Replacing Drive Flange Oil Seals: Automatic Transmission
PRND2L
PRND2L is offline
PostPosted: Sat Oct 03, 2015 2:10 pm    Post subject: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
I wanted to share my procedure for replacing the final drive seals on the differential for an automatic transmission 1990 Vanagon.
I've seen a few other procedures out there but only for manual transmissions which are very different than the A/T differential.
You can use the Bentley procedure on page 37.10. But I found it almost no help at all Sad
You can easily do this procedure with the transmission and differential in place.
There's lots of space around the diff to work.
I did the whole procedure with the back of the van up on steel ramps in about 2 hours.
Tools Needed:
- 6mm Hex bit (to remove drive flange)
- long flat head screw driver
- torque wrench
- 17mm Hex bit or "nut jam tool"
- 17mm socket
Parts Needed:
- 2 new final drive oil seals (original VW part # 018-409-399) I used the same part from a Quantum (part # 016-409-399B)
- 1.25L SAE 80W, SAE 80W/90 hyphoid gear oil.
- moly grease
Procedure:
Here is a picture to orient you.
This is the passenger side of the differential where the axle is mounted to the drive flange. The torque converter is to the left and the automatic transmission is on the right. The black differential pan is on the bottom. The large hex socket is the diff fill hole.
1) First remove the drive axles Smile
I won't go over the procedure to remove the drive axles. But it is simple enough.
There is a detailed description on how to remove both rear drive axles here
<<http://www.van-cafe.com/home/van/page_16_9/cv_joint_maintenence.html>>
Go down to the section "CV Joint Removal and Replacement"
(I recommend you read the entire article and inspect/replace/repair your CV joints while they are out.)
When the axles are removed all you will be left with are the drive flanges sticking out of the side of the differential.
Before removing the drive flange take some time now to clean as much of the crud as you can off of the differential as possible.
Especially everything directly above the drive flange.
When you remove the drive flange you don't want any dirt getting in to the differential!
2) Remove Drive Flange
The drive flange is held into the differential by a single bolt that has a 6mm hex socket.
Use a 6mm hex bit (circled in green) to remove the centre bolt holding the drive flange to the diff.
(The other bit is a 12mm 12point bit (T40) that is used to remove the drive axle bolts.)
Use 2 axle bolts as shown below to help you get the drive flange centre bolt out.
The drive flange should now pull straight out.
3) Remove old seal
My seals were so worn that they came out with the drive flange Sad
You will most likely have to pry them out.
Wrap some tape on the end of the long flat screw driver to avoid scratching anything. Then insert the end behind the seal and pry away!
It should normally take quite a bit of force.
4) Clean everything!
Here is picture of both of the drive flanges cleaned up and ready to go back in
A bit of kerosene and a brass brush got them almost looking new!
Notice that they are different heights.
The one on the right (tall one) is the Passenger side drive flange.
The left one (shorter one) is the Driver side drive flange.
5) Prepare and install new seals
I noticed that Bentley says "fill space between seal lips with multi-purpose grease"
I couldn't find any reference to having to do this with oil seals anywhere else. I ended up packing them with some moly grease I had.
Insert the oil seal into the opening with the 'greased' side facing inside. The outside of the oil seal will be flat.
It will only go part of the way in by hand! Don't just leave it here!
You will have to drive it in the rest of the way. It should eventually be well seated in the opening.
I used a mallet and a piece of hardwood that was about as wide as the seal diameter (55mm - 2 1/4")
Make sure the wood is touching opposite sides of the seal when you are driving it in so it goes in straight.
Here's how it looked when the seal was driven as far in as it would go.
6) Install the drive flange
You remember which drive flange goes on which side right?
Insert the drive flange slowly until it bottoms out, then twist it slightly to make sure the splines are engaged properly before pushing it all the way in.
Insert the correct bolt and use the 6mm hex bit to torque it down to 25 Nm ( 18 ft.lb)
You may have to install 2 drive bolts and use a screw driver like in the bolt removal in order to get enough leverage.
7.) Do the removal and installation for the other side.
8.) Fill Differential with gear oil
Remove the diff oil plug with either a 17mm Hex bit or you can make a "nut jam tool" out of a 17mm 1" bolt and 2 17mm nuts like this.
I just filled the diff with 80W/90 gear oil until it started to run out of the fill hole.
My diff pan does not have a leak so I decided to not take off the pan and drain the oil.
One because there is no local replacement gasket and I didn't want to fiddle with silicone.
Two because the seals have been bad for a few months now and I have refilled it several times this summer Smile
Then replace and tighten the fill plug.
