ozzo Samba Member
Posted: Mon Sep 28, 2015 10:11 am Post subject: 356 distributor |
when i got the car the po was running it with one distributor spring broken.
i got the best rebuild kit i could by and restored it.
i think because of the one spring missing smashing, the internal advance now is more than 30 deg... probably around 40.... i can set the total advance at 35@3000 rpm but yhe idle advance goes atdc.... it runs but oround 2000 rpm it bogs....
i tried to put some very thin sheet metal around the hole to decrease the inner diameter but does not look working... i can t weld close and redrill and don t know how to redo the advance stop pin which is also worn. does anybody sell this pin? any tip on how to build it?
other option is to lock the internal advance and tun cb black box or 123 ignition... any tip in which direction should i go?
thx |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Mon Sep 28, 2015 11:31 am Post subject: 356 distributor |
Contact Glenn Ring. He's very much a regular on The Samba. His avatar is a distributor ID plate so he'll be easy to find. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76896 Location: Sneaking up behind you
ozzo Samba Member
Posted: Mon Sep 28, 2015 11:39 am Post subject: |
i bought the rebuild kit from him some years ago.... then i stored the car... now it is time to fix it and drive again... i ll see if he reply here |
ozzo Samba Member
Posted: Mon Sep 28, 2015 11:42 am Post subject: |
thx glen
actually i m in italy. i can give you my email. [email protected]
thx |
ozzo Samba Member
Posted: Tue Sep 29, 2015 2:30 pm Post subject: |
After some more checking i found that the distributor engage teeth are worn and that if i turn the distributor shaft with screwdriver clockwise and ccwise it moves some degrees, plus no spring under distributor.
Copper cranckshaft timing gear is same as vw? I found also one vw distributor drive shaft with fuel pump cam on side as per 356.... will it work? It costs 1/10 of porsche replacement
thx |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
ozzo Samba Member
ozzo Samba Member
Posted: Wed Sep 30, 2015 11:18 pm Post subject: |
the one installed in car is marked vw.... so i ll replace it and bronze timing gear on crank.
opening third piece is it mandatory to replace the rubber seals or they can be re used? |
Posted: Thu Oct 01, 2015 12:17 pm Post subject: |
ozzo,
It is cheap insurance to replace the seals anytime you remove the cover.
Better safe than sorry. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Thu Oct 01, 2015 8:45 pm Post subject: |
Ozzo, unless your engine alternates between clockwise and counterclockwise rotation, hysteresis of the distributor drive will have negligible effect.
( http://www.businessdictionary.com/definition/hysteresis.html )
All 616 engines use VW parts for cam and distributor drive. Even worn bronze gears can give good results. In fact, I have never had to replace one in over 50 years to correct a timing issue in a running engine, unless the gear was damaged due to faulty distributor drive gear installation.
edit: auto fill correction from Bozo to ozzo _________________ Jack Staggs
Actual name |
ozzo Samba Member
Posted: Sat Oct 03, 2015 9:47 am Post subject: |
just measured advance angle is 15 deg with bottom dog foot of distributor loched in a vice and more than 20 with dist in car... so i don t know what to think
... even because the effect of a worn gear would be subtracting degres not adding... just i stll have doubt because i made that messurement |
ozzo Samba Member
Posted: Sun Nov 01, 2015 6:38 am Post subject: |
just to close it.
replaced bronze gear on crank and distributor shaft and distributor dog leg with vw stuff, 1/10 of buying through porsche dealer. no more click clack between dist shaft and bronze gear.... timing perfect now. solved |
