Ben Dover Banned
Joined: March 02, 2014 Posts: 92 Location: Charleston
Posted: Sat Oct 03, 2015 10:29 am Post subject: Can you put larger pistons and cylinders in a 36? |
I'm kicking around the idea of building a vintage performance 36er for my 58 euro rag. WW has the Okrassa kit,69.5mm crank,a performance can and the Abarth exhaust, but no mention of ratio rocker's or larger P's and C's. Are these not available? |
GTV Samba Member
Posted: Sat Oct 03, 2015 1:35 pm Post subject: |
Not yet.
What ever happened to the 80's that ac.net had falsely advertised? I'm surprised AA hasn't tooled up to make them yet, I would have guessed there is a large enough demand. _________________ EMPI Power Rules! |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Ben Dover Banned
Posted: Sat Oct 03, 2015 2:31 pm Post subject: |
That's great news on the ratio rocker's! |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sun Oct 04, 2015 1:58 am Post subject: |
It is possible to modify 83mm big bore kit to fit, but you have to cut down cooling fins and machine spacing for the cylinder studs (wider on the 40 hp cylinders). It is threads on how to do it here on the forum.
You also have take up the case and cylinder heads to fit. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Mon Oct 05, 2015 12:02 pm Post subject: Big bore 36'er |
Modify a set of 912 cyls., bore for 83.50 and use an Okrasa 69.5mm crankshaft gives you: 1522cc's. Install a Porsche 74mm
crankshaft and now you have: 1621cc's! If I remember correctly, the barrel thickness at the head meas. 3.5mm+
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Mon Oct 05, 2015 4:17 pm Post subject: |
Where are you guys sourcing the 80 and 83.5 millimeter pistons? Are you having them made? Are they production made pistons from another application? They don't look like custom CP, Wiseco, etc. Thanks. _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
morymob Samba Member
Posted: Mon Oct 05, 2015 5:59 pm Post subject: |
This came up awhile back using a Mazda 83mm piston, from dealer pistons and add rings,each appx $100 each including tx, $500 for 4pistons/+rings, too rich 4 my blood to experiment to fit but it has been done. Cyls ($$?) Getting pricy if u can also find cyls, as usual no warranty offered at this time. |
Posted: Tue Oct 06, 2015 7:30 am Post subject: |
Mr. Okrasa wrote: |
I collected the 83.50mm NOS piston sets way back in the 80's when nobody cared for them. |
Are these the Mazda pistons I've heard people mention here? 2nd oversize on an 83mm? What was their original application?
Thanks
j. _________________ Independent German Auto
671 Fern Drive
(321) 449-4665
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Posted: Tue Oct 06, 2015 8:44 am Post subject: |
Or use JE light weight pistons. That way you can also get the pin height right.
I just finished mock up on a 83,50 x 76 engine. Plenty of room to raise the pin height so engine with remains stock.
T |
Posted: Tue Oct 06, 2015 8:47 am Post subject: |
Low Bräu wrote: |
Mr. Okrasa wrote: |
Thanks
j. |
No. They are NOT Mazda pistons. They are GENUINE VW Metal Leve first oversize 83.50mm in their original boxes with rings, pins and clips. _________________
VW www.Okrasa.com
Posted: Tue Oct 06, 2015 4:37 pm Post subject: |
So these are 40HP big bore pistons with a 20mm pin and not early 1500 oversized pistons with the larger pin? Were the old Metal Leve big bore pistons 83.5? I recently purchased an NOS set of NPR (Japan) P&C kit that is 83mm not 83.5 that I plan on using with a set of cast iron Porsche cylinders. Thanks for the info.
671 Fern Drive
(321) 449-4665
Posted: Tue Oct 06, 2015 5:28 pm Post subject: |
Low Bräu wrote: |
j. |
Yes. They are VW 40hp 1st. oversize pistons with 20mm pins. Metal Leve made STD. and 1st O/S. piston sets.
The Porsche cylinders will work after you bore them to 83mm and relocate the head stud pattern in order to fit. _________________
VW www.Okrasa.com
Posted: Wed Oct 07, 2015 7:42 am Post subject: |
I'm sure those things are tough, if not impossible, to find these days. Thanks, again for sharing.
671 Fern Drive
(321) 449-4665
Posted: Fri Oct 09, 2015 4:37 am Post subject: custom pistons |
EGGE is a co in Santa Fe springs, custom make pistons,kits etc. |