9.) Re-install the Drive Axles.
10.) Go for a drive!
-Zander
'90 Westfalia Automatic
kamzcab86
kamzcab86 is offline
PostPosted: Sat Oct 03, 2015 3:58 pm    Post subject: Reply with quote
Nice! Added to the FAQ.
~Kamz Anxious
2016 Golf GTI S
Merian
Merian is offline
PostPosted: Sat Oct 03, 2015 4:10 pm    Post subject: Reply with quote
xlnt, detailed instructions
- just to clarify, this is not the same as the oil seals between the A/T and the diff., which is often required to prevent destruction of the differential R&P, and about which GoWesty says requires removal of the A/T section
http://www.gowesty.com/library_article.php?id=305
Wildthings
Wildthings is offline
PostPosted: Sat Oct 03, 2015 9:15 pm    Post subject: Reply with quote
You want to smear grease on the contact area of the seal between the two lips. Where you put the grease is not where it is needed. Always lube the lips of a seal when you are putting it in. A lot of people have opinions here but some lube is better than nothing, be it oil or grease.
Since your old seals fell out I would also probably have glued the new ones in with Permatex or some other slow drying sticky sealer.
gacrawford
gacrawford is offline
PostPosted: Thu Nov 12, 2015 8:35 pm    Post subject: Re: Replacing Final Drive Oil Seal: Automatic Transmission Reply with quote
Thanks for posting a great article. The fact that you specified the part# has ended a 3 day headache for me- why does Cip1, along with many other suppliers,( apart from "Airhead Parts), quote part# 091-301-189 when it obviously doesn't fit and your does? Thanks again. PS Anyone know a supplier for the correct part# in Canada? Thanks.
skelly
skelly is offline
PostPosted: Sun Apr 14, 2019 9:40 am    Post subject: Re: Replacing Final Drive Oil Seal: Automatic Transmission Reply with quote
awesome write up and pics... just blew an hour trying to find out this info! Here's a link to the supplier I found with the correct seals for 5 bucks each
https://www.hansautoparts.com/016409399BSeal.aspx
?Waldo?
?Waldo? is offline
PostPosted: Sun Apr 14, 2019 1:49 pm    Post subject: Re: Replacing Final Drive Oil Seal: Automatic Transmission Reply with quote
The only thing the grease is doing where you put it is diluting/contaminating your transmission fluid. Your seal lips are not even lubricated which is the whole reason for the grease. It is not unlikely that the un-lubricated seal lips will burn and leak or cause the seal to spin and self-destruct like the old ones.
Hans Auto Parts sells low quality knockoff parts made in China. I would not use one of their oil seals on one of my vehicles.
The seals are readily available from the major Vanagon vendors and I would trust those far more than Hans. E.g. https://www.vancafe.com/018409399-p/018409399.htm
pierrox
pierrox is offline
PostPosted: Sun Aug 16, 2020 3:15 pm    Post subject: Reply with quote
That's a great write up and I'll put it on the list of things to do to my inherited from Dad 1986 Vanagon.
I read about this and started to freak out a bit as the aforementioned Vanagon has 200.000km on its clock and has never had this operation done. The transmission doesn't feel 100% right - especially once warm. Anybody made a write up for it? I saw a YouTube video that showed where the seals are supposed to go but its maker never made the "how to" video he had promised...
Our bus is on Instagram
instagram.com/biencuitbus
View user's profile Send private message Instagram Classifieds Feedback
Eric_Taylor
Eric_Taylor is offline
PostPosted: Sat Apr 24, 2021 9:22 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
Thread revival!
I did this project today, and this is a very helpful write up. After a drive, I'm still seeing fluid coming out of the same spot. Thoughts? I did fill the diff to the brim, so perhaps it's a bit overfilled.
Wildthings
PostPosted: Sat Apr 24, 2021 11:39 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
What do you mean fill the differential to the brim? It gets filled to the bottom of the fill hole. Does it appear to be leaking from the seal or from elsewhere?
Wildthings
PostPosted: Sat Apr 24, 2021 11:50 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
Note on the original post, the proper tool for removing the axle bolts is a 8mm triple square bit and not a 6 point Torx . A triple square adapter that is ~3 inches long makes the job easier than a shorter one.
The automatic differential takes 90wt GL-5 gear oil, though a 80w90 multigrade GL-5 would be fine.
Also the job is easier if you buy and use a seal removal tool. This same style tool is helpful for other seals on the vehicle as well.
djkeev
djkeev is offline
PostPosted: Sun Apr 25, 2021 4:20 am    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
You won't know what tool you need for axle bolt removal until you are there looking at the bolt heads.
