and soldering iron and it turned from the ignition switch
Happy days! |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Sep 26, 2015 10:07 am Post subject: |
Typical and easy mistake..
It had a voltage drop for circuit 50 in this case by way of B+.
Improper testing with a volt meter can give misleading results..
High resistance can still allow proper voltage... but will drop the current flow..
Think of this example.......
A wire is damaged has one tiny strand left...(high resistance). when tested with a meter.. it can still have the correct source voltage... but load it up with say a bulb.. and it doesnt light...
Thats voltage drop 101....
Dirty or failed connections... OR a bad ignition switch..
a very very common 6 volt issue..
Class dismissed.. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat Sep 26, 2015 10:09 am Post subject: |
Glad I didn't have to fork out for a Starter motor among things |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sat Sep 26, 2015 1:02 pm Post subject: |
Well do not stop! Other end of that cable at starter solenoid has same junk terminal badly put on it, needs to be soldered or replaced with proper factory swedged on terminal.
NEVER test starter without rear bushing support or risk damaging the starter. Also check front bushing in the starter and brushes is a must. Still since you did not get a solenoid "click" the problem would not be the bushings or brushes.....
Polish clean the surfaces of the starter and transaxle for a good ground and apply dielectric grease to keep oxygen and thusly corrosion away fro as long as possible.
Remove the starter solenoid and give it same cleaning and greasing so it grounds to the starter.
Keep going thru the rest of the wiring cleaning, soldering if need be and greasing. _________________ In Stereo, Where Available! |
Posted: Sun Sep 27, 2015 5:07 am Post subject: |
Well the problems continue
Whilst the starter is now working, it is very slow and nit quite enough to get the engine started.
I assumed I had flattened the battery with all the mucking around but the time I found the wire at fault.
After a nights charging it is still slow, I hooked up my wire to the male spade (50) on the starter again and put it straight onto the battery and it was definitely faster but still not quite enough to start the engine..
Any tips or ideas to look into?
Does the regulator play a art in starting the car?
I checked the fuse box as I read that earlier ones could do with solder but it appears to be a newish Wolfsburg West box which appeared to have spot welded pins like the newer boxes so doubt this is a problem |
Posted: Sun Sep 27, 2015 6:11 am Post subject: |
Ok so modern cars have got me into bad habits and I always press the clutch down when starting cars.
I read somewhere that this can cause slow starting so tried it and whilst still a little slow for my liking it was fast enough to start the bug every time I tried so let just see how it goes. Despite soldering the wiring ends I think I'll order some new battery/starter cables just to make sure |
Posted: Sun Sep 27, 2015 7:07 am Post subject: |
Rippers wrote: |
Any tips or ideas to look into? |
Yes, how old is the battery? What is the voltage reading on the battery at rest? What is the voltage reading at the battery when cranking?
Quote: |
Does the regulator play a art in starting the car? |
No.
The speed with which the starter cranks the engine is largely dependent on how much current the battery can give. Assuming you have a healthy properly sized battery and an engine with stock compression, the 6V starter should spin it over pretty quickly.
As you've seen, once you've gotten the solenoid to activate, the rest of the electrical system is out of the picture and does not come into play. It's just battery direct to starter motor. So either the battery is weak, your grounds are weak, or the starter motor itself is worn. _________________ 1965 Volkswagen 1500 Variant S
Posted: Sun Sep 27, 2015 7:39 am Post subject: |
1. Did you remove the starter for polishing and greasing as posted before? Check the other bushing and brushes inside starter??
2. Have you soldered up all those replaced terminals with that yellow plastic collars on them? If you see any other colored collared terminals you need to solder them on or replace with factory terminals and swedged on with a ratchet crimp tool.
3. Have you removed both battery cables to clean both ends of both cables, and grease them? If you have any of those battery replacement clamps that bolt/clamp onto the battery cable when you cut off the old one? If so replace the whole battery cable with new one which has clamp swedged onto the cable so as to have a gas tight connection there that oxygen, acid which causes corrosion can not get into.
4. Done same as #3 to the transaxle to body ground cable?
5. Clean and grease up all connections between gen/reg, starter? Not only the wires thru those areas, but any grounding points like the regulator mounts. _________________ In Stereo, Where Available! |
Posted: Tue Sep 29, 2015 2:54 pm Post subject: |
I changed the bush tonight, greased it up and whilst very slightly improved.. still slow..
Bought and fitted new battery cables.
The Optima battery is strong and could crank the starter for ever so plenty of juice..
I'm left with thinking either the replacement starter is naff or something engine or clutch related it making the engine turn slowly.
Going to see how well it cranks without spark plugs in tomorrow to see if the engine is loose.. and whether the starter is actually even capable turning fast.
I can't see it being the engine tight as I can push start the car within a few meters.
What on earth could it be grrr.. my money is on it being a naff starter |
