highlandmurf Samba Member
Joined: April 08, 2010 Posts: 296 Location: Hudson Valley, NY
Posted: Wed Sep 30, 2015 3:55 pm Post subject: Squeakey type 4 with video |
So, When my engine starts, there is a squeak coming from the back until it runs awhile. as you can hear here:
https://www.youtube.com/watch?v=u7Lw9g5N5P0
Any thoughts, Slipping belt, bad bearing, alternator going?
The belt seems pretty good.
Thanks _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Tcash Samba Member
Posted: Wed Sep 30, 2015 7:04 pm Post subject: Re: Squeakey type 4 with video |
highlandmurf wrote: |
Thanks |
Pull the belt off to rule out the alt. and belt.
Good luck
Tcash |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Sep 30, 2015 7:47 pm Post subject: Re: Squeakey type 4 with video |
Thanks |
At idle, hit the alternator pulley where the belt joins it with a shot of WD-40.
Noise go away?
Take belt off and sand the pulleys at the belt contact surfaces, scrub belt with a gas or carb cleaner soaked rag, then sand it at pulley contact areas just to scuff off the glaze.
Noise not go away? Alternator bearing is a possibility. So might be a dry distributor shaft.
Colin _________________ www.itinerant-air-cooled.com |
AAVeeDub Samba Member
Joined: August 30, 2011 Posts: 283 Location: Phoenix, Az
Posted: Tue Feb 02, 2016 11:22 pm Post subject: Re: Squeakey type 4 with video |
hey @highlandmurph,
did you figure out what the problem was? I have this same noise ive never had before but it sounds like its coming from the back.
Could be a dry distributor shaft, i havent ruled that out yet. just stumbled on this post. i didnt think about the distributor shaft because it sounds like its from the back but ill try oiling it.
problem fix would be ideal for your post! _________________ '74 ShagWagen
1700 tIV stocker
Dual Baby Webers |
Posted: Fri Feb 12, 2016 5:52 pm Post subject: Re: Squeakey type 4 with video |
Yup, Colin had it again.
Glazed over fan belt. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Posted: Fri Feb 12, 2016 6:05 pm Post subject: Re: Squeakey type 4 with video |
Dayco Top Cog |
