kawaii055 Samba Member
Posted: Fri Oct 02, 2015 8:33 pm Post subject: Problem after jacking car up |
Searched and couldn't find anything, maybe i'm looking for the wrong thing.
I jacked up the rear of my 67 bug today and when i dropped it back down the rear suspension didn't settle down. it looks like there is no engine in it. I rolled it around a bit (not running yet) and it didn't drop down. Did I damage something? sorry if this is a dumb question i'm a first time owner. Thanks for the help! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Fri Oct 02, 2015 8:35 pm Post subject: Re: Problem after jacking car up |
kawaii055 wrote: |
That's normal, it'll settle when you drive it. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Oct 02, 2015 8:36 pm Post subject: |
i noticed some oil leaking from the boots, also normal? car isn't running anyway to fix it without driving it? roll it around more? thanks |
Posted: Fri Oct 02, 2015 8:46 pm Post subject: |
kawaii055 wrote: |
Oil leaking from boots, not normal.
No need to fix the rear suspension but if you must I guess you could roll it around more. I wouldn't bother though. _________________ 1965 Volkswagen 1500 Variant S
Kadixon76 Samba Member
Joined: June 29, 2015 Posts: 36 Location: Richland, WA
Leaking axle boots is a common problem, and should be addressed. And yes, you can can roll it around 10, 15, 20 ft forward and back and it should settle out. _________________ Kevin
____________________
63 Ragtop - current project |
Posted: Fri Oct 02, 2015 8:51 pm Post subject: |
Cool I was worried thanks for the quick replies guys |
Ojai63dbl Samba Member
Posted: Sat Oct 03, 2015 5:57 am Post subject: |
axle boots will leak when jacked up (weeping for not being on road). One you roll it back and fort or drive it - check then -- if stil leaking reset boot or replace |
Posted: Sat Oct 03, 2015 7:47 am Post subject: |
Ojai63dbl wrote: |
axle boots will leak when jacked up (weeping for not being on road). |
I like this _________________ 1965 Volkswagen 1500 Variant S
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sat Oct 03, 2015 8:13 am Post subject: |
Ojai63dbl wrote: |
Agree. Weeping for the road and from the extreme angle of the axle tube stretching the top and compressing the bottom of the boot. This angle can tear an older boot. _________________ 1964 Sedan 6 volt |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sat Oct 03, 2015 2:41 pm Post subject: |
Search for threads about replacing the boots. There are a few simple steps that will make them last much longer. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24737 Location: Olympia Wash Rinse & Repeat
Posted: Sat Oct 03, 2015 3:09 pm Post subject: |
Agreed, replace the boots and learn how to install them properly. Then they will not start to leak or get torn up when you jack up your VW.
Skip learning and you will end up investing a lot more time and $$ just replacing boots over and over. _________________ In Stereo, Where Available! |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Oct 03, 2015 5:32 pm Post subject: |
I always put something in each springplate like a big bolt or a 17mm nut so the rear won't sag and the boots don't get squashed. |
Posted: Sat Oct 03, 2015 8:00 pm Post subject: |
thomas. wrote: |
Lot easier to just install the boot the right way.... _________________ In Stereo, Where Available! |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Sun Oct 04, 2015 10:16 am Post subject: |
thomas. wrote: |
Good way to get hurt if the bolt or nut decides to slip out. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
Posted: Sun Oct 04, 2015 5:20 pm Post subject: |
cool thanks for all the help guys! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Oct 04, 2015 6:30 pm Post subject: |
thomas. wrote: |
I do the same thing when replacing boots, as does every pro VW mechanic I've ever met. Keeps the axle level and makes the job much easier to boot
Once replaced I also do this every time I jack up the car, or any customers car with swing axles that has good boots. Doing so keeps the stress off of them, which can and does cause oil leaks to develop due to the outer clamp slipping or the boots getting pinched on the frame horn and cracking prematurely.
I've heard "Ever since you changed my oil I have a leak from my axle boots" too many times
If you pick the wrong sort of spacer and you're afraid it's going to shoot out at you like a rocket or something, for your self protection you can put a C-Clamp or Vise-Grip on the nut/spacer/shim chosen to stabilize it in position. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Mon Oct 05, 2015 4:27 am Post subject: |
bugmandave wrote: |
thomas. wrote: |
Good way to get hurt if the bolt or nut decides to slip out. |
I've never had one pop out , but if using a 17mm nut I've put a piece of safety wire through it to be on the safe side. |
Posted: Mon Oct 05, 2015 3:53 pm Post subject: |
thomas. wrote: |
bugmandave wrote: |
thomas. wrote: |
I'd actually be more concerned with the axle suddenly dropping under high spring pressure and crushing anything under it or around it like your arm, hands, legs, head etc. than the nut shooting out like a bullet. Remember folks, stored energy can be a KILLER! _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