Mine are all 6mm hex.
My other Van had all triple square.
Some Vans have a mixture of both...... sometimes on the same joint!
Dave
Ghia
Vanagon
Beetle
Eric_Taylor
PostPosted: Sun Apr 25, 2021 12:34 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
Thanks for the responses here. I'll give a little more detail .
I did use a 6mm to remove the bolt for the drive flange and it fit well. per the Bentley I torqued the bolt to 18 ft/lb and that was no problem.
In saying I filled it to the brim, I opened the drain/fill hole to the left of the passenger side flange and filled it with the same diff fluid and weight that my mechanic put in during the last change of the diff. I filled it until it ran out of the hole, per instructions i've seen numerous places. This is a very seasoned vanagon wrench, who is well known here for custom vanagon work, so I trust the fluid weight is correct, though I would have to go get the bottle at my shop to give you the exact measurement.
After driving, when I looked at the bottom of the flange, there is gear oil seeping out. After filling, I cleaned the area and got the vast majority of it. This area was clean before the drive and now wet after the drive.
Is there an adjustment in the trans i'm missing? Was the torque too low?
jlrftype7
jlrftype7 is offline
PostPosted: Sun Apr 25, 2021 12:49 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
Couple of 3 things can go against you.... Wink Wink
The stub axle can have a slight groove in it where the seal lip rides, with enough wear no lip type seal can be expect to be tight against a worn spot on a shaft .
O- Ring seal AROUND the plate where the seal gets installed into , can be leaking a bit and your new seal is not at fault. See Bentley diagram for more info.
Last things, poor seal quality or possibly seal not installed flat against Transaxles, with the seal barely cocked at an angle in its mounting hole
Also check your vents on top of the Final Drive/Diff and Auto trans. Simple caps sitting on tubes, the caps need to be able to move up and down easily, venting pressure out of their assemblies if required. Caps can get rusted shut.
For what it’s worth, I had stub axle seal leakage with new seals , mostly in cold temps, then it stopped. ( and yes, level of gear oil was still good... Razz Razz )
Maybe the seals wore in a bit, either way, I’m happy
‘84 Tin Top - Hilga....Auto
Wildthings
PostPosted: Sun Apr 25, 2021 1:51 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
The cap covers up a spring loaded check valve and plays only a minor roll in sealing or venting, unless it is totally gobbed up with oily dirt. An occasional twist is all that is needed to keep it clear
jlrftype7
PostPosted: Sun Apr 25, 2021 8:00 pm    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
. Both of mine were rust and dirt clogged when I got our Vanagon in September 2018. I had to gently remove the caps and clean everything up, then tap the caps back on... Shocked
kourt
kourt is offline
PostPosted: Mon Apr 26, 2021 6:01 am    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
This is a helpful thread, but the original post on this thread omits the replacement of the o-rings in the ring gear adjusting rings (pictured below). Without replacement of these o-rings, you're not completely addressing the potential leak points.
Here's the necessary part at Van Cafe.
One must mark the position of the rings on the ring and transaxle (see the white mark on one of the rings below), remove them while counting turns, replace the o-rings, and then replace the rings with the same turns, to the same mark--unless you want to open the pan and adjust the ring gear backlash.
See page 39.60 of the Bentley for info on how to adjust the rings for backlash, which is the difficult part of working with the adjusting rings, or see the Peloquin install post I made on my automatic transaxle thread, which illustrates how to properly set the adjusting rings.
kourt
AceTaylor
AceTaylor is offline
PostPosted: Mon Apr 26, 2021 6:40 am    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
Just a couple of notes from my experiences. Take them for what they're worth.
That cast iron final drive section is like a sponge. It wicks up and holds oil. Like a sponge, gravity will pull the oil down and collect at a low point and drip after sitting for a period of time. It will do it for weeks. It will take a dozen cans of brake cleaner or several trips to the coin op car wash to get all the oil out of the cast iron.
MarkWard
MarkWard is offline
PostPosted: Mon Apr 26, 2021 7:31 am    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
I have a vague memory that the locks for these rings are accessed with the pan off unlike the manual transmission where you can completely access the rings from the outside. I apologize if my memory has failed.
kourt
kourt is offline
PostPosted: Mon Apr 26, 2021 7:37 am    Post subject: Re: Replacing Drive Flange Oil Seals: Automatic Transmission Reply with quote
You're 100% correct. One must remove the pan to open the locks, and then remove the rings. Thanks for catching that detail--it's important!
kourt
