Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Sat Oct 03, 2015 8:49 am Post subject: how do i swap this flasher relay for my new LED tail lights? |
I got my brand new LED Taillights installed thanks to CHIP! These things are awesome!!! Now I need to swap the flasher relay.
Here is a picture of what I believe is my current flasher...
Two wires piggy back off one connection. Of the three wires one goes into the fuse box, one goes to the steering column/speedo and the third goes back up into the wiring harness and i suppose back to the taillights.
Here is my new flasher that came with the tail lights...
How do I swap these out? |
Posted: Sat Oct 03, 2015 9:09 am Post subject: |
nevermind i got it! |
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Sat Oct 03, 2015 8:03 pm Post subject: |
What did you do to get the ep35 to work? I bought one to replace a missing relay in my 64 and I get nothing. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26310 Location: Douglas, WY
Posted: Sun Oct 04, 2015 3:08 am Post subject: |
Did you connect 31 up to a good ground?
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Oct 04, 2015 3:54 am Post subject: |
Try it with your brake lights on just to be sure. I think I tried that one on our buggy and it didnt work right, but we also had to run a "trailer converter" since we only have a single bulb dual element tail lights. Worked fine until you hit the brake lights and then it stopped flashing. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Oct 04, 2015 5:14 am Post subject: |
TheDon wrote: |
What did you do to get the ep35 to work? I bought one to replace a missing relay in my 64 and I get nothing. |
Flasher is easy. Keep the 2 wires together, hook them to the L terminal if looking at the new relay diagram on the packaging. Hook the wire going to the fuse box to the + according to the diagram. Then run a ground wire to the 3rd terminal, I just run it to the bolt holding the brace up behind the speedo. Let me know if that helps |
