Skulptorchaz Samba Member
Joined: June 11, 2013 Posts: 839 Location: S.E. Indiana
Posted: Tue Sep 29, 2015 3:55 pm Post subject: Cylinder heads - Time to BREEEETHE!! Which 1's? |
Now that I have the carbs ordered I may as well look into heads. (what the hell, only $$$$$$$$$$)
To refresh memories, it's a 1915, SCAT cam #20006 (biggest for street), counter weighted crank and duel 40's coming for the juice boxes.
I had the heads cut when we built it and it always ran well but, time to let her breathe.
I was looking at some heads on Appletree but not sure what to go with. Tom there, is good about helping people but I was also interested in your opinions. I guess I want it to "jerk a knot in my tail" as was so eloquently put to me. (that's just so funny!)
Opinions, or suggestions, got any?? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Sep 29, 2015 4:01 pm Post subject: |
I'd get a set of 049 revmasters 40x35 or tim's stage 1's. You want them flycut to 50cc. Dual springs. 28mm venturies will limit you to about 100 hp so consider swapping them to 32mm as well. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Tue Sep 29, 2015 6:31 pm Post subject: |
Perspective...
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1181
Description:
Designed for maximum power output on Regular Fuel. The "Builders Choice" Engine Kits are set up with the novice builder in mind. Easy to assemble with pre-determined compression ratio's, connecting rod length, camshaft and cylinder heads. The "Builder's Choice" engine kit takes all the guess-work out of building you own engine. Each kit is listed with the correct carburetor size, intake manifold, and exhaust type needed to achieve the advertised Horsepower output. Never before have engine-building secrets like these been let out to the public! Take advantage from years of engine building experience with the Builders Choice Engine Kit.
Features
1181 - 120 HP 1915cc Builders Choice Engine Kit includes:
2250 - Eagle Racing Camshaft
1275 - AS41 Dual Relief Super Case - T-1 & 2 Welded #3, Full Flowed, Cut for 94's
1289 - Super Race Rods (VW Journal) 5.400" length (set of 4)
1859 - Maxi 30 Full Flow Oil Pump
1278 - CB High Performance Case Kit
1537 - 28mm Ultralight Lifters (set of
1941 - Rear Main Seal - 13, 15, & 1600cc
1804 - MAIN BEARINGS STD
1865 - ROD BEARINGS T/1 STD
1525 - Eagle Cam Gear
1557 - Windage Tubes
1398 - 044 Super Mag CNC Round Port Cylinder Heads (40 x 35.5) 94 bore (with MINI WEDGE CHAMBER)
1770 - Thin Line Oil Sump - 1 1/2 qt.
1628 - Chromoly Push Rods - blank end (.035")
1081 - Super Big Bore Kit, 94 x 69mm
1087 - Teflon Buttons - 94mm pistons
1702D - C Channel Valve Covers (set of 2)
1424 - Main Bearing Dowell Pins (set of 5)
1999 - 8mm Deflector Plates - fits 13, 15, & 1600cc (set of 2)
1904 - Case Washer Set
1255 - Rubber-Coated Cam End Plug
1105 - 69mm 4140 Forged Chromoly Crank
1303 - Forged Chromoly Lightweight Flywheel - 200mm (o-ring seal)
1360 - Racing Gland Nut with washer
1229 - 8mm Chromoly Head Stud Kit - Dual Port
1849 - Racing Camshaft Bearing Set
1918 - Crankshaft Gear Assembly Kit w/Racer Spacer
1684 - CB Super Stock Rocker Arms - Complete Kit 1.1:1 Ratio (stock)
1362 - End Play Shim Kit
1908 - Case Lock Nut Kit
1973 - Gasket Set - 13, 15, & 1600cc Dual & Single Port Engines
LABOR-3 - Weld #3 Rear Case Web
LABOR-MC-BB - Machine Case - Big Bore
LABOR-FLOW - Full Flow Case
LABOR-CC-CS - CC Heads to 52cc
HP rating is based on Dual 44mm Carbs, 1 1/2" Merged Header with compression set at 8.5:1 using listed parts in kit. Mid Grade fuel is required for this kit.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
slalombuggy Samba Member
Posted: Tue Sep 29, 2015 7:21 pm Post subject: |
I'd also look at the Revmasters heads. I just ordered a set for my buggy engine. You can order them with a variety of combustion chamber sizes and they will unshroud the valves for better flow, all included in the price. My heads were $400 with the chamber work done the way I wanted
brad |
monomanx Samba Member
Joined: September 25, 2004 Posts: 715 Location: Southeast
Posted: Thu Oct 01, 2015 8:27 am Post subject: |
I just received an email that CB is having a fall sale...10% off of orders over $200.00
Maybe you could buy this engine kit. a $400,00 discount does not sound too bad! |
Posted: Thu Oct 01, 2015 10:12 am Post subject: |
I got my engine and it only has about 1500 miles on it. I certainly appreciate the thought but, no need for another one. I just need to figure out which heads would do me the most good. My present ones are perfectly fine, I am just wanting a bit more. lol
Murzi sounds like he may have a grasp of what I'm looking for.
I guess, if I go with Revmasters, I can explain what I have and they can give me a good idea on which way to go. (???) My guess is they are good about that and reputable but, I always like throwing it out to you guys for more opinions.
thanx! |
Posted: Thu Oct 01, 2015 11:32 am Post subject: |
Skulptorchaz wrote: |
thanx! |
It's a balance of compression, cam profile, headflow potential, and intake/exhaust. It's a guess on anyone's part as to the results you will get.
