Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Mon Sep 28, 2015 8:28 am Post subject: cutting hard to reach metal... |
Since i started working on my bus ( http://www.thesamba.com/vw/forum/viewtopic.php?t=637670 ), i cut most metal with my angle grinder, with some success. the 3/36 wheel is quite thin, and last a good while.
But now i want to cut stuff that is near corners (batterie tray for example), and i have no clue how to do it. Obviously the grinder doesnt reach it, so i'm wondering, what do you guys use? i have no air, so air tool are out of the question for now...
I got two in mind, but not sure if any are really what i need ;
A Saw? (DeWALT 10A Reciprocating Saw)
http://www.canadiantire.ca/en/pdp/dewalt-10a-reciprocating-saw-0541236p.html#.VgXwT_TZQw8
A.... cut out tool? (DeWalt DW660)
http://www.canadiantire.ca/en/pdp/dremel-rotary-tool-kit-0544869p.html#.VgXwF_TZQw8
(if you can't reach the site without entering a postal code, use G1B 1Y2)
I'm also considering a dremmel, but it feels more like a crafty store tool than anything, and i see little to no wheel for it for sale...
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Sep 28, 2015 9:07 am Post subject: |
I only buy the 12" long metal & wood cutting blades for my electric reciprocating saw. I only use my angle grinder for starting cuts & corners. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Sep 28, 2015 10:58 am Post subject: |
From your description of what you need to do, choice A (reciprocating saw) is what you need. And they can be had, a lot cheaper. http://www.harborfreight.com/power-tools/reciprocating-saws.html
(Before anyone goes on a rant about HF tools, I don't think the OP is a full time body shop guy who needs to do a lot of cutting on the daily. I've used the HF saw to cut out floor pans (more than once) and chop up a whole car into bite sized pieces. It is adequate.)
Do as Mike says: Use the cut-off tool to start your cuts, then switch to the saw. _________________ Everything known to man has been written.
Readers are Leaders! |
Enkiel Samba Member
Posted: Mon Sep 28, 2015 11:08 am Post subject: |
Air-Cooled Head wrote: |
Do as Mike says: Use the cut-off tool to start your cuts, then switch to the saw. |
I'm a bit scared by the bulk... cutting a bus battery tray seems to be a very tight spot to reach. kinda wish i had a picture to show.
EDIT: a picture, its not mine, but it shows at least how hard it is to reach (or maybe i'm not thinking outside the box enough...)
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Mon Sep 28, 2015 12:16 pm Post subject: |
Not a rant about HF tools but a reciprocating is a tool that can have many uses. I'd personally spend a few more $$$ on a quality product (since the op listed DeWalt). But 10 amp is great but you could get away with less, say 8, and save a few coins. It would also be physically smaller to fit in the compartment. _________________ Stupid people do stupid things. |
Enkiel Samba Member
